PS:需要按一下按键加一或者减一,同时要保证数字的稳定显示
#include #define uchar unsigned char #define uint unsigned int ***it we = P1^1; ***it du = P1^2; ***it lcden = P3^4; uchar num1 = 1, num3=1; uint num2=1; uchar leddata[]={ 0xC0, //"0" 0xF9, //"1" 0xA4, //"2" 0xB0, //"3" 0x99, //"4" 0x92, //"5" 0x82, //"6" 0xF8, //"7" 0x80, //"8" 0x90, //"9" }; void delay(uint z); void KeyScan(); //带返回值的子函数 void show_num_2bit(); //2位数码管显示程序 void show_num_3bit_1(); //第一个3位数码管显示程序 void show_num_3bit_2(); //第二个3位数码管显示程序 void show_num(); /*------------------------------------------------*/ void main() { lcden = 0; TMOD = 0x01; TH0 = (65536 - 0)/256; TL0 = (65536 - 0)%256; EA = 1; ET0 = 1; TR0 = 1; while(1) { show_num(); } } /*------------------------------------------------*/ void Interrupt_T0()interrupt 1 { TH0 = (65536 - 0)/256; TL0 = (65536 - 0)%256; KeyScan(); } void delay(uint z) { uint x,y; for(x = z; x > 0; x--) for(y = 114; y > 0 ; y--); } void KeyScan() //带返回值的子函数 { uchar cord_l,cord_h;//声明列线和行线的值的储存变量 P2 = 0xf8;//1111 0000 if( (P2 & 0xf8) != 0xf8)//判断是否有按键按下 { delay(5);//软件消抖 if( (P2 & 0xf8) != 0xf8)//判断是否有按键按下 { cord_l = P2 & 0xf8;// 储存列线值 P2 = cord_l | 0x07; cord_h = P2 & 0x7;// 储存行线值 switch( cord_l + cord_h ) { //第一行键值码 控制二位数码管 case 0xf6: if(num1>=0&&num1<=98) num1++; break; //+1 case 0xee: if(num1>=1&&num1<=99) num1--; break; //-1 case 0xde: break; case 0xbe: break; case 0x7e: break; //第二行键值码 控制第一个三位数码管 case 0xf5: if(num2>=1&&num2<=199) num2++; break; //+1 case 0xed: if(num2>=2&&num2<=200) num2--; break; //-1 case 0xdd: break; case 0xbd: break; case 0x7d: break; //第三行键值码 控制第二个三位数码管 case 0xf3: if(num3>=1&&num3<=199) num3++; break; //+1 case 0xeb: if(num3>=2&&num3<=200) num3--; break; //-1 case 0xdb: break; case 0xbb: break; case 0x7b: break; } } } } void show_num_2bit() //2位数码管显示程序 { uchar ge, shi; shi =num1/10; ge =num1%10; P0 = 0x01; //十位显示 we = 1; we = 0; if(shi==0) { P0 = 0xFF; du=1; du=0; delay(2); } else if(shi!=0) { P0 = leddata[shi]; du=1; du=0; delay(2); } P0 = 0x02; //个位显示 we = 1; we = 0; P0 = leddata[ge]; du=1; du=0; delay(2); } void show_num_3bit_1() //第一个3位数码管显示程序 { uchar ge, shi, bai; bai =num2/100; shi =num2%100/10; ge =num2%10; P0 = 0x04; //百位显示 we = 1; we = 0; if(bai==0) { P0 = 0xFF; du=1; du=0; delay(2); } else if(bai!=0) { P0 = leddata[bai]; du=1; du=0; delay(2); } P0 = 0x08; //十位显示 we = 1; we = 0; if(shi==0&&bai==0) { P0 = 0xFF; du=1; du=0; delay(2); } else if(shi!=0||bai!=0) { P0 = leddata[shi]; du=1; du=0; delay(2); } P0 = 0x10; //个位显示 we = 1; we = 0; P0 = leddata[ge]; du=1; du=0; delay(2); } void show_num_3bit_2() //第二个3位数码管显示程序 { uchar ge, shi, bai; bai =num3/100; shi =num3%100/10; ge =num3%10; P0 = 0x20; //百位显示 we = 1; we = 0; if(bai==0) { P0 = 0xFF; du=1; du=0; delay(2); } else if(bai!=0) { P0 = leddata[bai]; du=1; du=0; delay(2); } P0 = 0x40; //十位显示 we = 1; we = 0; if(shi==0&&bai==0) { P0 = 0xFF; du=1; du=0; delay(2); } else if(shi!=0||bai!=0) { P0 = leddata[shi]; du=1; du=0; delay(2); } P0 = 0x80; //个位显示 we = 1; we = 0; P0 = leddata[ge]; du=1; du=0; delay(2); } void show_num() { show_num_2bit(); show_num_3bit_1(); show_num_3bit_2(); } |
6个回答
现在的问题是,数码管可以稳定显示,但是按一下按键数字会增加好多而不是一个。
回帖奖励 +1 分积分 |
应该是程序框架有问题。这么能把含有延时消抖的键扫描程序放在中断里呢?如果有必要把键扫描程序放在中断里,建议采用中断记数消抖,并且只把获取键值部分留下,键值服务部分放到主循环中处理。定时器中断时间1ms足以。
这个最好改成单次脉冲上调的方式
你的中断服务程序有问题,不知道你想多长时间产生一次中断?
TH0 = (65536 - 0)/256; TH0 = 256 2进制= 1 0000 0000 TL0 = (65536 - 0)%256; TL0 = 256 2进制= 1 0000 0000 8位寄存器能装下9位数吗?就算TH0 = TL0 = 0xFF,假如是12M晶振,1秒要进入中断1000000次,你的中断服务程序还有按键扫描程序,其中还包含5ms的延时,这个中断服务程序能正常工作吗? |
所有延时都为定时器延时方式实现
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
386 浏览 0 评论
求助一下关于51系列单片机的Timer0的计时问题,TH0、TL0+1的时间是怎么算的?
1670 浏览 1 评论
【RA-Eco-RA4E2-64PIN-V1.0开发板试用】开箱+Keil环境搭建+点灯+点亮OLED
1123 浏览 0 评论
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
1005 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
1229 浏览 2 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
12018 浏览 31 评论
GMT+8, 2024-12-23 13:54 , Processed in 0.801520 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
