5个回答
你的问题是想问DFB激光器的激光管的正极接在什么地方么,还是其他问题
cai868 发表于 2018-9-24 13:43 你的问题已经发到了如下链接, 可以在如下链接中查看 https://ez.analog.com/message/215674#215674 |
好的,谢谢。 |
Your selected laser module is in a butterfly package with the laser anode pin connected to the case ground. There are two ways to use this laser module with ADN2871: 1. Connecting the laser module case ground to supply Vcc. This keeps the "positive supply" design and you can use Fig. 29 circuit directly; or 2. Using "negative supply" way to ADN2871 circuitry. In the Fig. 29 circuit, change all external Vccs to new "negative supply" ground, change all external GNDs to -3.3V. Now, you can connect the laser module case to negative supply ground. In this way, you may have to pay attention to the ADN2871 control/monitor signal levels accordingly. Please note, in this case, all these DC levels are referred to -3.3V, not the ground. |
只有小组成员才能发言,加入小组>>
寻求ADF5355类似的微波源,在DC-15GHz内,锁频时间在1ms内
1788 浏览 0 评论
1630 浏览 0 评论
999 浏览 0 评论
1101 浏览 0 评论
ADF5355失锁: 在用ADF5355进行多次扫频时,延时给了500ms还是经常会失锁
1189 浏览 0 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
2845浏览 3评论
2087浏览 2评论
给ADUM4223 增加信号驱动15V电压就不正常, 波动很大会被烧是什么情况?
2120浏览 2评论
1174浏览 2评论
使用ADI官方提供的no-OS來接收GPS L1(1575.42MHz)的資料
1405浏览 1评论
/9
GMT+8, 2025-12-2 16:47 , Processed in 1.774287 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6882
