电子发烧友论坛|
我们正在使用一款 中频子系统芯片 AD9864,
现在已经可以从 SSI 数据输出接口读取到 IQ 数据. 但是调试的时候遇到个问题: 不知道如何根据芯片 SSI 接口输出的 ATT 和 RSSI 数值,计算输入到 AD9864 入口处的实际信号功率大小. 器件手册里描述的不是很明白,也没有给出计算公式之类的. 请问 ATT 数值和 RSSI 数值是需要换算成 dB 的?如何换算? 谢谢! |
1个回答
您好!
对于RSSI的计算,产品线工程师解释如下,供您参考。 The RSSI is a coarse "linear detector" that measure the ABS(I)+ABS(Q) value of the input signal has shown in figure 58. It is typically used in conjunction with the AGC since its output is compared to the programmable level set in the AGCR field. The RSSI is a 6-bit field (when enabled) in the SSI output data with a value of 60 corresponding to a 0 dBFS sinewave input at IF center ( and -6 dBFS corresponding to a a value of 30). If the VGA setting is known than it is possible to calculate the real power from the IQ output (within digital pas***and with higher accuracy) or the RSSI field (wider band with lower accuracy due to 6-bit linear resolution). For example, if its setting was set to 0 dB (i.e. ONLY VGA Enabled in figure 59) than a -32 dBm input signal will result in a -2 dBFS level (defined as IF "clip point") on the I/Q output. Hence 0 dBFS = -30 dBm is my reference point. If the signal generator was reduced by 4 dB to -36 dBm. I would expect the RSSI field to read closer to 30 since this corresponds to -6 dBFS). Note that the freqency offset from the IF center also introduces an additional error as shown in figure 60. Again, the RSSI function is typically used in conjunction with the AGC and only provides a coarse estimate of the signal power over the extended freq range of the 1st stage Dec-12 filter. |
只有小组成员才能发言,加入小组>>
寻求ADF5355类似的微波源,在DC-15GHz内,锁频时间在1ms内
1788 浏览 0 评论
1630 浏览 0 评论
999 浏览 0 评论
1100 浏览 0 评论
ADF5355失锁: 在用ADF5355进行多次扫频时,延时给了500ms还是经常会失锁
1189 浏览 0 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
2845浏览 3评论
2087浏览 2评论
给ADUM4223 增加信号驱动15V电压就不正常, 波动很大会被烧是什么情况?
2120浏览 2评论
1174浏览 2评论
使用ADI官方提供的no-OS來接收GPS L1(1575.42MHz)的資料
1405浏览 1评论
/9
GMT+8, 2025-12-2 09:18 , Processed in 0.684992 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2090
