电子发烧友论坛|
我的PIC32板包括2个LED。它们在引脚RB2和RB3上。它们与一个Pulp-电阻连接到VCC。现在我有一个问题编程它们。如果我使用端口寄存器,它们的行为非常怪异。PoBBITS.RB2=0;//这打开了.BoBBITS.RB3=0;//这打开了.PoBBITS.RB2=1;//这关闭了LeD1,但同时打开了Le2.PoBBITBES.RB3=1;//这关闭了Del2,但同时打开了LeD1。使用PORTBSET或PORTBCR寄存器。但是,使用锁存器等效物,一切都如预期的那样工作。数据表状态:对端口寄存器的写入实际上与写入LAT寄存器相同。对我来说这是没有意义的。
以上来自于百度翻译 以下为原文 My PIC32 board includes 2 LEDs. They are on pins RB2 and RB3. They are tied to VCC with a pullup-resistor. Now I have a problem programming them. If I use the PORT registers they behave very weird. PORTBbits.RB2 = 0; // This turns on BOTH. PORTBbits.RB3 = 0; // This turns on BOTH. PORTBbits.RB2 = 1; // This turns off LED1, but at the same time turns on LED2. PORTBbits.RB3 = 1; // This turns off LED2, but at the same time turns on LED1. Same if I use PORTBSET or PORTBCLR registers. But with the LATCH equivalents everything works as expected. The datasheet states: • A write to a PORT register is the effectively the same as a write to a LAT register. It doesn't make sense to me... |
3个回答
你所观察到的和预期的一样。当它说“写一个端口寄存器”时,它意味着写入整个寄存器,而不是写入一个单独的比特。即PORTB= 0x1234;相同的TelATB= 0x1234;但是,通过PoBBIT结构写入单个位不是一个简单的写。它有效地读取端口,修改一个位,然后重写整个寄存器。这意味着,如果读取的值与Labb寄存器中的值不一样,则除了目标位以外的位可以改变。
以上来自于百度翻译 以下为原文 What you observe is exactly as expected. When it says "A write to a PORT register", it means writing to the WHOLE register, not to an individual bit. i.e. PORTB = 0x1234; is identical to LATB = 0x1234; but, writing to a single bit via the PORTBbits structure is NOT a simple write. It effectively reads the port, modifies one bit, then rewrites the whole register. The implication of this is that if the value read is not the same as what is in the LATB register, then bits other than the target bit can change. |
谢谢。这对我来说还不清楚,但是,PurtBeSt和PotobCr寄存器呢?如果我理解正确,这些只会影响给定的比特,但是下面的命令也会影响两个LED:PoBbCr=4;PORTBCLR=8;PORTBSET=4;
以上来自于百度翻译 以下为原文 Thanks. This wasn't clear to me. But then, what about the PORTBSET and PORTBCLR registers? These should only affect the given bits, if I understand correctly. But the following commands also affect both LEDs: PORTBCLR = 4; PORTBCLR = 8; PORTBSET = 4; PORTBSET = 8; |
在内部,PIC仍在进行我所描述的读/修改/写操作。解决方案很简单。总是使用LAT寄存器来改变PIN STATUS。只在实际读取输入PIN的状态时才使用端口寄存器。
以上来自于百度翻译 以下为原文 Internally, the PIC is still doing the read/modify/write operation I described. The solution is easy. ALWAYS use the LAT register to change pin status. ONLY use the PORT register when you actually want to read the state of an input pin. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 22:03 , Processed in 1.022126 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3714
