扫一扫,分享给好友
-- Company: -- Engineer: -- -- Create Date: 11:13:45 03/09/2017 -- Design Name: -- Module Name: top - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_arith.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. library UNISIM; use UNISIM.VComponents.all; entity top is Port ( clk : in STD_LOGIC; -- data_in : in STD_LOGIC_VECTOR (13 downto 0); -- clk8k: out STD_LOGIC;--AD时钟 -- dds_rdy : OUT STD_LOGIC; -- -- -- accumulate1_SCLR:IN STD_LOGIC; -- accumulate1_S:OUT STD_LOGIC_VECTOR(31 downto 0); -- accumulate2_SCLR:IN STD_LOGIC; -- accumulate2_S:OUT STD_LOGIC_VECTOR(31 downto 0); pdb : inout std_logic_vector(7 downto 0); astb : in std_logic; dstb : in std_logic; pwr : in std_logic; pwait: out std_logic; Q: out STD_LOGIC_VECTOR (31 downto 0) ); end top; architecture Behavioral of top is COMPONENT dds PORT ( clk : IN STD_LOGIC; ce : IN STD_LOGIC; we : IN STD_LOGIC; sclr : IN STD_LOGIC; data : IN STD_LOGIC_VECTOR(24 DOWNTO 0); rdy : OUT STD_LOGIC; cosine : OUT STD_LOGIC_VECTOR(13 DOWNTO 0); sine : OUT STD_LOGIC_VECTOR(13 DOWNTO 0); phase_out : OUT std_logic_vector(24 downto 0) ); END COMPONENT; component accumulate1 port( CLK:In STD_LOGIC; A:IN STD_LOGIC_VECTOR(13 downto 0); B:IN STD_LOGIC_VECTOR(13 downto 0); CE:IN STD_LOGIC; SCLR:IN STD_LOGIC; S:OUT STD_LOGIC_VECTOR(31 downto 0) ); END component; component accumulate2 port( CLK:In STD_LOGIC; A:IN STD_LOGIC_VECTOR(13 downto 0); B:IN STD_LOGIC_VECTOR(13 downto 0); CE:IN STD_LOGIC; SCLR:IN STD_LOGIC; S:OUT STD_LOGIC_VECTOR(31 downto 0) ); END component; constant stEppReady : std_logic_vector(7 downto 0) := "0000" & "0000" ; constant stEppAwrA : std_logic_vector(7 downto 0) := "0001" & "0100" ; constant stEppAwrB : std_logic_vector(7 downto 0) := "0010" & "0001" ; constant stEppArdA : std_logic_vector(7 downto 0) := "0011" & "0010" ; constant stEppArdB : std_logic_vector(7 downto 0) := "0100" & "0011" ; constant stEppDwrA : std_logic_vector(7 downto 0) := "0101" & "1000" ; constant stEppDwrB : std_logic_vector(7 downto 0) := "0110" & "0001" ; constant stEppDrdA : std_logic_vector(7 downto 0) := "0111" & "0010" ; constant stEppDrdB : std_logic_vector(7 downto 0) := "1000" & "0011" ; signal stEppCur : std_logic_vector(7 downto 0) := stEppReady; signal stEppNext : std_logic_vector(7 downto 0) ; signal clkMain : std_logic; --u***时钟 signal ctlEppWait : std_logic; signal ctlEppAstb : std_logic; signal ctlEppDstb : std_logic; signal ctlEppDir : std_logic; signal ctlEppWr : std_logic; signal ctlEppAwr : std_logic; signal ctlEppDwr : std_logic; signal busEppOut : std_logic_vector(7 downto 0); signal busEppIn : std_logic_vector(7 downto 0); signal busEppData : std_logic_vector(7 downto 0); signal regEppAdr : std_logic_vector(3 downto 0); -- Registers signal regData0 : std_logic_vector(7 downto 0); signal regData1 : std_logic_vector(7 downto 0); signal regData2 : std_logic_vector(7 downto 0); signal regData3 : std_logic_vector(7 downto 0); signal regData4 : std_logic_vector(7 downto 0); signal regData5 : std_logic_vector(7 downto 0); signal regData6 : std_logic_vector(7 downto 0); signal regData7 : std_logic_vector(7 downto 0); signal regLed : std_logic_vector(7 downto 0); signal dout1,dout2,data_out,sine,cosine : std_logic_vector(13 downto 0);--dout1是参考sine dout2是参考cosine data_out是AD转换后序列 ----signal cntr: std_logic_vector(23 downto 0); signal dds_we,dds_sclr,dds_ce,clk_8k : std_logic; signal accumulate1_ce,accumulate2_ce,rdy: std_logic; signal flag: std_logic:='1'; signal dds_data,phase_out: std_logic_vector(24 downto 0); signal dataout1,dataout2 : std_logic_vector(31 downto 0); begin ctlEppAstb <= astb; ctlEppDstb <= dstb; ctlEPPWr <= pwr; pwait <= ctlEppWait; busEppIn <= pdb; pdb <= busEppOut When ctlEppWr = '1' and ctlEppDir = '1' else "ZZZZZZZZ"; busEppOut <= "0000" & regEppAdr When ctlEppAstb = '0' else busEppData; --选择地址或数据xuantong -- rgLed <= choose_freq(3 downto 0); -- ldg <= '1'; ctlEppWait <= stEppCur(0); ctlEppDir <= stEppCur(1); ctlEppAwr <= stEppCur(2); ctlEppDwr <= stEppCur(3); busEppData <= regData0 when regEppAdr = "0000" else regData1 when regEppAdr = "0001" else regData2 