电子发烧友论坛|
您好,我们正在使用示波器5032,并有一些发送SCPI命令的工作程序。
现在我们切换到3032示波器,它在触发时表现不同。 以下是以前使用的命令:* RST:CHAN1:SCAL 5V; OFFS -4; COUP DC; IMP ONEMeg; DISP 1; BWL 1; INV 0; UNIT VOLT; PROB 1; :tiM:MODE MAIN; SCALE 0.01; REF LEFT; POS 0; :STOP:TRIGger:SWEep AUTO:SINGLE问题是: - >发送SINGLE命令后,5032-scope执行新的扫描。 - >新的3032确实.....没有.....我必须使用“新”ForceTrigger吗? 此外,当我手动按下5032仪器上的单键时,扫描开始。 并没有扫除3032 ??? 在3032有什么新东西丢失了吗? 谢谢BR TM 以上来自于谷歌翻译 以下为原文 Hello, we are using the oscilloscope 5032 and have some working programs that send SCPI-commands. Now we switched to the 3032 oscilloscope which behaves different at triggering. Here are the commands that used to work: *RST :CHAN1:SCAL 5V;OFFS -4;COUP DC;IMP ONEMeg;DISP 1;BWL 1;INV 0;UNIT VOLT;PROB 1; :TIM:MODE MAIN;SCALE 0.01;REF LEFT;POS 0; :STOP :TRIGger:SWEep AUTO :SINGLE The problem is: -> The 5032-scope executes a new sweep after i send the SINGLE-command. -> The new 3032 does..... nothing..... Do i have to use the "new" ForceTrigger? Also when i manually press the single-button at the 5032 instrument the sweep is starting. And it does not sweep on the 3032??? Is there something new at 3032 that is missing? Thanks BR TM |
2个回答
确切地说:在较新的X型号上,SINGLE始终使用NORMAL触发扫描。
如上所述,您可以使用FORCE,但是,如果为旧版本编写代码,它们没有FORCE,所以我将触发器设置为LINE ... 以上来自于谷歌翻译 以下为原文 Exactly: on the newer X models, SINGLE always uses NORMAL trigger sweep. As noted, you can use FORCE, but, if writing code for the older ones, they don't have FORCE, so I set the trigger to LINE... |
ncmza 发表于 2018-9-25 06:53 嗨,ksmith,好主意。 这意味着我只需要在LINE上添加命令触发并保持NORM(因为更改为AUTO没有效果)。 然后SINGLE应该再次工作。 正确? * RST:CHAN1:SCAL 5V; OFFS -4; COUP DC; IMP ONEMeg; DISP 1; BWL 1; INV 0; UNIT VOLT; PROB 1; :TIM:MODE MAIN; SCALE 0.01; REF LEFT; POS 0; :STOP:TRIGger:SOURce LINE; :TRIGger:SWEep NORM:SINGLE Thx 以上来自于谷歌翻译 以下为原文 Hi ksmith, good idea. That means i only have to add the command to trigger on LINE and stay on NORM (as changing to AUTO does not have an effect). Then the SINGLE should work again. Correct? *RST :CHAN1:SCAL 5V;OFFS -4;COUP DC;IMP ONEMeg;DISP 1;BWL 1;INV 0;UNIT VOLT;PROB 1; :TIM:MODE MAIN;SCALE 0.01;REF LEFT;POS 0; :STOP :TRIGger:SOURce LINE; :TRIGger:SWEep NORM :SINGLE Thx |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:37 , Processed in 0.588873 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1501
