电子发烧友论坛|
各位大家好,我是这个论坛的新人,我希望能在你的帮助下向你学习。
好吧,我有一个信号发生器HP8648C,序列号为3642U1637,但我的设备有问题。 你们中的任何人都可以建议你从PULSE模式出去做些什么吗? 我在手册中已经读到有必要在后面板PULSE IN连接器上施加TTL高信号。 问题是这个版本没有那个连接器。 我尝试过不同的方式,但没有下过脸。 我希望你能帮助我找到解决方案。 我真的很感激你。 预先感谢您的帮助。 最好的问候Rafael Suarez oa4dma 以上来自于谷歌翻译 以下为原文 Hello everybody, I am new in this forum and I hope I could learn from you with your help. Well, I have got a signal generator HP8648C with serial number 3642U1637 but I have a problem with this equipment. Any of you can me advise what to do for going out from the PULSE mode, please?. I have read in the manual that it is necessary to apply a TTL- high signal to the rear-panel PULSE IN connector. The problem is that this version has not that connector . I tried from different ways but without sucsses. I hope you can help me to find a solution. I will be realy grateful to you. Thank you in advance for your help. Best regards Rafael Suarez oa4dma |
2个回答
脉冲功能是8648C的额外成本选项(约1500美元)。
您的仪器没有连接脉冲的事实无疑意味着它没有配备选件。 以上来自于谷歌翻译 以下为原文 Pulse capability was an extra cost option on the 8648C (approximately 1500 USD). The fact that your instrument does not have the pulse in connector undoubtedly means that it is not equipped with the option. |
您好,非常感谢您的回答xmo。
那么,如果设备没有Pulse选项,这意味着它有另一个问题吗?不是吗? 每次脉冲按钮“RF开/关”出现RF OFF然后PULSE。 那么,是否有一个程序可以从这个出来并获得RF开启? 还有一点,PULSE选项在我更换电池2 / 3A时出现但在此之前我按下发电机的按钮来识别它,RF ON模式正在工作。 在此先感谢您的帮助。 最好的问候rafik oa4dma 以上来自于谷歌翻译 以下为原文 Hello, Thank you very much for your answer xmo. Then, if the equipment does not has Pulse option, this means that it has another problem?, isn´t it? Every time I pulse button "RF on/off" appears RF OFF and then PULSE. So, Is there a procedure to go out from this and get RF ON? Something else, the PULSE option appeared when I changed the battery 2/3A but before that I was pressing buttons of the generator to recognize it, the RF ON mode was working. THanks in advance for your help. Best regards rafik oa4dma |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 13:34 , Processed in 0.706618 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2270
