电子发烧友论坛|
恳请各位大佬帮忙改正一下!由于昨天晚上发的帖子需要下载,所以今天重新发一贴,代码附上!恳请各位老哥帮忙指教一下,能让小弟有所进步!
问题如下:AD采样然后执行算法,但是查表时候一直循环,查不出来!是不是算法没有执行啊,小弟用的是飞思卡尔XEP100的板子! 程序在下边,#include #include "derivative.h" /* derivative-specific definitions */ #define BUS_CLOCK 32000000 #define OSC_CLOCK 16000000 #define FAN1 PORTB_PB2 #define FAN1_dir DDRB_DDRB2 #define FAN2 PORTA_PA3 #define FAN2_dir DDRA_DDRA3 #define FAN3 PORTA_PA4 #define FAN3_dir DDRA_DDRA4 #define FAN4 PORTA_PA5 #define FAN4_dir DDRA_DDRA5 #define FAN5 PORTD_PD7 #define FAN5_dir DDRD_DDRD7 #define FAN6 PORTD_PD6 #define FAN6_dir DDRD_DDRD6 #define FAN7 PORTD_PD5 #define FAN7_dir DDRD_DDRD5 #define FAN8 PORTD_PD4 #define FAN8_dir DDRD_DDRD4 #define FAN9 PORTA_PA7 #define FAN9_dir DDRA_DDRA7 #define FAN10 PORTA_PA6 #define FAN10_dir DDRA_DDRA6 const unsigned int oumu[]={ 10450,10000,9574,9166,8778,8480,8058,7724,7404,7098,6808,6532,6268,6015,5776,5546,5326,5118,4918,4726,4544,4368,4202 }; const unsigned int temp[]={ 24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46 }; unsigned char chanel; unsigned int AD_in0,AD_in1,AD_in2,AD_in3,AD_in4,AD_in8,AD_in9,AD_in10,AD_in11,AD_in12; unsigned int y=0; unsigned char h=0; float a,b; void INIT_PLL(){ //初始化锁相环 CLKSEL &=0x7f; PLLCTL &=0x8F; CRGINT &=0xDF; #if (BUS_CLOCK == 40000000) SYNR=0x44; #elif (BUS_CLOCK ==32000000) SYNR=0x43; #elif (BUS_CLOCK == 24000000) SYNR=0x42; #endif REFDV=0x81; PLLCTL |=0x70; asm NOP; asm NOP; while(!(CRGFLG&0x08)); CLKSEL=0x80; } void INIT_AD(){ //初始化AD转换 ATD0CTL2=0x40; //启动A/D模块,快速清零,禁止中断 ATD0CTL1_SRES=2;//选用12位模数转换 ATD0CTL3=0x88; //每次只转换一个通道 ATD0CTL4=0x01; //AD模块时钟频率为8MHz } unsigned int AD_capture(chanel) //启动AD转换 { unsigned int AD_data; switch(chanel) { case 0: ATD0CTL5 = 0x00; //转换AD00 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 1: ATD0CTL5 = 0x01; //转换AD01 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 2: ATD0CTL5 = 0x02; //转换AD02 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 3: ATD0CTL5 = 0x03; //转换AD03 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 4: ATD0CTL5 = 0x04; //转换AD04 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 8: ATD0CTL5 = 0x08; //转换AD08 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 9: ATD0CTL5 = 0x09; //转换AD09 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 10: ATD0CTL5 = 0x0a; //转换AD10 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 11: ATD0CTL5 = 0x0b; //转换AD11 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 12: ATD0CTL5 = 0x0c; //转换AD12 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; } return(AD_data); } void hanshu() { //电阻值算法 a=10*AD_capture(chanel)/(4.4-AD_capture(chanel)); b=a*1000; y=(int)b; } void main(void) { /* put your own code here */ DisableInterrupts; INIT_PLL(); INIT_AD(); FAN1_dir=1; FAN2_dir=1; FAN3_dir=1; FAN4_dir=1; FAN5_dir=1; FAN6_dir=1; FAN7_dir=1; FAN8_dir=1; FAN9_dir=1; FAN10_dir=1; FAN1=1; EnableInterrupts; for(;;){ while(1){ hanshu(); while(!(y<=oumu[h]&&y>=oumu[h+1])) //将阻止与已知阻止表比较 { h++; if (h==24){ h=0; } } AD_in0=temp[h]; } if (AD_in0>45) FAN1=0; else if (AD_in0<25) FAN1=1; if (AD_in1>45) FAN2=0; else if (AD_in1<25) FAN2=1; if (AD_in2>45) FAN3=0; else if (AD_in2<25) FAN3=1; if (AD_in3>45) FAN4=0; else if (AD_in3<25) FAN4=1; if (AD_in4>45) FAN5=0; else if (AD_in4<25) FAN5=1; if (AD_in8>45) FAN6=0; else if (AD_in8<25) FAN6=1; if (AD_in9>45) FAN7=0; else if (AD_in9<25) FAN7=1; if (AD_in10>45) FAN8=0; else if (AD_in10<25) FAN8=1; if (AD_in11>45) FAN9=0; else if (AD_in11<25) FAN9=1; if (AD_in12>45) FAN10=0; else if (AD_in12<25) FAN10=1; } } /* loop forever */ /* please make sure that you never leave main */ |
5 个讨论
