大家好...
我在使用PowerShell与我的Intel AMT设备进行通信时遇到问题。 它之前一直工作得很好,但现在我得到一个Schannel错误70(协议错误) 我想这是因为Intel AMT不再支持TLS 1.0了。 我怎样才能让poweshell模块再次运行? 客户端的AMT版本为12.0.6,FW为12.0.6.1120 请指教 /海涅 以上来自于谷歌翻译 以下为原文 Hi All... I'm having issues using powershell to communicate with my Intel AMT devices. It's been working just fine before, but now i get a Schannel error 70 (protocol error) I guess it's because of Intel AMT not supporting TLS 1.0 any longer. How can i get the poweshell module to work again? The AMT version on the client is 12.0.6 and FW is 12.0.6.1120 Please advice /Heine |
9个回答
Helloheinekmadsen,我想告知英特尔SCS 12.0已经弃用了用于英特尔®AMT的英特尔®SCS通信的TLS 1.0安全协议,因为TLS 1.0协议已经识别出安全漏洞。
如果您想了解更多相关信息,请参阅以下第3.13节中的以下PDF文件:http://www.intel.com/content/dam/support/us/en/documents/ software / Intel_SCS_User_Guide.pdf如果您有任何其他问题,请告诉我,我将非常乐意为您提供帮助。最好的问候, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello heinekmadsen, I would like to inform that Intel SCS 12.0 has deprecated the TLS 1.0 security protocol for Intel® SCS communication with Intel® AMT, due to the fact The TLS 1.0 protocol has identified security vulnerabilities. If you would like to know more information about it, I would like to refer you to the following PDF File in the section 3.13. https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf Please if you have any other question, let me know and I will be more than happy to assist you. Best regards, Emeth O |
jerry1978 发表于 2018-10-24 17:18 嗨, 您是否阅读了我的完整帖子并查看了截图? 似乎你只是重复了我自己的发现,因为我还说不再支持TLS 1.0。 我的问题是让PowerShell模块工作,现在TLS1.0被删除了,模块似乎默认为TLS 1.0(纠正我,如果我错了) 我需要的是一个PowerShell模块,能够在新版本12中使用TLS。当前模块似乎已经过时了。 /海涅 以上来自于谷歌翻译 以下为原文 Hi, Did you even read my full post and viewed the screenshots? Seems like you just repeated my own findings as i also state that TLS 1.0 is no longer supported. My issue is getting the powershell module to work now thet TLS1.0 is depricated, and the module seems to default to TLS 1.0 (Correct me if i'm wrong) What I need is a powershell module that's able to use TLS with the new version 12. The current module seems outdated. /Heine |
你好, 好的,请接受我对误解的道歉。 我将调查有关您正在寻找的信息的更多详细信息,以便为您提供最准确的答案。 祝你有美好的一天。 最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, Ok, please accept my apologize for the misunderstanding. I am going to investigate more details about the information that you are looking for in order to provide you the most accurate answer about it. Have a wonderful day. Best regards, Emeth O |
你好, 我正在审查您遇到的有关此问题的一些详细信息,我想告诉您问题是powershell模块仅支持TLS 1.0和1.0。请求将升级powershell功能以支持TLS 1.1和 1.2。 不幸的是,这不是一夜之间发生的事情。但是,让我问你一件事: 您最近是否升级了系统?您是否使用旧系统使用较旧的AMT固件?您之前是否在没有TLS的情况下连接并且最近实施了TLS?我将等待您的结果以继续下一步。 最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, I was reviewing some details about this issue that you have been facing and I would like to let you know that the problem is that the powershell module supports TLS 1.0 and 1.0 only.The request will be to upgrade the powershell capability to support TLS 1.1 and 1.2. Unfortunately, this is not something that happens overnight. However, let me ask you something: Did you upgrade the system recently? Did you were using an older system with an older AMT firmware? Did you connect previously without TLS and just recently implemented TLS? I will be waiting your outcome in order to proceed with the next step. Best regards, Emeth O |
LingMao 发表于 2018-10-24 17:52 嗨.. 感谢您查看此问题。 情况是我们在外部测试环境中进行了PoC并开始在生产中实施。 由于安全性的提高,我们决定采用最新版本。 如果powershell模块将被更新,那将是很棒的。 /海涅 以上来自于谷歌翻译 以下为原文 Hi.. Thanks for looking into this issue. The situation is that we did a PoC in out test environment and the started to implement in production. We decided to go with the latest versions in production because of the security improvements. If the powershell module will be updated it would be great. /Heine |
你好heinekmadsen, 我代表我的同事跟进此案。 一旦我们为您解答,我们会立即与您联系。 祝你有美好的一天。 问候, 纳德T. 英特尔客户支持技术人员 根据与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello heinekmadsen, I am following up this case, on behalf of my co-worker. You will be contacted back as soon as we have an answer for you. Have a great day. Regards, Nader T Intel Customer Support Technician Under Contract to Intel Corporation |
你好, 你能不能请那么友好,并为我们提供你正在使用的powershell模块的版本? 最诚挚的问候,Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, Could you please so kind and provide us the version of the powershell module that you are using? Best regards, Emeth O |
嗨... 抱歉回复晚了... 我们使用版本3.2.4(根据控制面板中的添加/删除程序中的条目) /海涅 以上来自于谷歌翻译 以下为原文 Hi... Sorry for the late answer... We use the version 3.2.4 (according to the entry in Add/Remove programs in control panel) /Heine |
您好,非常感谢您提供的信息。 我们将调查有关它的更多信息,因为根据最后更新,TLS 1.0将不再受支持。 让我向上级部门询问,以便为您提供最准确的信息。最好的问候, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, Thank you so much for the information. We are going to investigate more information about it because according to out last update TLS 1.0 will not be supported any more. Let me ask to our upper level department in order to provide you the most accurate information. Best regards, Emeth O |
只有小组成员才能发言,加入小组>>
521浏览 0评论
GMT+8, 2024-12-26 16:22 , Processed in 1.512029 second(s), Total 95, Slave 78 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
