The 74HC40103 is a high-speed Si-gate CMOS device and are pin compatible with the
40103 of the 4000B series. The 74HC40103 is specified in compliance with JEDEC standard no. 7A. The 74HC40103 consists of an 8-bit synchronous down counter with a single output which is active when the internal count is zero. The 74HC40103 contains a single 8-bit binary counter and has control inputs for enabling or disabling the clock (CP), for clearing the counter to its maximum count and for presetting the counter either synchronously or asynchronously. All control inputs and the terminal count output (TC) are active-LOW logic. In normal operation, the counter is decremented by one count on each positive-going transition of the clock (CP). Counting is inhibited when the terminal enable input (TE) is HIGH. The terminal count output (TC) goes LOW when the count reaches zero if TE is LOW, and remains LOW for one full clock period. When the synchronous preset enable input (PE) is LOW, data at the jam input (P0 to P7) is clocked into the counter on the next positive-going clock transition regardless of the state of TE. When the asynchronous preset enable input (PL) is LOW, data at the jam input (P0 to P7) is asynchronously forced into the counter regardless of the state of PE, TE, or CP. The jam inputs (P0 to P7) represent a single 8-bit binary word. When the master reset input (MR) is LOW, the counter is asynchronously cleared to its maximum count (decimal 255) regardless of the state of any other input. If all control inputs except TE are HIGH at the time of zero count, the counters will jump to the maximum count, giving a counting sequence of 256 clock pulses long. The 74HC40103 may be cascaded using the TE input and the TC output, in either a synchronous or ripple mode.
74HC40103.pdf
(136.62 KB, 下载次数: 4
2243 浏览 0 评论
1413 浏览 1 评论
4513 浏览 2 评论
2980 浏览 0 评论
这是汽车360全景控制器上的主板,请问圆圈中的原件是什么,起什么作用?
2714 浏览 0 评论
GMT+8, 2024-11-25 19:20 , Processed in 0.709652 second(s), Total 69, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
