我们正在进行以太网数据测试,因此需要触发10BaseT,100BaseT,1000BaseT以太网“数据”。
当我说“数据”时,我指的是以太网数据包或数据流的区域,实际数据(有效载荷)所在的区域......我们唯一明显的能力是在以太网(物理层)信号的开头触发。 我们需要能够深入钻取数据包,并识别或选择(即“触发”)数据(有效载荷)区域(即绕过所有前同步码,源/目标寻址,以及所有其他“ 预数据“数据流的区域。不太熟悉协议分析器,但即便如此,我认为我们需要示波器功能,因为我们正在处理物理层...思考?我们有什么选择?谢谢, Joe Cianchetta 以上来自于谷歌翻译 以下为原文 We are doing ethernet data testing and thus have a need to trigger off of 10BaseT, 100BaseT, 1000BaseT ethernet "data". When I say "data", I mean the area of the ethernet packet or data stream, where the actual data (payload) resides... our only apparent capability is to trigger at the beginning of the ethernet (physical layer) signal. We need to be able to go drill deep into the packet, and identify or select (i.e. "trigger off of") the data (payload) area (i.e. bypass all of the pre-amble, source / destination addressing, and all other "pre-data" areas of the data stream. Not too familiar with protocol analyzers but even so, I'm thinking we need oscilloscope capabilities, since we are dealing with the Physical Layer... Thoughts? What are our options? Thank you, Joe Cianchetta |
1个回答
你没有提到你正在使用的范围,所以这有点难以回答。
更难的是10BaseT,100BaseT和1000BaseT彼此非常不同。 对于10BaseT和100BaseT,在Infiniium Scopes上,您可以使用N8825A / B Infiniium 10BASE-T / 100BASE-TX以太网解码器。 我认为它没有Payload触发,但它对你有用。 我不知道基于范围的1000BaseT解决方案。 IIRC,1000BaseT使用所有4对并在成对中传播数据。 这可能会妨碍使用范围。 也许将一个专用的以太网协议分析仪与硬件触发输出相结合,连接到示波器的触发输入,可以满足您的需求。 示波器可以提供一些解码,但也可以提供以太网信号的物理层。 人 以上来自于谷歌翻译 以下为原文 You don't mention which scope you are using, so this is a little tough to answer. What makes it tougher is that 10BaseT, 100BaseT, and 1000BaseT are very different from each other. For 10BaseT and 100BaseT, on Infiniium Scopes, you might be able to use the N8825A/B Infiniium 10BASE-T / 100BASE-TX Ethernet Decoder. I don't think it does Payload triggering, but it usefule to you. I don't know of a scope based solution for 1000BaseT. IIRC, 1000BaseT uses all 4 pairs and spreads that data across the pairs. That might preclude the use of a scope. Maybe a combination of a dedicated Ethernet Protocol Analyzer, with a HW trigger output, connected to the Trigger In of a scope, will give you what you need. The scope can provide some decode, but also the Physical Layer of the Ethernet signal. Al |
只有小组成员才能发言,加入小组>>
2102 浏览 1 评论
1860 浏览 1 评论
1715 浏览 5 评论
2584 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1564 浏览 4 评论
505浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
364浏览 0评论
1413浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
275浏览 0评论
2259浏览 0评论
GMT+8, 2024-4-28 14:55 , Processed in 1.233646 second(s), Total 96, Slave 80 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
