一、准备原料 三星原厂提供的UBOOT代码-u-boot-samsung-dev. [size=10.5000pt]二、在4212平台代码基础上修改成自己的平台LHS4412 1.用户目录下新建文件夹lhs4412-uboot cd, mkdir lhs4412-uboot 2.进入lhs4412-uboot文件夹,将三星平台代码压缩文件拷贝至此。解压, 重命名为:lhs4412-uboot tar -vxf u-boot-samsung-dev.tar.gz mv u-boot-samsung-dev lhs4412-uboot 3.拷贝迅为的CodeSign4SecureBoot文件夹到当前目录。至此当前目录结构为: 4.进入文件夹lhs4412-uboot cd lhs4412-uboot 进入三星平台cd board/samsung cp -rf smdk4212 lhs4412 cd lhs4412 Mv clock_init_smdk4212.S clock_init_lhs4412.S Mv mem_init_smdk4212.S mem_init_lhs4412.S Mv smdk4212.c lhs4412.c Mv smdk4212_val.h lhs4212_val.h Mv smdk4412_val.h lhs4412_val.h Vi lowlevel_init.S #ifdef CONFIG_EXYNOS4412 #include "smdk4412_val.h" //改为#include "lhs4412_val.h" #else #include "smdk4212_val.h" //改为#include "lhs4212_val.h" #endif Vi clock_init_lhs4412.S #ifdef CONFIG_EXYNOS4412 #include "smdk4412_val.h" //改为#include "lhs4412_val.h" #else #include "smdk4212_val.h" //改为#include "lhs4212_val.h" #endif Vi Makefile 33行:COBJS-y := smdk4212.o //改为:COBJS-y := lhs4412.o 37行;SOBJS += mem_init_smdk4212.o //改为:SOBJS += mem_init_lhs4412.o 38 ;SOBJS += clock_init_smdk4212.o //改为:SOBJS += clock_init_lhs4412.o Cd , cd lhs4412-uboot/lhs4412-uboot 修改boards.cfg 添加lhs4412 arm armv7 lhs4412 samsung exynos Cp -av include/configs/smdk4412.h include/configs/lhs4412.h Vi include/configs/lhs4412.h 265: #define CONFIG_SYS_PROMPT "SMDK4412 # " 改为:#define CONFIG_SYS_PROMPT "LHS4412 # " 319:#define CONFIG_IDENT_STRING " for SMDK4412" 改为;#define CONFIG_IDENT_STRING " for LHS4412" Vi u-boot.lds board/samsung/smdk4212/libsmdk4212.o (.text) 修改为 : board/samsung/lhs4412/liblhs4412.o (.text) 5.编译 make lhs4412_config make 6.制作UBOOT 因CPU exynos_4412的启动过程是 BL0 //BL0固化在iram中的程序 (关闭看门狗,关闭中断及MMU,时钟设置,检测om决定启动方式,拷贝bl1到iram中 BL1 <8k /*BL1 初始化化环境(中断初始化,设置堆栈等),搬移bl2代码到RAM中,并允许它, BL1是三星提供的,无源码,见CodeSign4SecureBoot/E4412_N.bl1.SCP2G.bin | 如果想看源码,可以反汇编分析,如arm-none-linux-gnueabi-objdump -D -b binary -m arm E4412_N.bl1.SCP2G.bin > b1.asm BL2 <14k //bl2 完成基本硬件初始化(Low_init.s 时钟串口内存flash等) u-boot.bin 所以我们单独运行u-boot是不行的,需使用三星提供的BL1 BL2进行打包加密校验 cp -rf sdfuse_q ./ //sdfuse_q 三星提供的加密处理(checksum) Cp mkuboot ./ //拷贝SD卡制作UBOOT脚 本。 //cp -rf CodeSign4SecureBoot ../ // CodeSign4SecureBoot 三星提供的安全启动方式 前面已拷贝 vim Makefile 修改,添加sdfuse_q的编译 (sdfuse_q主要是进行checksum ,大小等检验,还有通过脚本可制作sd启动盘) 在354 ifeq ($(CONFIG_CPU_EXYNOS5250),y) ./mkbl2 u-boot.bin bl2.bin 14336 Endif后添加 @split -b 14336 u-boot.bin bl2 @+make -C sdfuse_q/ @./sdfuse_q/chksum @./sdfuse_q/add_padding @rm bl2a* @echo Cp build_uboot.sh ./ 拷贝编译脚本 Vi build_uboot.sh 修改路径:sec_path="../CodeSign4SecureBoot/" if [ -z $1 ] then make tc4_android_config //改make lhs4412_config elif [ $1 = $option1 ] then make tc4_plus_android_config //改make lhs4412_config else echo please input right parameter. //改make lhs4412_config exit 0 Fi cat E4412_N.bl1.SCP2G.bin bl2.bin all00_padding.bin u-boot.bin tzsw_SMDK4412_SCP_2GB.bin > u-boot-iTOP-4412.bin改 为>u-boot-lhs-4412.bin mv u-boot-iTOP-4412.bin $ROOT_DIR 改为mv u-boot-lhs-4412.bin $ROOT_DIR chmod 777 ./build.sh ./build_uboot.sh 编译 生成u-boot-lhs-4412.bin [size=10.5000pt]7.