when regEppAdr = "0010" else regData3 when regEppAdr = "0011" else regData4 when regEppAdr = "0100" else regData5 when regEppAdr = "0101" else regData6 when regEppAdr = "0110" else regData7 when regEppAdr = "0111" else "00000000"; Inst_dds : dds PORT MAP ( clk => clk_8k, sclr=>flag, ce=>not flag, we =>not flag, data => dds_data, rdy=>rdy, cosine => cosine, sine => sine, phase_out => phase_out ); Inst_accumulate1 : accumulate1 port map ( CLK=>clk_8k, --成累加一次周期 A=>dout1, B=>dout2, CE=>rdy, SCLR=> flag, S=>dataout1 ); --Inst_accumulate2 : accumulate2 --port map ( --CLK=>clk_8k, --成累加一次周期 --A=>dout2, --B=>data_out, --CE=>rdy, --SCLR=> reset, --S=>dataout2 --); ------------------------------------------------ dout1(13) <= not sine(13); dout1(12 downto 0) <= sine(12 downto 0); dout2(13) <= not cosine(13); dout2(12 downto 0) <= cosine(12 downto 0); process variable count: integer :=0 ; begin wait until clk'Event and clk='1'; --设置周期采样点个数 if (count<500) then count:=count+1; else clk_8k<=not clk_8k; count:=0; end if; end process; process variable count: integer :=0 ; begin wait until clk'Event and clk='1'; --设置解调周期 if (count<=8000) then flag<='1'; count:=count+1; elsif (80000 count:=count+1; else count:=0; end if; end process; process (clk) begin if clk = '1' and clk'Event then stEppCur <= stEppNext; end if; end process; process (stEppCur, stEppNext, ctlEppAstb, ctlEppDstb, ctlEppWr) begin case stEppCur is When stEppReady => if ctlEppAstb = '0' then if ctlEppWr = '0' then stEppNext <= stEppAwrA; --ctlEppNext=1读 else stEppNext <= stEppArdA; end if; elsif ctlEppDstb = '0' then if ctlEppWr = '0' then stEppNext <= stEppDwrA; else stEppNext <= stEppDrdA; end if; else stEppNext <= stEppReady; end if; When stEppAwrA => stEppNext <= stEppAwrB; When stEppAwrB => -- xie地址线 if ctlEppAstb = '0' then stEppNext <= stEppAwrB; else stEppNext <= stEppReady; end if; When stEppArdA => stEppNext <= stEppArdB; When stEppArdB => if ctlEppAstb = '0' then --读地址线 stEppNext <= stEppArdB; else stEppNext <= stEppReady; end if; When stEppDwrA => stEppNext <= stEppDwrB; When stEppDwrB => --写数据线 if ctlEppDstb = '0' then stEppNext <= stEppDwrB; else stEppNext <= stEppReady; end if; When stEppDrdA => stEppNext <= stEppDrdB; When stEppDrdB => if ctlEppDstb = '0' then --写地址线 stEppNext <= stEppDrdB; else stEppNext <= stEppReady; end if; When others => stEppNext <= stEppReady; end case; end process; process (clk, ctlEppAwr) --? begin if clk = '1' and clk'Event then if ctlEppAwr = '1' then regEppAdr <= busEppIn (3 downto 0); end if; end if; end process; process (clk, regEppAdr, ctlEppDwr, busEppIn) begin if clk = '1' and clk'Event then if ctlEppDwr = '1' and regEppAdr = "0001" then --地址为1时,写入控制第一个dds regData1 <= dataout1(7 downto 0); --这里怎么写? end if; end if; end process; process (clk, regEppAdr, ctlEppDwr, busEppIn) begin if clk = '1' and clk'Event then if ctlEppDwr = '1' and regEppAdr = "0010" then --地址为2 regData2 <= dataout1(15 downto 8); end if; end if; end process; process (clk, regEppAdr, ctlEppDwr, busEppIn) begin if clk= '1' and clk'Event then if ctlEppDwr = '1' and regEppAdr = "0011" then --地址为3 regData3 <= dataout1(23 downto 16); end if; end if; end process; process (clk, regEppAdr, ctlEppDwr, busEppIn) begin if clk = '1' and clk'Event then if ctlEppDwr = '1' and regEppAdr = "0100" then --地址为4 regData4 <= dataout1(31 downto 24); end if; end if; end process; Q <= dataout1; --R <= dataout2; dds_data <= "0000000000001000001100010"; --1k --ad9240clk<=clk_8k; --dds_ce<='1'; --dds_we <= '1'; --ce<='1'; --clk8k<=clk_8k; --dds_rdy<=rdy; --dds_sclr<=flag; --dds_we<=not flag; --dds_ce<=not flag; --accumulate1_ce<=not flag; --accumulate2_ce<=not flag; end Behavioral; |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计52:主要功能测试结果与分析4(NVMe 指令提交与完成机制测试)
866 浏览 0 评论
NVMe高速传输之摆脱XDMA设计51:主要功能测试结果与分析3 nvmePCIe高速存储 PCIe高速存储
546 浏览 0 评论
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
524 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1568 浏览 0 评论
1031 浏览 0 评论
4523 浏览 64 评论
/9
GMT+8, 2025-12-9 07:17 , Processed in 1.713414 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1303
