这里给大家介绍一下3peak这个大品牌
思瑞浦微电子科技(苏州)股份有限公司,简称3PEAK,专注于高速、高精度、低功耗、超低噪声模拟芯片和系统产品,拥有自主知识产权并持续创新,致力于为市场、客户提供高性能、高可靠性、具有更佳性价比的模拟芯片,产品涵盖工业领域、医疗设备、汽车电子、通信系统和信息安全等多种应用领域。 采用位于以色列和美国的国际一流模拟Foundry、精益求精的芯片设计以及严谨的测试技术,保证了3PEAK高性能、高集成度、高稳定性、功能强大的模拟产品。从ADC、DAC,到放大器,到时钟产品,我们的设计者致力于每一项指标、每一个细节的反复推敲;同时,“3PEAK实验室“追求了每一项模拟性能的最佳测试技术和极致应用环境的探究,例如,对“超低噪声模拟芯片”在时域和频域的nV级噪声特征进行全面的测试与研究。 3PEAK以行业最高标准所建立的严格、完备的品质保证体系,确保了每一个产品都经过多达几十项的、严苛的检验测试,具备世界一流的产品一致性和可靠性。“3PEAK实验室”产品可靠性试验包括HTOL高温工作寿命试验、HAST高温高湿加速压力试验、TCT温度循环试验、ESD测试等。 3peak 运放LM358性能参数如下。 完美兼容替代ti LM358DR替代选型 LM358 - Low Slew Rate,36V, RRO Dual Op‐amps Features Internal Frequency Compensation for Unity Gain High DC Voltage Gain: 110dB(Typ) Wide Bandwidth at Unity Gain: 1.2MHz(Typ) Wide Power Supply Range: 3V to 36V Dual Supplies: ±1.5V to ±18V EMIRR IN+: 71dB(Under 1GHz) Low Supply Current: 100μA(Typ) Offset Voltage Temperature Drift: 1uV/°C Input Bias Current: 60pA Typical Input Common-Mode Voltage Range Includes Ground Rail-to-Rail Output No Phase Reversal for Overdriven Inputs –40°C to 125°C Operation Range ESD Rating: Robust 2KV – HBM, 2KV – CDM High Performance Drop-In Compatible With 321,358,324 Series ProductTypical ApplicationDescriptionLM321/358/324 types consist of single/dual/quad channel independent, high gain, internally frequency compensated operational amplifiers which are designed specifically to operate from a single power supply over a wide range of voltages. They may also be operated from split power supplies. The supply current is basically independent of the supply voltage over the recommended voltage range. These devices are particularly useful in interface circuits with digital systems and can be operated from the single common 5VDC power supply. They are also intended for transducer amplifiers, DC gain blocks and many other conventional op amp circuits which can benefit from the single power supply capability. In the linear mode, the input common-mode voltage range includes ground and the output voltage can also swing to both ground and power rail, even though operated from a single power supply. The LM321 is single channel version available in 5-pin SOT23 packages. The LM358 is dual channel version available in 8-pin SOP, TSSOP and MSOP packages. The LM324 is quad channel version available in 14-pin SOP and TSSOP packages.Applications Walkie-Talkie Battery Management Solution Transducer Amplifiers Summing Amplifiers Multivibrators Oscillators DC Gain Blocks 大盛唐国际集团---美国EXAR代理商/艾科嘉代理商--英国ISOCOM光耦代理商---韩国ATO授权代理商,***旺宏MXIC代理商,美国ALLIANCE代理商,美国3PEAK代理商,香港HKC晶振代理商,在深圳、上海、西安、北京、武汉、香港均设有分支机构,真诚欢迎您致电了解详情,随时为您提供技术支撑。 共赢热线13544202029 -邓R。企鹅号619694412 |
相关推荐 |
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
1859 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
658 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1188 浏览 0 评论
2773 浏览 3 评论
1252 浏览 1 评论
GMT+8, 2024-10-1 13:40 , Processed in 0.532233 second(s), Total 43, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
