电子发烧友论坛|
Heloi使用PIC32 MX570F512L。我创建了一个使用Hydio2.05.01的引导加载程序。效果很好。但是引导加载程序在程序Flash区域中编程,而对于我的项目,我希望它在引导闪存区域中被编程。我知道要做到这一点,我需要修改我的链接器脚本。既然我是新手,有人能告诉我或者解释需要改变什么。我的Bootloader大小在0x1D00左右。这是由和谐产生的链接器脚本的一部分。您的帮助将不胜感激。
以上来自于百度翻译 以下为原文 hello i'm using PIC32MX570F512L. I've created a bootloader using hARMony 2.05.01. It worked perfectly. but the bootloader is programmed in program flash region and for my project i want it instead to be programmed in the boot flash region. I know that to do this i need to modify my linker script. Since i'm new to this can someone tell me or explain what need to be changed. My bootloader size is around 0x1d00. This is part of linker script generated by harmony. Your help would be appreciated ./************************************************************************* * For interrupt vector handling *************************************************************************/ PROVIDE(_vector_spacing = 0x00000001); _ebase_address = 0x9D000000; /************************************************************************* * Memory Address Equates * _RESET_ADDR -- Reset Vector * _BEV_EXCPT_ADDR -- Boot exception Vector * _DBG_EXCPT_ADDR -- In-circuit Debugging Exception Vector * _DBG_CODE_ADDR -- In-circuit Debug Executive address * _DBG_CODE_SIZE -- In-circuit Debug Executive size * _GEN_EXCPT_ADDR -- General Exception Vector *************************************************************************/ _RESET_ADDR = 0xBFC00000; _BEV_EXCPT_ADDR = (0xBFC00000 + 0x380); _DBG_EXCPT_ADDR = (0xBFC00000 + 0x480); _DBG_CODE_ADDR = 0x9FC00490; _DBG_CODE_SIZE = 0x760; _GEN_EXCPT_ADDR = _ebase_address + 0x180; /************************************************************************* * Memory Regions * * Memory regions without attributes cannot be used for orphaned sections. * Only sections specifically assigned to these regions can be allocated * into these regions. *************************************************************************/ MEMORY { kseg0_program_mem (rx) : ORIGIN = 0x9D000000, LENGTH = 0x2000 /* All C Files will be located here */ kseg0_boot_mem : ORIGIN = 0x9FC00000, LENGTH = 0x0 /* This memory region is dummy */ config3 : ORIGIN = 0xBFC00BF0, LENGTH = 0x4 config2 : ORIGIN = 0xBFC00BF4, LENGTH = 0x4 config1 : ORIGIN = 0xBFC00BF8, LENGTH = 0x4 config0 : ORIGIN = 0xBFC00BFC, LENGTH = 0x4 kseg1_boot_mem : ORIGIN = 0xBFC00000, LENGTH = 0x300 /* C Startup code */ kseg1_data_mem (w!x) : ORIGIN = 0xA0000000, LENGTH = 0x10000 sfrs : ORIGIN = 0xBF800000, LENGTH = 0x100000 debug_exec_mem : ORIGIN = 0x9FC00490, LENGTH = 0x760 configsfrs : ORIGIN = 0xBFC00BF0, LENGTH = 0x10 } |
3个回答
引导闪存太小,不能适合您的引导加载程序。可用空间仅为0x3f0字节。
以上来自于百度翻译 以下为原文 Boot Flash is too small to fit your bootloader. The usable space is only 0x3f0 bytes. |
好的,谢谢。所以,要清楚应用笔记AN1388中的内存映射不是正确的吗?
以上来自于百度翻译 以下为原文 ok thankyou. so just to be clear the memory map in the application note AN1388 is not the correct one? Attached Image(s) |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5794 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 13:59 , Processed in 0.730396 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
217
