名称 | 型号 | 处理器 | 主频 | 内存 | 存储 | 系统 | 价格 | 核心板配置1 | LST-CORE3354-512D4GE-080-IC-L | AM3354 | 800M | 512MB | 4GB EMMC | Linux | 299 | | LST-CORE3354-512D4GE-080-IC-A | AM3354 | 800M | 512MB | 4GB EMMC | Android | 299 | | LST-CORE3354-512D512N-080-IC-L | AM3354 | 800M | 512MB | 512MB NAND | Linux | 299 | | LST-CORE3354-512D512N-080-IC-A | AM3354 | 800M | 512MB | 512MB NAND | Android | 299 | | LST-CORE3354-1GD4GE-080-IC-L | AM3354 | 800M | 1GB | 4GB EMMC | Linux | 399 | | LST-CORE3354-1GD4GE-080-IC-A | AM3354 | 800M | 1GB | 4GB EMMC | Android | 399 | 如需其他配置,请联系客服改价!
LST-Core335X-A是北京立萨科技有限公司开发的基于AM335X处理器的嵌入式核心板模块。最高1GHz主频的Cortex-A8内核,可提供快速的数据处理和流畅的界面切换。该产品自带6路UART、2路CAN-Bus,2路USB OTG、2路以太网等接口,具有强大的通讯功能。
AM335x ARM Cortex-A8 Processors | Core Feature | AM3352 | AM3354 | AM3356 | AM3357 | AM3358 | AM3359 | Package | 15x15mm, 0.8mm (ZCZ) | CPU Speed (MHz) | 300, 600, 800, 1000 | 300, 600, 800, 1000 | 300, 600,800 | 300, 600,800 | 600, 800,1000 | 800 | [tr][/tr]
Core Internal Memory | 64KB SRAM shared w/ | Data 32KB Cache, Programmable 32KB Cache | On-chip L2 (KB) | Data 32KB Cache, Programmable 32KB Cache | External Memory Interface | DDR2/DDR3/DDR3L/mDDR (LPDDR), 2x16-bit, NAND ECC | Graphics | - | 3D Graphics | - | - | 3D | OS Support | Linux, Android,Windows Embedded | Other Hardware Acceleration | Crypto Accelerator | Crypto Accelerator | 2 PRU-ICSS Crypto Accelerator | 2 PRU-ICSS Crypto Accelerator + EtherCAT slave support | 2 PRU-ICSS Crypto Accelerator | 2 PRU-ICSS Crypto Accelerator + EtherCAT slave support | [tr][/tr]
[tr][/tr]
[tr][/tr]
[tr][/tr]
10/100/1000 EMAC | 2 port switch | USB 2.0 OTG + PHY | 2 | Serial Ports | 6 UART, 2 SPI, 3 I2C, 2 McASP, 2 CAN, 8 Timers | System | EDMA, WDT, RTC, 3 eQEP, 3 eCAP, JTAG, ADC (8ch) | Parallel | 3 MMC/SD/SDIO, GPIO | TI AM335X 核心板(配图)
项目 | 参数 | 配置 | CPU | TI AM3354 (800MHz主频) Cortex-A8处理器 | 可选 | 内存 | 512MB/1GB | 可选 | Flash | 4GB EMMC ,512MB NAND | 可选 |
项目 | 参数 | 网口 | 2路RGMII接口(支持MII、RMII、RGMII) | USB | 2路独立USB OTG | UART | 5路UART(含UART0,最多支持6路,与其它引脚复用) | McASP | 1路(最多支持2路,与其它引脚复用) | I2C | 2路(最多支持3路,与其它引脚复用) | SPI | 1路(最多支持2路,与其它引脚复用) | MMC | 1路(支持MMC、SD、SDIO,最多支持3路,与其它引脚复用) | PWM | 2路(最多支持3路,与其它引脚复用) | GPIO | 2路(最多支持118路,与其他引脚复用) | LCD | 24Bit RGB | GPMC | 引出所有地址、数据、控制总线(与其它引脚复用) | ADC | 8路(4路用作电阻触摸屏) | CAN | (最多支持2路,与其它引脚复用) | JTAG | 支持 | 备注: | 核心板已引出AM335X的所有功能引脚 |
项目 | 参数 | 工作温度 | -40~+ 85℃工业级 | 存储环境温度 | -50~100 ℃ | 存储环境湿度 | 20%~90%,非冷凝 | 机械尺寸 | 54mm x 54 mm,4mm | | 8层板设计,沉金工艺,独立的完整接地层,无铅化工艺 | | 3.6V~5V | 静态系统功耗 | 约0.5W | 接口类型 | 4个44PIN双排插针接口(2*22)间距为4MM |
类 别 | 名称 | 备注 | 开发环境 | Vmware-workstation | 版本12.0.0以上 | ubuntu-12-04 | 推荐32bit版本 | 烧写镜像 | LST-SPL-335X-A2 V1.0 | | 引导程序 | u-boot | 版本u-boot-2013.01.01-psp06.00.00.00 | linux内核 | Linux | 版本linux-3.2.0-psp04.06.00.11 | 驱动程序 | USB OTG | | Ethernet | 2个RGMII接口 | SD | | eMMC/NandFlash | | Audio | MCASP | Touchpad | | LCD Controller | | UART | | I2C | | LED | | KEY | | PWM | | 测试代码 | UART测试程序 | |
类 别 | 名称 | 备注 | 开发环境 | Vmware-workstation | 版本12.0.0以上 | ubuntu-12-04 | 指定64bit版本 | 引导程序 | u-boot | | Linux内核 | Linux | 版本linux-3.2.0 | 驱动程序 | USB OTG | | Ethernet | 2个RGMII接口 | SD | | eMMC/NandFlash | | Audio | MCASP | Touchpad | | LCD Controller | | UART | | I2C | | LED | | KEY | | PWM | | Android | android 4.2.2 | |
标配 | 名称 | 数量 | 备注 |
am3354核心板
| 1 | |
am3354核心板 开发资料
| 1 | |
l超高性价比
一切从客户角度出发,维护客户的利益,坚持高品质、高性能的服务准则为客户创造最大效益。
l稳定、可靠、便捷
1、基于低功耗、低成本ARM处理器开发平台
2、高性能、多核ARM处理开发平台
3、高稳定性、高可靠性的信号链模块、通信模块等功能模块。
l个性化-自由定制
多年的历程,积累了丰富的行业经验,领先的行业技术支持,多款嵌入式平台,满足不同行业客户的定制需求。
联系电话:4009601660
工作时间:工作日8:30-17:30
网址:www.lisatech.cn
