Namaste,我正在研究带有DSPIC30F4011i的PWM问题,因为当我增加PDC占空比的值降低时,请发现波形第一波形是PWM1H(PDC1=1999)和第二个PWM2H(PDC2=19999)。根据我的理解,应该是相反的,请解释为什么?…程序…使用主(空){TrISE=0x00;和/或确保PWM引脚被设置为输出端口=0x00;/ /清除输出PTCONBITS.PPES=1;/PWM PWM定时器规模比例PTCONPS.PTCKPS=0;//PWM定时器预刻度PTCONPTS.PTMOD=2;//PWM工作在上下模式连续PTMR=0;//P。WM计数器值,开始于0 PTP= 19999;//PWM时基周期PWMCON1比特。PMOD3=0;//PWM在互补模式PWMCON1BIT.PMOD2=0;//PWM在互补模式PWMCON1BIT.PMOD1=0;//PWM在互补模式PWMCON1BITS PN3H=1;//PWM高引脚启用PWMCON1BITS PN2H=1;//P;WM高PIN启用PWMCON1BITS PUN1H=1;//PWM高PIN启用PWMCON1BITS PEN3L=1;//启用PWM Low pin(方向控制?)PWMCON1比特?PN2L=1;/ / PWM Low pin启用(方向控制?)PWMCON1比特?PUN1L=1;/ / PWM Low pin启用(方向控制?)DTCON1BITS DTAPs=0;//死区预缩放器DTCON1BITS DTA=59;/死区时间值为4 U.PDC1=1999;//PWM×1占空比寄存器(11位)PDC2=19999;/PWM PWM 2占空比寄存器(11位)PDC3=30000;/PWM PWM占线占空比寄存器(11位)PTCONBITS.PTEN=1;/ /启用PWM定时库!(1){}
以上来自于百度翻译 以下为原文 Namaste, I am working on pwm with DSPIC30f4011 My problem is that as i increase the value of PDC duty cycle reduces. Please find the waveform first waveform is of PWM1H(PDC1=1999) and second of PWM2H(PDC2=19999). As per my understanding it should be opposite, kindly explain why? ........ Program used int main(void) { TRISE = 0x00; // make sure PWM pins are set to be outputs PORTE = 0x00; // clear the outputs PTCONbits.PTOPS = 1; // PWM timer post-scale PTCONbits.PTCKPS = 0; // PWM timer pre-scale PTCONbits.PTMOD = 2; // PWM operates in Up-down Mode continuously PTMR = 0; // PWM counter value, start at 0 PTPER = 19999; // PWM Timebase period PWMCON1bits.PMOD3 = 0; // PWM in complimentary mode PWMCON1bits.PMOD2 = 0; // PWM in complimentary mode PWMCON1bits.PMOD1 = 0; // PWM in complimentary mode PWMCON1bits.PEN3H = 1; // PWM High pin is enabled PWMCON1bits.PEN2H = 1; // PWM High pin is enabled PWMCON1bits.PEN1H = 1; // PWM High pin is enabled PWMCON1bits.PEN3L = 1; // PWM Low pin enabled (direction control later?) PWMCON1bits.PEN2L = 1; // PWM Low pin enabled (direction control later?) PWMCON1bits.PEN1L = 1; // PWM Low pin enabled (direction control later?) DTCON1bits.DTAPS = 0; //DeadTime pre-scaler DTCON1bits.DTA = 59; //DeadTime value for 4 us. PDC1 = 1999; // PWM#1 Duty Cycle register (11-bit) PDC2 = 19999; // PWM#2 Duty Cycle register (11-bit) PDC3 = 30000; // PWM#3 Duty Cycle register (11-bit) PTCONbits.PTEN = 1; // Enable PWM Timerbase! while(1) {} } Attached Image(s) |
2个回答
1)PDCX值不应大于PTPER值。2)你的评论中的“11位”语句是什么意思?3)只有一个波形图像贴在你的帖子上。4)使用[代码]…[/CODE]在代码周围的标签(无空白)用于正确的文本格式设置。
以上来自于百度翻译 以下为原文 1) The PDCx value should not be more than the PTPER value. 2) What do the "11-bit" statements in your comments mean? 3) There was only one waveform image attached to your post. 4) Use [ code ] ... [ /code ] tags (without whitespaces) around your code for proper text formatting. |
请找到两个波形的变焦视图
以上来自于百度翻译 以下为原文 Please find the zoom view with two waveform Attached Image(s) |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 06:48 , Processed in 0.642698 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7349
