电子发烧友论坛|
我试图在MICROStiCK II板上调试一个DSPIC33 EV256GM00 2设备,由于某些原因,MICRODSICK的调试器选项在硬件工具屏幕中不可用。事实上,在启动工具包上没有任何可用的东西。我需要安装驱动软件吗?
以上来自于百度翻译 以下为原文 I am trying to debug a dsPIC33EV256GM002 device on a Microstick II board and for some reason the debugger option for Microstick is not available in the Hardware Tools screen. In fact nothing under starter kits shows up available. Is there driver software that I need to install? |
6个回答
HiMeMcTICK II应该在“调试工具”下显示为PKOB(PACKIT ON)设备。只要将它连接到PC并检查项目属性下可用的调试工具,您就应该看到PKOB,接着是您的MICROSTICK(Bur..…)的序列号。我在Wi7 64 Pro下使用了它。在没有任何问题的情况下赢取10 64 PRO。当你把它连接到PC时,检查你是否听到“锣”。如果你不能用你的操作系统的USB驱动程序来解决问题,而不是用MPLABX。PKOB设备,像PICTIT3,只需要通用的HID驱动程序,比如键盘或鼠标,有N个。编辑Ad:你可以通过查看硬件管理器检查你的司机是否正常,一旦连接到MICROSTICK就应该显示出来。
以上来自于百度翻译 以下为原文 Hi The microctick II should show up under "debug tools" as a PKOB (pickit on board) device. Just connect it to the PC and check out the available debug tools under project properties, you should see a PKOB followed by the serial number of your Microstick (BUR.....). I've used it both under Win7 64 Pro and Win 10 64 pro without any issues. Just check if you cn hear the "gong" when you connect it to the PC. If you can't than you have aproblem with the USB drivers of your OS, not with MPLabX. The PKOB devices, like the Pickit3, only need generic HID drivers like the keyboard or the mouse, there is nothing special about. EDIT ADD: You can check if your drivers are ok just by looking to the hardware manager, once connected the the Microstick should show up there. HIH Best regards Jorge |
谢谢你的回复。是的,当MICROSTICK II板***入时,在硬件工具菜单上,一个新条目弹出右下方的“起动器工具”,但是它是灰色的,我不能选择这个选项。我试过了所有的东西,但我不能选择。这是有趣的,因为在屏幕上的名称被称为“MICROSTICK II S…”的名称显示不完全出于某种原因。有没有办法重新安装驱动程序的MICROSTICK II在我的Windows 7 PC?
以上来自于百度翻译 以下为原文 Thanks for the reply. Yes when the microstick II board is plugged in, on the hardware Tools menu a new entry pops up right below "starter tools", however it is greyed out and I cannot select the option. I have tried everything but I cannot select this. It is funny because on the screen the name is called "Microstick II S..." - the name shows up incomplete for some reason. Is there a way to reinstall drivers for the microstick II on my Windows 7 PC? |
Hiu可以尝试设备管理器。用MICROSTICK连接到“设备管理器”和unnistalMICROSTICK。然后断开连接并重新连接。您也可以简单地尝试“更新驱动程序”。用MPLAB X关闭这个按钮,这样当您刷新T时,它不会尝试扫描USB设备。他是司机。
以上来自于百度翻译 以下为原文 Hi You can try the device manager. With the Microstick connected go to the "device manager" and unnistal the Microstick. Then disconnect it and reconnect again. You can also simply try to "update drivers". Try this with MPLAb X closed, so it doesn't try to scan the USB devices while you are refreshing the drivers. HIH Best regards Jorge |
嗨,我看到了类似于PIC32 mm的东西,MICROSTICK II不可用作硬件工具。MPLAB X有一个表格被放在.jar文件中,列出哪些设备应该有黄色或绿色的点,作为程序员和调试器。使MICROSTICK成为所有PIDIT 3.0处理的设备的调试工具,但我无法找到线程。迈西尔
以上来自于百度翻译 以下为原文 Hi, I have seen something similar with PIC32MM, with Microstick II not available as hardware tool. MPLAB X have a table tucked away in a .jar file, listing which devices shall have yellow or green dots presented for Microstick PKOB, as programmer and debugger. There was a thread with advise about how to Enable Microstick as debugging tool for all devices handled by PICkit 3. but I cannot locate the thread. Mysil |
嗨,问题很可能是MICROSTICK II不支持DSPIC33 EV256GM00 2(它只支持某一组PIC/DSPIC)。事实上它只支持3.3V设备:http://www. McCux.com……ARTNONO=DD3300 13-2,以验证MICROTICK II被MPLAB X V4.15正确识别,很容易:1插入MICROSTICK II中的一个PIC/DSPIC,它是用IT2/创建一个项目3/你现在应该看到MICROSTICK II工具出现的绿色或黄色作为可能的工具,这意味着你可以选择它,特别是PICHONE,我喜欢16位28引脚启动器板(DM30)0027):http://www. McCys.com…….S.ASPX?它有几个优点:1 /它操作3.3V或5V(可选)2 /它几乎没有硬件(大多数引脚可用)3 /它既有ICSP又有RJ11连接器。
以上来自于百度翻译 以下为原文 Hi, the issue is most probably that Microstick II does not support dsPIC33EV256GM002 (it supports only a certain set of PIC / dsPIC ). In fact it support ONLY 3.3V devices : http://www.microchip.com/...artno=dm330013-2 To verify that Microstick II is properly recognized by MPLAB X v4.15, it is easy : 1/ Plug into the Microstick II one of the PIC / dsPIC that was shipped with it 2/ Create a project 3/ You should now see Microstick II tool appearing with green or yellow as possible tool which means that you can select it with that particular PIC Personally I like the 16-Bit 28-Pin Starter Board ( DM300027 ) : http://www.microchip.com/...s.aspx?PartNO=DM300027 It has several advantages : 1/ it operates either with 3.3V or 5V (selectable) 2/ it has almost no harware (most pins are available) 3/ it has both ICSP AND RJ11 connectors Regards |
好的,你有答案!显然MICROSTICK II不喜欢5伏设备,一旦我放入一个DSPIC33 FJ设备,调试器现在就可以在HARDUS工具下拉上选择,我可以运行和单步代码没有问题。我会听取您的建议并订购28针起动器板,因为我已经有PI了。CKIT-3程序员,感谢所有参与进来的人!
以上来自于百度翻译 以下为原文 Ok RISC you had the answer! Apparently the Microstick II does not like 5 volt devices, as soon as I put in a dsPIC33FJ device the debugger now was select-able on the Harware Tools dropdown and I am able to run and single-step code no problem. I will take your advice and order the 28-pin starter board, since I already have a Pickit-3 programmer. Thanks to all who chimed in to assist! |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:28 , Processed in 0.899514 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1622