加入点灯代码,确认uboot运行。 Vi board/samsung/lhs4412/lowlevel_init.S 96: /* PS-Hold high */ 电源管理 ldr r0, =0x1002330c ldr r1, [r0] orr r1, r1, #0x300 str r1, [r0] 后添加 ldr r0, =0x11000c08 ldr r1, =0x0 str r1, [r0] /* Clear MASK_WDT_RESET_REQUEST */ ldr r0, =0x1002040c ldr r1, =0x00 str r1, [r0] //led test ldr r0, =0x11000060 //GPK1[1] ldr r1, [r0] bic r1, r1, #0xf0 orr r1, r1, #0x10 str r1, [r0] ldr r1, [r0, #4] orr r1, r1, #2 str r1, [r0, #4] 保存重新编译,烧到开发板,运行,可 以看灯一闪而过。但是串口无任何输出。 8.开启串口 开发板串口为UART2. Vi include/configs/lhs4412.h 添加#define DEBUG 输出调试信息 161: #define CONFIG_SERIAL1 1 改为:#define CONFIG_SERIAL2 1 保存编译,烧到开发板,可以看到串口输出信息,进入UBOOT读秒,读取内核,但是EMMC读取速度超慢,无法忍受,但最终读取完成。 9.修改MMC驱动。加快内核的读取速度。 Vi driversmmcmmc.c 1271; 在函数mmc_init中 mmc_set_clock(mmc, 1); mmc_set_bus_width(mmc, MMC_BUS_WIDTH_1); 修改为: mmc_set_clock(mmc, 40000000); //40M mmc_set_bus_width(mmc, MMC_MODE_4BIT); 保存编译,烧到开发板,可以看到串口输出信息,进入UBOOT读秒,读取内核EMMC读取速度超快,读取完成。但是无法加载内核。打印信息如下 : ### main_loop: bootcmd="movi read kernel 0 40008000;movi read rootfs 0 41000000 100000;bootm 40008000 41000000" Hit any key to stop autoboot: 0 reading kernel..device 0 Start 1063, Count 8192 MMC read: dev # 0, block # 1063, count 8192 ... 8192 blocks read: OK completed reading RFS..device 0 Count 9255, Start 2048 MMC read: dev # 0, block # 9255, count 2048 ... 2048 blocks read: OK completed ## Current stack ends at 0xc3cfbdc8 * kernel: cmdline image address = 0x40008000 Wrong Image Format for bootm command ERROR: can't get kernel image! [size=10.5000pt]10.修改EMMC分区信息。 Vi archarmincludeasmarch-exynosMovi_partition.h 修改21-57行为: #define PART_SIZE_FWBL1 (8 * 1024) #define PART_SIZE_BL1 (16 * 1024) #define PART_SIZE_UBOOT (495 * 1024) #define PART_SIZE_KERNEL (6 * 1024 * 1024) #define PART_SIZE_ROOTFS (2 * 1024 * 1024)// 2M ////#define PART_SIZE_TZSW (156 * 1024) #define PART_SIZE_TZSW (24 * 1024) //为了与迅为UBOOT中的 environment start 544一致。 #define MOVI_FWBL1_BLKCNT (PART_SIZE_FWBL1 / MOVI_BLKSIZE) #define MOVI_BL1_BLKCNT (PART_SIZE_BL1 / MOVI_BLKSIZE) #define MOVI_ENV_BLKCNT (CONFIG_ENV_SIZE / MOVI_BLKSIZE) /* 16KB */ #define MOVI_UBOOT_BLKCNT (PART_SIZE_UBOOT / MOVI_BLKSIZE) /* 328KB */ #define MOVI_ZIMAGE_BLKCNT (PART_SIZE_KERNEL / MOVI_BLKSIZE) /* 4MB */ #define MOVI_ROOTFS_BLKCNT (PART_SIZE_ROOTFS / MOVI_BLKSIZE) /* 26MB */ #define MOVI_TZSW_BLKCNT (PART_SIZE_TZSW / MOVI_BLKSIZE) /* 160KB */ #define MOVI_UBOOT_POS ((eFUSE_SIZE / MOVI_BLKSIZE) + MOVI_FWBL1_BLKCNT + MOVI_BL1_BLKCNT) #define MOVI_TZSW_POS ((eFUSE_SIZE / MOVI_BLKSIZE) + MOVI_FWBL1_BLKCNT + MOVI_BL1_BLKCNT + MOVI_UBOOT_BLKCNT) #define ENV_START_BLOCK MOVI_FWBL1_BLKCNT+MOVI_BL1_BLKCNT+MOVI_UBOOT_BLKCNT+MOVI_TZSW_BLKCNT+1 Vi archarmcpuarmv7exynosMovi_partition.c 25: 修改函数init_raw_area_table Image[2]部分修改为: image[2].start_blk = location; image[2].used_blk = MOVI_UBOOT_BLKCNT + MOVI_BL1_BLKCNT + MOVI_FWBL1_BLKCNT; image[2].size = PART_SIZE_UBOOT + PART_SIZE_FWBL1 + PART_SIZE_BL1; image[2].attribute = 0x2; strcpy(image[2].description, "u-boot"); dbg("u-boot: %dn", image[2].start_blk); Image[3]部分: image[3].start_blk = image[2].start_blk + MOVI_UBOOT_BLKCNT; 修改为:image[3].start_blk = image[2].start_blk + MOVI_UBOOT_BLKCNT + MOVI_BL1_BLKCNT + MOVI_FWBL1_BLKCNT; Image[4]部分 image[4].attribute = 0x10; strcpy(image[4].description, "environment"); 后改为: if (location == 0) image[4].start_blk = image[4].start_blk + 2; else image[4].start_blk = image[4].start_blk + 1; 为了与迅为UBOOT中的environment start 544一致。 保存编译,烧到开发板,可以看到串口输出信息,进入UBOOT读秒,读取内核EMMC读取速度超快,读取完成。加载内核成功,文件系统也成功加载。但是UBOOT下,fastboot失败!Starting download of 527104 bytes ---------ERROR: DMA Address is not aligned by 8--------- 11.使用fastboot功能 Vi includeconfigslhs4412.h 167: #undef CONFIG_USB_CPUMODE 修改为#define CONFIG_USB_CPUMODE 保存编译,烧到开发板.fastboot命令成功 12.环境变量的保存。 到目前为止,环境变量是默认的。迅为开发板环境变量保存在错误的分区了,只要使用saveenv命令,就会破坏EMMC中的文件系统。导致加载文件系统不断重启而失败。最后连fastboot命令都失效。EMMC分区被破坏。重新分区,烧UBOOT, 文件系统。 Vi driversmmcmmc.c 在函数mmc_read_ext_csd中。 959: if (ext_csd_struct > 6) { printf("unrecognised EXT_CSD structure " "version %dn", ext_csd_struct); err = -1; goto out; } 改为 if ((ext_csd_struct > 5) && (7 != ext_csd_struct)) { printf("unrecognised EXT_CSD structure " "version %dn", ext_csd_struct); err = -1; goto out; } 因刚好version =7; 保存编译,烧到开发板.saveenv命令成功 ,现在读取的是EMMC中的环境变量。 13. 疑问:迅为提供的UBOOT E4412_N.bl1.SCP2G.bin 已经将整个UBOOT拷贝到内存中。测试是否如此? 修改lowlevel_init.S load_uboot函数修改为: /*****************************************************************************/ .globl load_uboot load_uboot: push {lr} ldr r0, =INF_REG_BASE ldr r1, [r0, #INF_REG3_OFFSET] cmp r1, #BOOT_MMCSD beq mmcsd_boot cmp r1, #BOOT_EMMC beq emmc_boot cmp r1, #BOOT_EMMC_4_4 beq emmc_boot_4_4 cmp r1, #BOOT_SEC_DEV beq mmcsd_boot second_mmcsd_boot: ldr r3, =BOOT_MMCSD ldr r0, =INF_REG_BASE str r3, [r0, #INF_REG3_OFFSET] mmcsd_boot: #ifdef CONFIG_CLK_1000_400_200 ldr r0, =ELFIN_CLOCK_BASE ldr r2, =CLK_DIV_FSYS2_OFFSET ldr r1, [r0, r2] orr r1, r1, #0xf str r1, [r0, r2] #endif mov r0, #SDMMC_CH2 str r0, _boot_device bl load_uboot_image b load_uboot_exit emmc_boot: #if defined(CONFIG_CLK_1000_400_200) || defined(CONFIG_CLK_1000_200_200) || defined(CONFIG_CLK_800_400_200) ldr r0, =ELFIN_CLOCK_BASE ldr r2, =CLK_DIV_FSYS1_OFFSET ldr r1, [r0, r2] orr r1, r1, #0x3 str r1, [r0, r2] #endif mov r0, #EMMC str