AD9788芯片中,设置反sinc滤波器的作用是什么?
如下文介绍,参数设定的依据是什么呢? It is designed to provide greater than ±0.05 dB pass-band ripple up to a frequency of 0.4 × fDACCLK. To provide the necessary peaking at the upper end of the pass band, the inverse sinc filter has an intrinsic insertion loss of 3.4 dB. |
1个回答
TheDAC output spectrum is shaped by the characteristic sin(x)/x(or SINC) envelope, due to the intrinsic zero-order hold effectassociated with DAC-generated signals.Because the shape ofthe SINC envelope is well known, it can be compensated. This envelope restoration functionis provided bythe optionalinverse SINC filter preceding the DAC. This function isimplemented as an FIRfilter, which has a transfer function thatis the exact inverse of the SINC response.
只有小组成员才能发言,加入小组>>
给ADUM4223 增加信号驱动15V电压就不正常, 波动很大会被烧是什么情况?
1197 浏览 2 评论
ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1825 浏览 1 评论
ad7193差分输入ain1与ain2差是正值时,读到电压与实际值误差小,但为负值值,误差就变的很大
4191 浏览 2 评论
8918 浏览 1 评论
3099 浏览 1 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
1301浏览 3评论
AD7190状态寄存器一直是0x80,连续转换模式下RDY不拉低
1592浏览 2评论
1524浏览 2评论
1199浏览 2评论
1329浏览 1评论
GMT+8, 2024-10-18 07:42 , Processed in 4.331040 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
