在为汽车应用选择组件时,您可能会发现自己问“我的汽车产品中使用的每个组件都需要AEC-Q200认证吗?”。
答案是不”。 AEC-Q200是抗应力的全球标准,如果这些组件将用于汽车应用,所有无源电子元件必须满足这些标准。 无源元件包括芯片电阻器,通孔电阻器,电阻器阵列,陶瓷电容器,铝电解电容器,固定电感器,NTC热敏电阻,PTC热敏电阻,电阻温度检测器,电流感应变压器,脉冲变压器,实时时钟,TVS器件等器件, PTC可复位保险丝等。 如果这些部件已通过标准中包含的严格的压力测试,则这些部件仅被视为“符合AEC-Q200标准”。 AEC-Q200有五种不同等级的组件可以测试,它们决定了车辆在何处可以使用。 请查看下面的图表,查看这些等级,每个等级的基本温度要求,以及可以使用该等级的部件。 以上来自于谷歌翻译 以下为原文 When choosing components for an automotive application, you may find yourself asking “Does every component I use in my automotive product need AEC-Q200 qualification ?”. The answer is “no”. AEC-Q200 is the global standard for stress resistance that all passive electronic components must meet if these components are going to be used in an automotive application. Passive components include devices such as Chip Resistors, Through Hole Resistors, Resistor Arrays, Ceramic Capacitors, Aluminum Electrolytic Capacitors, Fixed Inductors, NTC Thermistors, PTC Thermistors, Resistance Temperature Detectors, Current Sense Transformers, Pulse Transformers, Real Time Clocks, TVS Devicess, PTC Resettable Fuses and so on. These parts are only deemed to be “AEC-Q200 qualified” if they have passed the stringent suite of stress tests contained within the standard. AEC-Q200 has five different grades components can test to, which determines where in a vehicle they may be used. Please check the below chart to see these grades, the basic temperature requirements for each grade, and where that grade of part can be used. |
2个回答
连接器怎么样?
到目前为止,我看不到连接器的汽车等级 以上来自于谷歌翻译 以下为原文 What about connectors? So far I could not see any automotive rating for connectors |
你好@sp12,
虽然某些连接器是为汽车应用而构建和参考的,但它们并不像许多板级组件那样具有AEC-Q200等级。 事实上,如果你看一下它们中的许多,你就不会看到汽车级别的信息,因为它们被用于各种各样的应用程序中。 例如,TE在他们的网站上列出了他们的DTM系列连接器作为汽车,但是没有汽车评级。 谢谢 - 罗伯特· 以上来自于谷歌翻译 以下为原文 Hello @sp12 , While some connectors are built and referenced to be used in automotive applications they do not carry the AEC-Q200 ratings like many of the board level components. In-fact if you look at many of them you will not see an automotive level information as they are used in such a variety of application. TE for instance listed their DTM Series of connectors as automotive on their website, however there is no automotive rating. Thank You -Robert |
只有小组成员才能发言,加入小组>>
3295 浏览 3 评论
225浏览 1评论
GMT+8, 2024-5-15 17:03 , Processed in 0.661668 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
