首先,这是我的PCPP链接:https://pcpartpicker.com/list/WMM72R
CPU没有超频。 所以PC是在去年7月左右建立的,12月份主板+ CPU升级。 在12月安装后,PC运行良好。 CPU温度约为30-35℃,游戏温度约为60-65℃,Prime95压力测试约为85-90℃。 然后大约两个月前(大约8月中旬9月初),我注意到在玩Destiny 2时,温度大约在70-80℃之间,并且在玩游戏时偶尔波动。 此时还实现了空转温度约为40-50℃,Prime95为99C +。 整个时间内的环境温度约为20-23℃,PC处于开放区域。 我的风扇配置在前面x3 120mm处,将空气推入AIO,顶部x2 140mm,背面x1 120mm,将空气排出机壳。 环境MB温度是正常的。 决定采取第一条诊断路线,并使用Arctic Silver 5重新涂抹导热膏。重新涂抹,重新安装AIO冷却器,温度完全恢复正常! Idle回到30-35C,Destiny 2在60C运行,Prime95回到85-90C。 然后两周过去了,温度几乎和热膏重新施加前的温度一样高。 我目前有两个工作理论: a。)AIO冷却器泵开始运转,然而,管似乎很好(一个温暖,一个冷却),Link 4软件中的温度并不表示温度比平时更热或泵出现故障。 b。)CPU出现问题,但是,所有电压水平似乎都很好,游戏性能在任何情况下都不会受到影响。 还有什么可能吗? 我只是不明白在TP重新应用之后,两个星期的温度是好的,然后再次高。 我感谢任何帮助,因为这开始令人沮丧。 以上来自于谷歌翻译 以下为原文 First, here's my PCPP link: https://pcpartpicker.com/list/WMM72R CPU is not overclocked. So the PC was built around last July, with the mobo + CPU upgrade in December. Upon installation in December, the PC ran great. CPU temps were ~30-35C idle with a gaming temp of ~60-65C and a Prime95 stress test of around 85-90C. Then about two months ago (roughly mid August beginning of September) I noticed while playing Destiny 2 the temp was around 70-80C and fluctuated sporadically throughout playing the game. Also realized at this time that the idle temp was around 40-50C and Prime95 was 99C+. Ambient temperature during this entire time was around 20-23C and the PC is in an open area. My fan configuration is x3 120mm on the front pushing air into the AIO, and x2 140mm at the top and x1 120mm at the back bringing air out of the case. Ambient MB temp is normal. Decided to take the first diagnosis route and reapply thermal paste, using Arctic Silver 5. Reapplied, re-seated the AIO cooler, and the temps were completely back to normal! Idle was back to 30-35C, Destiny 2 was running at 60C and Prime95 was back to 85-90C. Then two weeks have passed, and the temperatures are almost running as hot as before the thermal paste reapplication. I currently have two working theories: a.) AIO cooler pump is starting to go, however, the tubes seem to be fine (one wARM, one cool) and the temperature in the Link 4 software does not indicate that the temp is hotter than usual or the pump is malfunctioning. b.) Something is wrong with the CPU, however, all voltage levels seem fine and game performance is not affected during any of this. Is there anything else it could possibly be? I just don't understand how after TP reapplication, the temps were fine for two weeks and then they were high again. I appreciate any help, as this is starting to be frustrating. |
1个回答
HelloAJ5L1CK,感谢您加入此英特尔社区。根据https://ark.intel.com/,您的英特尔®酷睿™i7-8700K处理器符合规格。
这意味着报告的温度不应损坏系统中的处理器或其他组件。 请记住,处理器能够在压力测试或游戏过程中产生相当多的热量。 因为您正在运行要求苛刻的游戏和应用程序,所以这种行为是可以预期的。现在,即使大多数第三方应用程序相当准确地报告处理器温度,我们也建议使用我们的英特尔®处理器诊断工具来报告处理器的准确温度。英特尔® Processor Diagnostic ToolWanner G.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello AJ5L1CK, Thank you for joining this Intel Community. According to https://ark.intel.com/, your Intel® Core™ i7-8700K Processor is running within specifications. This means that the temperature reported should not damage the processor or other components in your system. Keep in mind that the processor is capable of generating a fair amount of heat during stress tests or gaming sessions. Because you are running demanding games and applications, this behavior is expected. Now, even though most third-party applications report the processor temperature fairly accurately, we also recommend using our Intel® Processor Diagnostic Tool to report accurate temperature for your processor. Intel® Processor Diagnostic Tool Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-19 14:14 , Processed in 1.036711 second(s), Total 74, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
