我的VEE程序运行一些测试,然后打开一个空白的Word文档,添加标题信息,matlab图形,段落文本等。
一切都相当简单。 然后,我想创建一个空白表,将其插入当前插入点(即光标所在的位置),然后将列标题和结果加载到表中。 我可以创建一个包含所选行数/列数的表,但插入点取决于一个'Range'变量,如果我为它组成值,我只能使用它 - 如果前面的内容它会在错误的位置结束 长度不一。 至于向单元格添加文本:一切都以单元格(1,1)结束,或者我得到无用的.NET错误消息。 E.G.,在截图中,一个问题是Sel.MoveRight~交易。 任何的建议都受欢迎。 问候,凯文 以上来自于谷歌翻译 以下为原文 My VEE program runs some tests then opens a blank Word doc., adds title info, Matlab graphs, paragraph text etc.etc. all fairly straightforward. I then want to create a blank table, insert it at the current insertion point (i.e. where the cursor is) then load column headings and results into the table. I can create a table with chosen number of rows/columns but the insertion point depends on a 'Range' variable which I can only get to work if I make up the value for it - then it ends up in the wrong place if preceding content varies in length. As for adding text to cells: everything ends up in cell (1,1) or I get unhelpful .NET error messages. E.G., in the screenshot, one problem is the Sel.MoveRight~ transaction. Any advice would be welcome. Regards, Kevin 附件
4个回答
凯文,而不是从空白文档开始,尝试使用包含图表的文档和其他已经存在的位置。
此模板文件将消除程序中的大量代码。 要获取所需的文本,可能必须在单词doc中创建命名字段。 然后在VEE中写入这些字段名称。 这可能是最简单的方式。 -法案 以上来自于谷歌翻译 以下为原文 Kevin, Instead of starting with a blank document, try using a document that has the chart and other things already in place where you want. This template file will eliminate a lot of code from your program. To get the text where you want you might have to create named fields in the word doc. Then in VEE just write to those field names. That is probably the easist way. -Bill |
derek88 发表于 2018-10-10 18:51 嗨,谢谢你的建议; 我考虑过创建一个模板,但是表格会有不同的行数(虽然是固定的列数)所以我将不得不尝试内联插入以确保它可以将所有内容都推下来而不会覆盖... Rgds,Kevin 以上来自于谷歌翻译 以下为原文 Hi, Thanks for the advice; I had considered creating a template but the table(s) will have a varying number of rows (though fixed column count) so I'll have to experiment with inline insertion to make sure it pushes everything down without overwriting... Rgds, Kevin |
以下是此问题的解决方案。
由于我刚刚粘贴了U.F.所附程序将无法运行。 进入一个空白的VEE文件。 但是你将能够查看所有......(WORD)公式框,看看如何从正文模式进入表格模式 - 创建表格,在其单元格中移动,输入数据 - 然后切换回正文 文字模式。 以上来自于谷歌翻译 以下为原文 Here is a solution to this issue. The attached program won't run as I've just pasted the U.F. into a blank VEE file. But you'll be able to look at all of the ...(WORD) formula boxes to see how to go from body text mode to table mode - creating the table, moving around its cells, entering data - then switching back to body text mode. 附件
凉。 感谢分享,它可能会派上用场。 -法案 以上来自于谷歌翻译 以下为原文 Cool. Thanks for sharing that, it might come in handy. -Bill |
只有小组成员才能发言,加入小组>>
2106 浏览 1 评论
1867 浏览 1 评论
1722 浏览 5 评论
2590 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1567 浏览 4 评论
511浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
368浏览 0评论
1424浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
281浏览 0评论
2263浏览 0评论
GMT+8, 2024-5-6 00:04 , Processed in 1.163281 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
