你好
我正在尝试在CentOS 7.x上安装GRID 6.0,但除了安装版本7.4之外没有任何运气。 7.4的问题在于它目前不支持Citrix,所以我需要使用早期版本,理想情况是7.3。 我坚持的位是“内核源文件”部分(见附件)。 我可以通过运行“yum update”来解决这个问题,但问题在于它将整个操作系统升级到版本7.4,它修复了GRID安装,但破坏了Citrix。 如果有人可以建议如何解决这个问题,将不胜感激 谢谢 本 以上来自于谷歌翻译 以下为原文 Hi I'm trying to install GRID 6.0 on CentOS 7.x, but not having any luck apart from version 7.4, which does install. The problem with 7.4, is that it's not currently supported by Citrix, so I need to use an earlier version, ideally 7.3 at this stage. The bit I'm stuck at is the "Kernel Source Files" part (see attached). I can fix that by running "yum update", but the problem with that is that it upgrades the entire OS to version 7.4, which fixes the GRID install, but breaks Citrix. If anyone can advise how to get around this issue it would be much appreciated Thanks Ben |
1个回答
为什么一旦你在公共论坛上发布内容,你就会在几分钟后找出解决方法...
本 以上来自于谷歌翻译 以下为原文 Why is it that as soon as you post something on a public forum, you then work out how to fix it a few minutes later ... Ben |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3125 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3531 浏览 4 评论
GMT+8, 2024-12-22 21:26 , Processed in 0.784010 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
