扫一扫,分享给好友
安装环境:matlab 2017B 中文版本
MATPOWER 6.0 按照要求将MATPOWER6.0的解压包放在tool box下面相对应的路径里面,安装后输入命令:test_matpower 报错如下信息: t_test_fcns.............ok t_nested_struct_copy....ok t_feval_w_path..........not ok ##### Ran 20 of 20 tests: 19 passed, 1 failed t_mpoption..............ok t_loadcase..............警告: You have $MATPOWER/t/t_loadcase in your path. In general your path should not include sub-directories of $MATPOWER/t. While harmless, it does prevent this test from verifying the ability to load m-file cases that are outside your path. > In t_loadcase (line 561) In t_run_tests (line 58) In test_matpower (line 128) ok t_ext2int2ext...........ok t_jacobian..............ok t_hessian...............ok t_margcost..............ok t_totcost...............ok t_modcost...............ok t_hasPQcap..............ok t_mplinsolve............ok (2 of 4 skipped) t_mips..................ok t_qps_matpower..........ok (252 of 360 skipped) t_miqps_matpower........ok (226 of 240 skipped) t_pf....................ok t_cpf...................ok t_islands...............ok t_opf_model.............ok t_opf_fmincon...........ok t_opf_mips..............ok (125 of 250 skipped) t_opf_mips_sc...........ok (125 of 250 skipped) t_opf_dc_mips...........ok t_opf_dc_mips_sc........ok t_opf_dc_ot.............ok t_opf_userfcns..........> In mplinsolve (line 49) In mips (line 457) In qps_mips (line 180) In qps_matpower (line 252) In dcopf_solver (line 164) In opf_execute (line 50) In opf (line 204) In runopf (line 75) In rundcopf (line 73) In t_opf_userfcns (line 85) In t_run_tests (line 58) In test_matpower (line 128) 警告: 矩阵接近奇异值,或者缩放错误。结果可能不准确。RCOND = 1.087361e-16。 ok t_opf_softlims..........> In mplinsolve (line 49) In mips (line 457) In qps_mips (line 180) In qps_matpower (line 252) In dcopf_solver (line 164) In opf_execute (line 50) In opf (line 204) In runopf (line 75) In t_opf_softlims (line 77) In t_run_tests (line 58) In test_matpower (line 128) 警告: 矩阵接近奇异值,或者缩放错误。结果可能不准确。RCOND = 1.765365e-17。 > In mplinsolve (line 49) In mips (line 457) In qps_mips (line 180) In qps_matpower (line 252) In dcopf_solver (line 164) In opf_execute (line 50) In opf (line 204) In runopf (line 75) In t_opf_softlims (line 77) In t_run_tests (line 58) In test_matpower (line 128) 警告: 矩阵接近奇异值,或者缩放错误。结果可能不准确。RCOND = 1.765365e-18。 错误使用 loadcase (line 225) loadcase: syntax error or undefined data matrix(ices) in the file 错误使用 feval 未定义函数或变量 'softlims_savecase_test_48860897'。 出错 t_opf_softlims (line 92) mpc1 = loadcase(fn); 出错 t_run_tests (line 58) feval( test_names{k}, ~verbose ); 出错 test_matpower (line 128) t_run_tests( tests, verbose ); |
2个回答
说明文档里有的,你的matpower换一个安装目录。不要带matlab
刚试过了,你的安装目录里换一个根目录,不要带matlab。这个在说明手册里有的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
我用matlab的coder 封装了一个c语言的dll, 但是在用labview调用时,会出现识别不到库的问题,有大神遇到过吗
3962 浏览 0 评论
5419 浏览 0 评论
在matlab中如何计算含有第一类修正的贝塞尔函数的积分算不出的问题?
9225 浏览 0 评论
怎么利用matlab得到95%,80%和70%的置信区间,并生成不同区间下的功率误差贝塔分布?
10666 浏览 0 评论
请问simulink的s-function模块如何添加多输入输出接口
14886 浏览 2 评论
/9
GMT+8, 2025-12-9 06:59 , Processed in 0.614598 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4161
