fixed = rgb2gray(imread('1-60.bmp'));
moving = rgb2gray(imread('1-120.bmp')); % View misaligned images 图片不一致 figure,imshowpair(fixed, moving,'blend','Scaling','independent'); title('两图差别'); % Get a configuration suitable for registering images from different % sensors. [optimizer, metric] = imregconfig('monomodal'); % Tune the properties of the optimizer to allow for more iterations % and reduce the initial step size we will take in parameter space so % that the registration will converge to a global maxima of mutual % information. optimizer.MaximumIterations = 300; %最大迭代次数 % optimizer.InitialRadius = 3.5e-3; % Align the moving image with the fixed image movingRegistered = imregister(moving, fixed, 'affine', optimizer, metric); % View registered images figure, imshowpair(fixed, movingRegistered,'Scaling','joint'); title('配准完成'); set(gca,'units','pixels','Visible','off'); frame=getframe; im1=frame2im(frame); imwrite(im1,'peizhun0.jpg','jpg'); 想求助下怎么把 配准图片配准区域是原灰度值图片而不是绿色的???
1个回答
我有Matlab运行出结果的源代码,你可以对比看看
使用simulink进行三相短路故障分析时,各参数应该如何设置
1294 浏览 1 评论
想请教一下图中是simulink的什么模块,需要这种三段斜率函数模块但没找到在哪
1419 浏览 1 评论
2334 浏览 1 评论
200圆!求助大佬给一份VSG并网和离网模式的simulink仿真
2600 浏览 0 评论
MATLAB(3)--矩阵的引用(sub2ind、ind2sub、reshape函数使用)
3431 浏览 0 评论
GMT+8, 2024-12-20 05:44 , Processed in 0.620837 second(s), Total 73, Slave 55 queries .
