电子发烧友论坛|
安捷伦不久前为infiniivision范围发布了一份真正的兼容打印机清单,但此后它已被此网址上的一揽子声明所取代:[http://www.keysight.com/main/editorial.jspx?cc=US&
; lc = eng& ckey = 1379987]我有一台没有窗户的MSO-X-3104A,对打印机非常挑剔。 并非所有PCL5打印机都能正常工作 许多彩色打印机只能打印B& W. 该名单现已消失。 谁能为我提供清单? 谢谢,杰森K. 以上来自于谷歌翻译 以下为原文 Agilent had not long ago posted a real list of compatible printers for the infiniivision scopes but it has since been replaced by the blanket statement at this URL: [http://www.keysight.com/main/edi ... ng&ckey=1379987] I have a MSO-X-3104A that does not have windows and is very fussy about printers. Not all PCL5 printers work. Many color printers will only print B&W. The list is now gone. Can anyone supply the list for me? Thanks, Jason K |
2个回答
我不确定,但我会问。
我知道会做出这个决定的人,我怀疑答案是这样的:从以下情况开始:1)经过测试的打印机数量远远小于可用打印机的数量,2)打印机被淘汰,或者去 制造商很快就会“失去支持”,3)还有其他方法可以获取可打印信息,例如超出范围的屏幕截图和打印页面,4)绝大多数经过测试的PCL3和PCL5打印机运行良好, 如果不是很完美,5)每个打印机的每个打印机都有相当大的时间和金钱成本,6)这些资源是有限的,可以更好地用于开发新的范围,或者为现有的范围添加新功能,决定 是为了停止测试打印机,并提供现在可在网上获得的一揽子声明。 它不是一个完美的解决方案,我们道歉,但它似乎对大多数用户和大多数情况最有意义。 人 以上来自于谷歌翻译 以下为原文 I don't know for sure, but I will ask. I know the folks who would have made this decision, and I suspect that the answer will be something like this: Since: 1) The number of tested printers is much smaller than the number of available printers, 2) Printers get obsoleted, or go 'out of support' by the manufacturer, very quickly, 3) There are other means for getting printable information, such as screenshots out of the scope and onto the printed page, 4) The vast majority of tested PCL3 and PCL5 printers worked well, if not perfectly, 5) There's a considerable cost in time and money acquiring and testing each printer with each scope, 6) Those resources are limited, and would be better spent in developing new scopes, or adding new features to existing scopes, a decision was made to stop testing printers, and provide the blanket statement that's now available on the web. It is not a perfect solution, and we apologize, but it seemed to make the most sense for most users and in most situations. Al |
我们没有任何“认证程序”来生成已批准的兼容打印机列表。
正如您发现的声明所说,我们努力为PCL3 / 5打印机提供一般支持。 因为每个供应商和打印机都有自己特殊的奖励行为,YMMV。 如果您还没有,请尝试更新到最新固件 - 我们会定期对PCL驱动程序进行兼容性更新。 如果您使用的是最新固件,但仍有不合作的打印机,请向我们提供这些打印机的列表。 过去,我们已在内部订购此类打印机以调试兼容性问题。 谢谢, - 克里斯 以上来自于谷歌翻译 以下为原文 We don't have any sort of "certification program" to generate a list of approved, compatible printers. As the statement you found says, we strive to generically support PCL3/5 printers. Because each vendor and printer has its own special bonus behaviors, YMMV. If you haven't already, please try updating to the latest firmware - we periodically make compatibility updates to the PCL driver. If you're on the latest firmware and still have printer(s) that won't cooperate, please provide us with a list of those printers. In the past we have ordered such printers in-house to debug compatibility issues. Thanks, --Chris |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 20:24 , Processed in 0.783316 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1088
