根据我的经验,如果你想避免使用旧的工具集……或使用第三方工具,似乎有一个连续的“是的,我们必须修复……在微芯片上的某个时候”的态度;而且情况并没有改善。该死的,我甚至不得不把论坛设置为“移动”模式,甚至登录!点证明…避免“出血边缘”,这样做远不是理想的。缺点是你只能使用“最后几年”的芯片和一些非常“ER”的代码示例,其中许多代码都有自己的错误添加到混合中。连同他们各自的“移动目标”文档(今天在这里,但是明天改变了),至少程序员通常使用芯片,并且任何问题都有更好的文档记录(第三方网站,幸运的发现微芯片上的任何东西,混乱的网页…)你可以习惯于做事情而不改变一切,需要重新学习,无限。熟悉建立了经验,节省了时间。目前的编程硬件似乎完全是基于“出售它然后希望它工作”的思维方式;我唯一的尝试是在Web票响应(PICTIT4不释放12CF部件上的MCLR线),导致建议重复我的HA。我已经试过了……我没有任何进一步的反应。不完全是令人鼓舞的;当我可以购买任何数量的完整的板,从相同的或更少的价格,从其他制造商,直接工作的盒子,并鼓励我使用他们的范围代替…我已经考虑升级。到ICD4,至少试着玩追赶……现在不是地狱中的猫。我还在学习,我永远不能确定这是我的错误还是工具……这是一个不确定性和花费(时间和金钱)。我可以不做。如果Microchip认真出售更多,而不仅仅是购买。更多的公司,他们真的需要行动起来;此刻他们正积极地驱赶客户……你注意到了PIC Micro的网页数量下降了吗?还是那些从他们移动到手臂核心的人?考虑到目前的状态,我不认为这是巧合…或许是他们买下阿特梅尔的主要原因之一。
以上来自于百度翻译
以下为原文
Based on my experience if you want to avoid problems use an older toolset...or two,or use third-party tools;there seems to be a continual 'yeah we must fix that..sometime' attitude at microchip;and the situation isn't improving!
hell,i even had to set the forum to 'mobile' mode to even log in! point proven...
Avoiding 'bleeding-edge' and doing it this way is far from ideal...the downside is you can only use 'last-years' chips and some very,er 'legacy' code examples,many of which have their own bugs to add into the mix. along with their respective 'moving target' documentation (here today but changed/gone tomorrow)
On the plus side at least the programmers generally work with the chips,and any problems are better documented (third party web sites, good luck finding anything on microchips shambolic web pages..) and you can get used to doing things without everything changing and needing to be re-learned all over again,ad infinitum. familiarity builds experience and saves time.
The current programming hardware seems to be entirely based on the 'sell it then hope it works' school of thinking;my one and only attempt at a web-ticket response (PICKit4 not releasing MCLR lines on 12F parts) resulted in the advice to repeat what i had already tried...and i haven't had any further response.
Not exactly encouraging; when i could have bought any number of complete boards for the same,or less, price from other manufacturers,which work straight out of the box; and encourage me to use their range instead...i had considered upgrading to an ICD4 to at least try and play catch-up...not a cat-in-hells chance now.as i'm still learning,i could never be sure if it was my error or the tools...it's an uncertainty and an expense (in both time and money) i can do without.
If microchip are serious about selling more,rather than just buying more companies, they really need to get their act together; at the moment they are positively driving customers away...have you noticed the falling numbers of web pages mentioning PIC micro's? or the ones 'moving on' from them to ARM core? given the current state of play;i don't think it is any coincidence... and perhaps one of the main reasons they bought ATMEL.
