Fixed CCRs: SPB 17.2 HF020
05-21-2017
CCRID Product ProductLevel2 title
1737443 ADW DBEDITOR Revising the schematic model classification for one category causes all parts in the library to be revised
1734123 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas crashes Allegro PCB Designer in 17.2 S016
1742084 ALLEGRO_EDITOR DATABASE Running DB Doctor on DRA files with custom pad shapes resets some of the custom padstack shapes in release 17.2
1739397 ALLEGRO_EDITOR INTERACTIV In release 17.2, running the SKILL function axlImportXmlDBRecords causes Allegro PCB Editor to crash
1724588 ALLEGRO_EDITOR MANUFACT Backdrill Route keepout suppressing existing Route Keepouts
1740036 ALLEGRO_EDITOR MANUFACT Generating the cross-section chart does not provide information about the overall board thickness
1743726 ALLEGRO_EDITOR OTHER IDF file export: In release 17.2, only one design outline is exported as against multiple board outlines in release 16.6
1744467 ALLEGRO_EDITOR OTHER The 'logical_op_new' variable is not displayed in User Preferences Editor
1729350 ALLEGRO_EDITOR REPORTS Net loop report is not working.
1713014 ALLEGRO_EDITOR SHAPE Incorrect behavior of donut shaped pads at certain rotations
1739870 ALLEGRO_EDITOR SHAPE The artwork is different from the PCB in release 17.2 Hotfix 17
1698869 ALLEGRO_EDITOR SKILL PCB Editor crashes when trying to open another .brd file after running SRM on first .brd file
1739307 ALLEGRO_EDITOR SKILL axlCNSDFAExport fails after first run
1743385 ALLEGRO_EDITOR SKILL SKILL APIs for STEP model mapping are not available in release 17.2 Hotfix 17 or 18
1685826 ALLEGRO_EDITOR UI_GENERAL Reports when opened from Status Form disappear behind PCB Editor canvas when clicking on canvas
1687797 ALLEGRO_EDITOR UI_GENERAL Cannot open two HTML windows, one after the other, while using SKILL function
1696229 ALLEGRO_EDITOR UI_GENERAL Setting the 'allegro_html' environment variable in User Preferences Editor overwrites existing popup text windows
1708636 ALLEGRO_EDITOR UI_GENERAL In SPB 17.2 release, keyboard focus automatically shifts to the newly opened dialog box
1711367 ALLEGRO_EDITOR UI_GENERAL Launching two report windows using SKILL is not working in 17.2
1742856 ALLEGRO_EDITOR UI_GENERAL Allegro PCB Editor crashes if Project Manager is open for a design in release 17.2 Hotfix 18
1729519 APD SHAPE shape degassing does not generate all voids to cover entire shape
1711375 CONCEPT_HDL CORE Copy-paste of schematic between two instances of DE-HDL is not working as expected
1737230 CONCEPT_HDL CORE On the Linux platform, copying of schematic objects does not work between designs of releases 16.6 and 17.2
1741375 CONCEPT_HDL CORE Inconsistent behavior of the Move command when moving a symbol
1743992 CONCEPT_HDL CORE Inconsistent behavior of the Move command when moving a symbol
1736093 CONSTRAINT_MGR CONCEPT_HDL Incorrect topology extraction and mapping errors related to MUX parts
1743518 CONSTRAINT_MGR CONCEPT_HDL Lag observed in expanding and collapsing the net classes in Constraint Manager
1730159 FSP ALLEGRO_INTEG FSP diff engine does not read PF Thevenin connections in FSP
1664070 ORBITIO ALLEGRO_SIP_I Display pads of SMD components on correct layer
1709319 ORBITIO USABILITY OrbitIO issues an error about Device template while importing brd with Bundles
1741150 PSPICE ENVIRONMENT Need a way to prevent the 'pspSimSetting.js' file from being overwritten by a hotfix installation in 17.2
1735354 PSPICE SIMULATOR Access to custom nom.lib is not working as expected
1716523 SIP_LAYOUT COLOR Tool crashes on using the PageUp, PageDown, and Tab keys in the Color dialog box.
