问候语!我试图通过USB连接PIC32 MX470F512H到PC。我使用的是USB CDC和声库,我的项目是基于CDC*COMLPORTA的一个例子。问题是我的联系不稳定。当我打开PCB时,我的PC找到了设备并安装了驱动程序。在30到40秒内一切都很好,之后PC显示了设备管理器对USB设备的一个感叹号。它说“设备不能启动(代码10)”。如果我重新连接设备,错误就会留下。我必须为PCB解除1530分钟的电源,所以PCB再次发现只有30到40秒才正确。我想我有一个硬件问题。这里是我的连接:VUSB3V3(引脚35)和Vu***(引脚34)都连接到PCB VCC(3,3V)。GND & GT;USB端口PIN 4D+-GT;USB PIN 3D -GT;USB PIN 2USB引脚1。怎么回事?谢谢!
以上来自于百度翻译 以下为原文 Greetings! I`m trying to connect PIC32MX470F512H to PC through USB. I`m using USB CDC HARMony library and my project is based on cdc_com_port_single example. The problem is my connection is unstable. When I turn on the PCB, my PC finds the device and installs the driver. Everything is fine for about 30-40s and after that the PC shows a exclamation mark in the device manager right to the USB device. It says "device cannot start(code 10)". If I reconnect the device the error stays. I have to unpower the PCB for 15-30min so the PCB to be found correct again only for 30-40s. I think I have a hardware problem. Here are my connections: Vu***3v3(PIN 35) and Vu***(PIN 34) are both connected to PCB Vcc(3,3V). GND->USB port PIN 4 D+ -> USB PIN 3 D- -> USB PIN 2 USB PIN 1 -> unconnected Any ideas what`s going on?! Thanks! |
6个回答
嗨,CDC USB设备和谐项目与USB初学者工具包III很好。检查USB起动器工具包III的示意图对您的板。示意图在初学者工具包用户手册中。使用一个现成的项目为USB初学者工具包III,只需将其适应您的硬件,如果需要。
以上来自于百度翻译 以下为原文 Hi, The CDC USB device Harmony projects works well with USB starter kit III. Check the schematics of the USB starter kit III against your board. Schematics are in the starter kit user manual. Use a ready made project for USB starter kit III and just adapt it to your hardware if necessary. Regards |
VBUS(PIN 34)是否需要连接到5V的USB +VE线路(引脚1)?
以上来自于百度翻译 以下为原文 Doesn't the Vbus (Pin 34) need to be connected to the 5v USB +ve line (pin 1)? |
我要试试看!我在看初学者工具包的原理图,但是UC有点不同,这让我感到困惑。我明天试着把VUSB连接到PC PIN 1!
以上来自于百度翻译 以下为原文 I`m going to try it! I`m watching the starter kit schematics, but uC is little bit different and this confuses me. I`ll try tomorrow to connect Vu*** to PC Pin 1! |
首先检查数据表,但我似乎记得VBUS是检测到USB是上升,所以需要看到5V
以上来自于百度翻译 以下为原文 Check the data sheet first but I seem to recall the Vbus is to sense the USB is up, so needs to see 5v |
我已经连接了USB端口的PIN 1到PIN 34 VUSB -没有变化!我对PIN 35 VASB3V3感到困惑。数据表上说这是ISUSB内部收发器的电源。如果没有使用USB模块,这个引脚必须连接到VDD(第24页)。如果我用这个别针,我该怎么办?让它没有联系吗?
以上来自于百度翻译 以下为原文 I`ve connected PIN 1 of the u*** port to PIN 34 Vu*** - no change! I`m confused about PIN 35 Vu***3v3. The datasheet says this is USB internal transceiver supply. And If the USB module is NOT used, this pin must be connected to VDD(page 24). So if I`m using this pin what should I do? Leave it unconnected? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5794 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1125浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 16:05 , Processed in 1.232157 second(s), Total 87, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1941
