SDRAM配置代码如下
void sdram_fullconfig(void) { Pin pinsSdram[] = {BOARD_SDRAM_PINS}; //configure corresponding pin. volatile uint32_t i; volatile uint8_t *pSdram = (uint8_t *) SDRAM_CS_ADDR; //SDRAM first address /* Configure PIO */ PIO_Configure(pinsSdram, PIO_LISTSIZE(pinsSdram)); PMC_EnablePeripheral(ID_SDRAMC); MATRIX->CCFG_SMCNFCS = CCFG_SMCNFCS_SDRAMEN; //Enable the SDRAM support /* 1. SDRAM features must be set in the configuration register: asynchronous timings (TRC, TRAS, etc.), number of columns, rows, CAS latency, and the data bus width. */ SDRAMC->SDRAMC_CR = SDRAMC_CR_NC_COL8 // 8 column bits ,reset 8 column | SDRAMC_CR_NR_ROW11 // 12 row bits (4K) ,reset 11 row | SDRAMC_CR_CAS_LATENCY3 // CAS Latency 3 ,reset 2 | SDRAMC_CR_NB_BANK2 // 2 banks ,reset 2 bank | SDRAMC_CR_DBW // 16 bit , reset 16 | SDRAMC_CR_TWR(5) //write recovery delay , reset 2 | SDRAMC_CR_TRC_TRFC(13) // 63ns min , row cycle delay and row refresh cycle delay ,reset 7 | SDRAMC_CR_TRP(5) // Command period (PRE to ACT) 21 ns min,reset 3 | SDRAMC_CR_TRCD(5) // Active Command to read/Write Command delay time 21ns min,reset 2 | SDRAMC_CR_TRAS(9) // Command period (ACT to PRE) 42ns min,reset 5 | SDRAMC_CR_TXSR(15U); // Exit self-refresh to active time 70ns Min ,reset 8 /* 2. For mobile SDRAM, temperature-compensated self refresh (TCSR), drive strength (DS) and partial array self refresh (PASR) must be set in the Low Power Register. */ /* 3. The SDRAM memory type must be set in the Memory Device Register.*/ SDRAMC->SDRAMC_MDR = SDRAMC_MDR_MD_SDRAM; //SDRAM or low power SDRAM /* 4. A minimum pause of 200 μs is provided to precede any signal toggle.*/ for (i = 0; i < 100000; i++); /* 5. (1)A NOP command is issued to the SDRAM devices. The application must set Mode to 1 in the Mode Register and perform a write access to any SDRAM address.*/ SDRAMC->SDRAMC_MR = SDRAMC_MR_MODE_NOP; *pSdram = 0; //enable SDRAM for (i = 0; i < 100000; i++); /* 6. An All Banks Precharge command is issued to the SDRAM devices. The application must set Mode to 2 in the Mode Register and perform a write access to any SDRAM address. */ SDRAMC->SDRAMC_MR = SDRAMC_MR_MODE_ALLBANKS_PRECHARGE; *pSdram = 0; for (i = 0; i < 100000; i++); /* 7. Eight auto-refresh (CBR) cycles are provided. The application must set the Mode to 4 in the Mode Register and perform a write access to any SDRAM location eight times.*/ for (i = 0; i < 8; i++) { SDRAMC->SDRAMC_MR = SDRAMC_MR_MODE_AUTO_REFRESH; *pSdram = 0; } for (i = 0; i < 100000; i++); /*8. A Mode Register set (MRS) cycle is issued to program the parameters of the SDRAM devices, in particular CAS latency and burst length. The application must set Mode to 3 in the Mode Register and perform a write access to the SDRAM. The write address must be chosen so that BA[1:0] are set to 0. For example, with a 16-bit 128 MB SDRAM (12 rows, 9 columns, 4 banks) bank address, the SDRAM write access should be done at the address 0x70000000.*/ SDRAMC->SDRAMC_MR = SDRAMC_MR_MODE_LOAD_MODEREG; *pSdram = 0; for (i = 0; i < 100000; i++); /*9. For mobile SDRAM initialization, an Extended Mode Register set (EMRS) cycle is issued to program the SDRAM parameters (TCSR, PASR, DS). The application must set Mode to 5 in the Mode Register and perform a write access to the SDRAM. The write address must be chosen so that BA[1] or BA[0] are set to 1. For example, with a 16-bit 128 MB SDRAM, (12 rows, 9 columns, 4 banks) bank address the SDRAM write access should be done at the address 0x70800000 or 0x70400000. */ //SDRAMC->SDRAMC_MR = SDRAMC_MR_MODE_EXT_LOAD_MODEREG; // *((uint8_t *)(pSdram + SDRAM_BA0)) = 0; /* 10. The application must go into Normal Mode, setting Mode to 0 in the Mode Register and performing a write access at any location in the SDRAM. */ SDRAMC->SDRAMC_MR = SDRAMC_MR_MODE_NORMAL; *pSdram = 0; for (i = 0; i < 100000; i++); /* 11. Write the refresh rate into the count field in the SDRAMC Refresh Timer register. (Refresh rate = delay between refresh cycles). The SDRAM device requires a refresh every 15.625 μs or 7.81 μs. With a 100 MHz frequency, the Refresh Timer Counter Register must be set with the value 1562(15.625 μs x 100 MHz) or 781(7.81 μs x 100 MHz). */ // For IS42S16100E, 2048 refresh cycle every 32ms or 16ms. SDRAMC->SDRAMC_TR = 1921;//15.625 x 123M = 1921 SDRAMC->SDRAMC_CFR1 |= SDRAMC_CFR1_UNAL;//Unaligned access is supported. /* After initialization, the SDRAM devices are fully functional. */ } |
经过试验,从表象看,是串口影响了SDRAM的读取和写入。
使用stm32l451片子,对ad7606进行3通道100k采样值跳动问题?
792 浏览 1 评论
STM32进行DMA数据转运,为什么只有A组最后一位数据被转运到B组去?
1415 浏览 2 评论
1733 浏览 3 评论
1336 浏览 0 评论
嵌入式开发 Win11安装ST-Link 提示 设备描述符请求失败 怎么处理?
1463 浏览 0 评论
GMT+8, 2024-8-21 21:30 , Processed in 0.531983 second(s), Total 49, Slave 41 queries .