#include #include "derivative.h" /* derivative-specific definitions */ #define BUS_CLOCK 32000000 #define OSC_CLOCK 16000000 #define FAN1 PORTB_PB2 #define FAN1_dir DDRB_DDRB2 #define FAN2 PORTA_PA3 #define FAN2_dir DDRA_DDRA3 #define FAN3 PORTA_PA4 #define FAN3_dir DDRA_DDRA4 #define FAN4 PORTA_PA5 #define FAN4_dir DDRA_DDRA5 #define FAN5 PORTD_PD7 #define FAN5_dir DDRD_DDRD7 #define FAN6 PORTD_PD6 #define FAN6_dir DDRD_DDRD6 #define FAN7 PORTD_PD5 #define FAN7_dir DDRD_DDRD5 #define FAN8 PORTD_PD4 #define FAN8_dir DDRD_DDRD4 #define FAN9 PORTA_PA7 #define FAN9_dir DDRA_DDRA7 #define FAN10 PORTA_PA6 #define FAN10_dir DDRA_DDRA6 const unsigned int oumu[]={ 10450,10000,9574,9166,8778,8480,8058,7724,0,7404,7098,6808,6532,6268,6015,5776,5546,5326,5118,4918,4726,4544,4368,4202 }; const unsigned int temp[]={ 24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47 }; unsigned char chanel; unsigned int AD_in0,AD_in1,AD_in2,AD_in3,AD_in4,AD_in8,AD_in9,AD_in10,AD_in11,AD_in12; unsigned int y=0; unsigned char h; float a,b; void INIT_PLL(){ //初始化锁相环 CLKSEL &=0x7f; PLLCTL &=0x8F; CRGINT &=0xDF; #if (BUS_CLOCK == 40000000) SYNR=0x44; #elif (BUS_CLOCK ==32000000) SYNR=0x43; #elif (BUS_CLOCK == 24000000) SYNR=0x42; #endif REFDV=0x81; PLLCTL |=0x70; asm NOP; asm NOP; while(!(CRGFLG&0x08)); CLKSEL=0x80; } void INIT_AD(){ //初始化AD转换 ATD0CTL2=0x40; //启动A/D模块,快速清零,禁止中断 ATD0CTL1_SRES=2;//选用12位模数转换 ATD0CTL3=0x88; //每次只转换一个通道 ATD0CTL4=0x07; //AD模块时钟频率为2MHz } unsigned int AD_capture(chanel) //启动AD转换 { unsigned int AD_data; switch(chanel) { case 0: ATD0CTL5 = 0x00; //转换AD00 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 1: ATD0CTL5 = 0x01; //转换AD01 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 2: ATD0CTL5 = 0x02; //转换AD02 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 3: ATD0CTL5 = 0x03; //转换AD03 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 4: ATD0CTL5 = 0x04; //转换AD04 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 8: ATD0CTL5 = 0x08; //转换AD08 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 9: ATD0CTL5 = 0x09; //转换AD09 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 10: ATD0CTL5 = 0x0a; //转换AD10 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 11: ATD0CTL5 = 0x0b; //转换AD11 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; case 12: ATD0CTL5 = 0x0c; //转换AD12 while(!ATD0STAT0_SCF); AD_data = ATD0DR0; break; } return(AD_data); } void hanshu() { //电阻值算法 a=10*AD_capture(chanel)/(4.4-AD_capture(chanel)); b=a*1000; y=(int)b; } void main(void) { /* put your own code here */ DisableInterrupts; INIT_PLL(); INIT_AD(); FAN1_dir=1; FAN2_dir=1; FAN3_dir=1; FAN4_dir=1; FAN5_dir=1; FAN6_dir=1; FAN7_dir=1; FAN8_dir=1; FAN9_dir=1; FAN10_dir=1; FAN1=1; h=0; EnableInterrupts; for(;;){ hanshu(); while(!(y<=oumu[h]&&y>=oumu[h+1])) //将阻止与已知阻止表比较 { h++; if (h==24){ h=0; } } AD_in0=temp[h]; if (AD_in0>45) FAN1=0; else if (AD_in0<25) FAN1=1; if (AD_in1>45) FAN2=0; else if (AD_in1<25) FAN2=1; if (AD_in2>45) FAN3=0; else if (AD_in2<25) FAN3=1; if (AD_in3>45) FAN4=0; else if (AD_in3<25) FAN4=1; if (AD_in4>45) FAN5=0; else if (AD_in4<25) FAN5=1; if (AD_in8>45) FAN6=0; else if (AD_in8<25) FAN6=1; if (AD_in9>45) FAN7=0; else if (AD_in9<25) FAN7=1; if (AD_in10>45) FAN8=0; else if (AD_in10<25) FAN8=1; if (AD_in11>45) FAN9=0; else if (AD_in11<25) FAN9=1; if (AD_in12>45) FAN10=0; else if (AD_in12<25) FAN10=1; } } /* loop forever */ /* please make sure that you never leave main */ 老哥我这个改过的查表之后0的时候h=7是怎么回事呢?不应该是8或者9吗? |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6776 浏览 1 评论
7794 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1557浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1210浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
736浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
679浏览 1评论
/9
GMT+8, 2025-12-2 15:48 , Processed in 0.939422 second(s), Total 61, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4046
