我试图找到一个与之配对的圆形连接器:
螺纹的外径尺寸为15.56mm,因此它可能是M16,(除非SAE螺纹是这种情况常见的; 16mm和5/8非常接近)。 螺纹外壳内部约12.9mm 销的直径为1.1毫米 七个外销均匀分布在9mm圆上 如果有任何其他信息有助于识别这一点,请告诉我。 以上来自于谷歌翻译 以下为原文 I am trying to find a circular connector that would mate to this: The OD of the threads measures 15.56mm, so it is probably M16, (unless SAE threads are common for this sort of thing; 16mm & 5/8 are awfully close). The inside of the threaded shell is ~12.9mm The diameter of the pins is 1.1mm The seven outer pins are evenly spaced on a 9mm circle If there is any other information that would help in identifying this, please let me know. |
4个回答
我在想配对连接器可能是1754-1092-ND。
与我推荐的部件配合的连接器是部件1754-1091-ND,它似乎非常接近连接器上的尺寸。 以上来自于谷歌翻译 以下为原文 I’m thinking the mating connector might be 1754-1092-ND. The connector that mates to the part I am recommending is part 1754-1091-ND and it seems to be very close to the dimensions you have on your connector. |
谢谢,特拉维斯。
它确实看起来约为27 TPI,并且引脚编号模式是正确的。 我从制造商那里获得的是每个引脚按编号列出的内容列表,并检查了它用电压表列出的功能。 我会订购一个,看看它是如何适合的。 以上来自于谷歌翻译 以下为原文 Thanks, Travis. It does look to be about 27 TPI, and the pin numbering pattern is correct. All that I have from the manufacturer is a list of what each pin does by number, and I checked the functions that it lists with my voltmeter. I’ll order one and see how it fits. |
1754-1092-ND不合适。
螺母上的螺纹不匹配。 我有更多的工具来检查螺纹,它有1毫米的螺距,所以它绝对是一个公制螺纹。 外插座位于连接器上7mm圆的中心; 我的设备上的针脚以9毫米圆圈为中心。 如果制造商在其数据表上放置更多尺寸信息而不依赖于您知道现有连接器符合的规格,那么找到这种连接器的配合部件要容易得多。 以上来自于谷歌翻译 以下为原文 The 1754-1092-ND did not fit.
It would be much easier to find mating parts for connectors of this sort if manufacturers put more dimensional information on their datasheets instead of relying on you to know what spec your existing connectors met. |
我查看了系统中所有键控8位置连接器,遗憾的是我无法找到与您所拥有的连接器相匹配的连接器。
我发现的大多数也有7毫米直径。 以上来自于谷歌翻译 以下为原文 I reviewed all of the keyed 8 position connectors in our system, and unfortunately am not able to find a match to the one that you have. Most of the ones that I found also had the 7mm diameter. |
只有小组成员才能发言,加入小组>>
3448 浏览 3 评论
469浏览 1评论
GMT+8, 2024-11-22 13:13 , Processed in 0.812156 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
