电子发烧友论坛|
大家好,我想用保护代码编程PIC24F16KL401,以避免任何人读取和复制代码。我的配置位是:首先,它是正确的只是GSS0=作为代码保护?然后,一旦我编程设备,我得到:连接到MPLAB ICD 3…当前加载的固件在ICD 3固件套件版本…01.4818固件类型………DSIC3F/24F/24HTAIL电压检测目标设备PIC24F16KL401找到。设备ID修订= 2设备擦除…编程…以下我MORY区域将被编程:程序存储器:开始地址=0x0,结束地址=0xFFFFraseMebug在程序DEVICOK中失败,我再次设置GSS关闭,我尝试程序/调试,但我总是得到相同的错误消息。怎么了?谢谢。
以上来自于百度翻译 以下为原文 Hi to all, I would like to program PIC24F16KL401 with protected code to avoid anyone could read and duplicate code. My configuration bits are: #pragma config FNOSC = FRC // oscillatore FRC interno #pragma config SOSCSRC = DIG // disabilito oscillatore secondario #pragma config POSCMD = NONE // primary oscillator disabilitato #pragma config OSCIOFNC = ON #pragma config ICS = PGx1 // FPOR #pragma config BOREN = BOR0 // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware; SBOREN bit disabled) #pragma config GSS0 = ON First of all is it correct just GSS0 = ON as code protection? Then, once I program device I got: Connecting to MPLAB ICD 3... Ok, I set GSS OFF again, I try to program/debug but I get always same error message. What's wrong? Thanks. |
1个回答
您好,您的问题不是代码保护。目前您的ICD3程序员不能设法擦除和重新编程PIC。可能有第十个不同的原因发生这种情况。如果你有另一个板,它工作连接你的ICD3到该板。然后再尝试他的新董事会。你能发布你的原理图吗?当做
以上来自于百度翻译 以下为原文 Hi, Your problem is not code protection. Currently your ICD3 programmer cannot manage to erase and reprogram the PIC. There could be tenth of different reasons why this happens. In case you have another board where it works connect your ICD3 to that board. Then try again with his new board. Can you post your schematic ? Regards |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5795 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1125浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 19:49 , Processed in 0.815821 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2333
