2个快速的问题,我找不到答案:1)If被称为先前停止/变形的对象,发生了什么?2)如果计时器启动,如果在定时器过期后调用:将发生什么?对于单次单镜头计时器,该功能是否应该使用?帮助文件只提到停止并破坏一个周期定时器。我在代码中发现注释,说明CPU在开始执行单个定时器但没有具体停止之后开始奇怪地随机重置。
以上来自于百度翻译 以下为原文 2 quick questions that I could not find answers for: 1) If SYS_TMR_CallbackStop(handle) is called for a previously stopped / destryoed object, what happens? 2) If a timer is started with handle = SYS_TMR_CallbackSingle() what happens if : SYS_TMR_CallbackStop(handle) is called AFTER that timer has expired? and should that function be used at all for Single one shot timers? The help file only mentions that is stops and destroys a periodic timer. I found comments in code here that state that the CPU started strangely randomly resetting after Single timers were implemented started but NOT specifically stopped. I am not sure. Regards X |
3个回答
除非他们改变了系统,(我仍然在1.11)你可以停止一个属于其他东西的计时器。一些计时器函数将计时器自动返回到池中。所以很难确定它仍然安全使用。所以要小心。重复的回调工作正常。
以上来自于百度翻译 以下为原文 Unless they changed the system ,( I am still at 1.11) you could be stopping a timer that belongs to something else. Some of the timer functions return the timer to the pool automatically. So it is difficult to be sure it still safe to use. So be care. Repetitive callbacks work ok. |
好的,我只是跟踪了停止函数,如果它不与一个有效句柄相比较,它基本上只是返回并且什么也不做。但是,不排除句柄是按你所说的另一个计时器再次有效的。我不知道该如何处理这些信息。只要它不能产生一个例外或结盟者一些其他的记忆,我现在大概可以忽略它。
以上来自于百度翻译 以下为原文 Ok. I just traced through the stop function and it seems that if it does not compare to a valid handle, it basically just returns and does nothing. That however does not rule out that the handle is valid again by some other timer as you said. I am not sure what to do with that information mentally but as long as it can not ever produce an exception or clubber some other memory, I can probably ignore it for now. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
501 浏览 0 评论
5811 浏览 9 评论
2350 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3543 浏览 3 评论
1159浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1120浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
888浏览 1评论
501浏览 0评论
/9
GMT+8, 2025-12-13 03:42 , Processed in 0.672174 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1151