r0, _boot_device bl load_uboot_image b load_uboot_exit emmc_boot_4_4: #if defined(CONFIG_CLK_1000_400_200) || defined(CONFIG_CLK_1000_200_200) || defined(CONFIG_CLK_800_400_200) ldr r0, =ELFIN_CLOCK_BASE ldr r2, =CLK_DIV_FSYS3_OFFSET ldr r1, [r0, r2] orr r1, r1, #0x3 str r1, [r0, r2] #endif /* mmc ch4 devider value change */ // bl mmc_ch4_devider_change mov r0, #EMMC_4_4 str r0, _boot_device bl load_uboot_image /* store second boot information in DRAM */ ldr r0, =CONFIG_PHY_UBOOT_BASE ldr r1, [r0] ldr r2, =0x2000 cmp r1, r2 bne second_mmcsd_boot b load_uboot_exit load_uboot_exit: pop {pc} /********************************************************************/ 149行附近时钟,内存初始化部分。 ldr r0, =0xff000fff bic r1, pc, r0 /* r0 <- current base addr of code */ ldr r2, _TEXT_BASE /* r1 <- original base addr in ram */ bic r2, r2, r0 /* r0 <- current base addr of code */ cmp r1, r2 /* compare r0, r1 */ beq after_copy /* r0 == r1 then skip sdram init and u-boot.bin loading */ ldr r0, =CHIP_ID_BASE ldr r1, [r0] lsr r1, r1, #8 and r1, r1, #3 cmp r1, #2 bne v310_1 bl mem_ctrl_asm_init bl system_clock_init b 1f v310_1: bl system_clock_init bl mem_ctrl_asm_init_ddr3 1: b load_uboot cold_boot: bl relocate_code ldr r0, _boot_device b coldboot 修改为: ldr r0, =0xff000fff bic r1, pc, r0 /* r0 <- current base addr of code */ ldr r2, _TEXT_BASE /* r1 <- original base addr in ram */ bic r2, r2, r0 /* r0 <- current base addr of code */ cmp r1, r2 /* compare r0, r1 */ beq after_copy /* r0 == r1 then skip sdram init and u-boot.bin loading */ ldr r0, =CHIP_ID_BASE ldr r1, [r0] lsr r1, r1, #8 and r1, r1, #3 cmp r1, #2 bne v310_1 /* Memory initialize */ bl mem_ctrl_asm_init /* init system clock */ bl system_clock_init b 1f v310_1: /* init system clock */ bl system_clock_init /* Memory initialize */ bl mem_ctrl_asm_init_ddr3 1: bl load_uboot /******* 若拷贝了则点亮此LED灯*************************/ ldr r0, =0x11000100 // GPL2CON的地址是0x11000100 ldr r1, [r0] // 先读出原值 bic r1, r1, #0xf // 清除bit[3:0] orr r1, r1, #1 // 设置bit[3:0]为0b0001 str r1, [r0] // 写入GPL2CON ldr r0, =0x11000104 // GPL0DAT的地址是0x11000104 ldr r1, [r0] // 读出原值 orr r1, r1, #1 // bit[0]为1 str r1, [r0] // 写入GPL0_0 mov r1, #0x1000000 3: subs r1, r1, #1 bne 3b _boot_device: .word 0x0 after_copy: 保存编译,烧到开发板.发现另一个LED灯 根本没亮过,说明BL1已经把完整的UBOOT拷贝到 内存。 14 网卡移植,迅为网卡芯片为DM9621, USB接口的网络芯片。驱动与DM9000完全不同,如果哪位移植成功, 请告诉我一声,谢谢! |
11 个讨论
简单学习了解一下
好贴,多谢分享
你正在撰写讨论
开启全新AI时代 智能嵌入式系统快速发展——“第六届国产嵌入式操作系统技术与产业发展论坛”圆满结束
1788 浏览 0 评论
2024 RT-Thread全球巡回线下培训火热来袭!报名提问有奖!
10361 浏览 11 评论
1965 浏览 0 评论
IaaS+on+DPU(IoD)+下一代高性能算力底座技术白皮书
3370 浏览 0 评论
飞凌嵌入式-ELFBOARD 常用的USB接口及其不同版本介绍第1期
1217 浏览 0 评论
68384 浏览 21 评论
嵌入式热门DIY项目:智能机器人开源资料合集(原理图、代码、论文)
68708 浏览 22 评论
GMT+8, 2024-9-16 08:13 , Processed in 0.670862 second(s), Total 53, Slave 45 queries .
