PowerDesigner 与模型驱动开发
How to use PowerDesigner Business Process, UML and Data models in application analysis and design? Some software engineer processes are too complex (RUP, CMM, …) Each company should carefully select a process and adapt it to its own needs based on Type of application Size of team
Define Use Case Diagram Identify classes Define Collaboration Diagram and/or Sequence Diagram Identify classes and operations Design Class Diagram Generate a report and use the report as a specification Generate a Physical Data Model with O/R mapping Optimize the PDM Generate the Database Define classes implementation in Class Diagram Generate the code and O/R mapping Use an IDE to finish the implementation, compile and test Reverse engineer the code to update the UML model Reverse engineer existing code to create a Class Diagram Reverse engineer existing database to create a PDM Understand the existing application’s logic Define Use Case Diagram Define Collaboration Diagram and/or Sequence Diagram Improve Class Diagram Generate a report and use the report as a specification Modify the Database Improve classes implementation Generate the code and O/R mapping Use an IDE to finish the implementation, compile and test Reverse engineer the code to update the UML model |
电子水泵在低温启动时反应迟钝,高温时又容易过载,VHE电容能解决吗?
353 浏览 1 评论
为什么在充电过程中HY2213-BB3A会特别特别烫,这应该如何解决?
2582 浏览 0 评论
在实际网关设计中,如何利用电容的高纹波电流能力进行热管理优化?
1537 浏览 2 评论
5067 浏览 0 评论
1610 浏览 0 评论
/9
GMT+8, 2025-12-4 06:58 , Processed in 0.517115 second(s), Total 43, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
