前几天上电试试,结果系统起不来,哎!
只好刷系统咯,先刷了一个Ubuntu吧,我对这个比较熟,是Linux最好的桌面系统之一。
1.下载并安装系统烧写工具 IH固件烧写工具。下载链接:http://mirror.lemaker.org/IH_FW_Burning_Tool_For_Windowns_V2.01.03.zip
2.如果你想从EMMC NAND Flash启动操作系统,你必须在EMMC NAND Flash上安装一个操作系统。LeMaker Guitar可以利用核心板上的硬“ADFU”按键或底板上的软“ADFU”按键进入ADFU模式去烧系统固件。建议使用软“ADFU”按键进入ADFU模式。下面的步骤将告诉你如何将一个操作系统固件烧写到EMMC NAND Flash上。
在这里一定要注意了,要按住核心板上的升级ADFU按键哦,底板上的不起作用咧!
3.打开固件文件,点击“下载”,烧写系统固件到EMMC,耐心等待,直到固件烧写完成,重启即可!
4.测试:
上电后,uboot已经启动,能引导内核,结果呢,还是挂掉了!
- Uncomplicated firewall...
- [ OK ] Reached target Encrypted Volumes.
- [ OK ] Created slice system-getty.slice.
- Starting Create list of required st... nodes for the current kernel...
- Starting Setup Virtual Console...
- Mounting Debug File System...
- [ OK ] Mounted Debug File System.
- [ OK ] Started Remount Root and Kernel File Systems.
- [ OK ] Started Increase datagram queue length.
- [FAILED] Failed to start Load Kernel Modules.
- See "systemctl status systemd-modules-load.service" for details.
- [ OK ] Started Uncomplicated firewall.
- [ OK ] Started Create list of required sta...ce nodes for the current kernel.
- [ OK ] Started Setup Virtual Console.
- [ OK ] Started Nameserver information manager.
- [ OK ] Started udev Coldplug all Devices.
复制代码
心酸啊,再去看看uboot:
- U-Boot 2015.04-g66e41a5 (Jan 16 2016 - 14:32:57)Actions-Semi
- DRAM: mem-size=1024MB
- 1 GiB
- PLL:core=0x311,dev=0x1164,bus=0x1c710000,bus1=0x2e004,display=0x164, spead=0x0
- MMC: error: SDC0 send CMD8, No rsp
- error: SDC0 send CMD55, No rsp
- error: SDC0 send CMD1, No rsp
- error: SDC2 send CMD8, No rsp
- error: SDC2 send CMD55, No rsp
- SD0: 0, eMMC: 1 (eMMC)
- Using default environment
- *** emmc boot ***
- error: SDC0 send CMD8, No rsp
- Failed to find mmc:0
- reading boot_logo.bmp.gz
- reading new_gamma_data
- fdtdec_get_hdmi_par: not support auto ,we used default vid = 1039136640
- In: serial
- Out: serial
- Err: serial
- Net: owl_mac
- Error: owl_mac address 73:00:73:65:74:65 illegal value
- , u***_ether
- Error: u***_ether address not set.
- Hit any key to stop autoboot: 0
- try boot from mmc card ...
- ** Bad device mmc 0 **
- Wrong Image Format for bootm command
- ERROR: can't get kernel image!
- boot from emmc card ...
- reading uEnv.txt
- 177 bytes read in 3 ms (57.6 KiB/s)
- Loaded environment from uEnv.txt
- Running uenvcmd ...
- reading boot.scr
- ** Unable to read file boot.scr **
- reading uImage
- 5710784 bytes read in 253 ms (21.5 MiB/s)
- reading kernel.dtb
- 34456 bytes read in 4 ms (8.2 MiB/s)
- ## Booting kernel from Legacy Image at 00007fc0 ...
- Image Name: Linux-3.10.37
- Image Type: ARM Linux Kernel Image (uncompressed)
- Data Size: 5710720 Bytes = 5.4 MiB
- Load Address: 00008000
- Entry Point: 00008000
- Verifying Checksum ... OK
- ## Flattened Device Tree blob at 04000000
- Booting using the fdt blob at 0x4000000
- XIP Kernel Image ... OK
- Using Device Tree in place at 04000000, end 0400b697
- read_mi_head, line 430, magic 0x0, length 0, item num 0
- Starting kernel ...
复制代码
为嘛这么错错误咧???????
希望和大家一起讨论解决这个问题,嘿嘿
emmc烧录我这里也没有成功,今天搞了一个u***3.0的线来试试。
楼主, 我很期待楼主是如何解决的哦, 也希望看到楼主的分享。
楼主,目前从坛友的试用帖子中,烧录系统有成功的,您可以移步到试用汇总贴中,去看看其他坛友的分享,希望早日解决。
如果不能从EMMC启动,那你能够从SD卡启动吗?你可以把SD卡,或EMMC先格式化干净,再重新烧写系统。
