1、在资料上看到MSP430的I2C的中断向量的对应:
USCIAB0TX_VECTOR为数据向量(包括发送和接收) USCIAB0RX_VECTOR为状态向量(包括4个状态变化) 请问 (包括发送和接收)(包括4个状态变化)分别指什么?? 下面这是个主机程序 #include unsigned char TXData; unsigned char TXByteCtr; int main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop WDT P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0 P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz UCB0BR1 = 0; UCB0I2CSA = 0x48; // Slave Address is 048h UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation IE2 |= UCB0TXIE; // 使能发送中断 TXData = 0x00; // Holds TX data while (1) { TXByteCtr = 1; // Load TX byte counter while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts // Remain in LPM0 until all data // is TX'd TXData++; // Increment data byte } } #pragma vector = USCIAB0TX_VECTOR __interrupt void USCIAB0TX_ISR(void) { if (TXByteCtr) // Check TX byte counter { UCB0TXBUF = TXData; // Load TX buffer TXByteCtr--; // Decrement TX byte counter } else { UCB0CTL1 |= UCTXSTP; // I2C stop condition IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag __bic_SR_register_on_exit(CPUOFF); // Exit LPM0 } } 主机发送数据,使能发送中断,使用vector = USCIAB0TX_VECTOR 下面是从机程序 #include volatile unsigned char RXData; int main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop WDT P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0 P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMODE_3 + UCSYNC; // I2C Slave, synchronous mode UCB0I2COA = 0x48; // Own Address is 048h UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation IE2 |= UCB0RXIE; // 从机使能接收中断 while (1) { __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts __no_operation(); // Set breakpoint >>here<< and read } // RXData } // USCI_B0 Data ISR【 #pragma vector = USCIAB0TX_VECTOR __interrupt void USCIAB0TX_ISR(void) { RXData = UCB0RXBUF; // Get RX data __bic_SR_register_on_exit(CPUOFF); // Exit LPM0 } 从机接收数据,使能接收中断,为什么不使用 #pragma vector = USCIAB0RX_VECTOR而使用#pragma vector = USCIAB0TX_VECTOR??? |
1 个讨论
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
386 浏览 0 评论
求助一下关于51系列单片机的Timer0的计时问题,TH0、TL0+1的时间是怎么算的?
1670 浏览 1 评论
【RA-Eco-RA4E2-64PIN-V1.0开发板试用】开箱+Keil环境搭建+点灯+点亮OLED
1123 浏览 0 评论
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
1005 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
1229 浏览 2 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
12017 浏览 31 评论
GMT+8, 2024-12-23 10:21 , Processed in 0.772576 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
