每个模块的程序都是没有问题的 但是放在一起就打开时弹出上图对话框,求指点,不胜感激
楼主问题解决了不?我也遇上了同样的问题,困惑好几天了,
Reported In
Software LabVIEW Full Issue Details My LabVIEW program has been crashing with errors in image.cpp or drawmgr.cpp I have noticed in Windows Task Manager that the number of GDI Objects used by LabVIEW approaches 10,000 The error in inconsistent in when it occurs This happens during edit-time, run-time, and, startup Solution Try reducing the amount front panel objects This will help reduce the total amount of GDI objects used by LabVIEW Change the limit of GDI object handles A method for increasing the number of GDI objects in Windows (after 2000) is described in MSDN:GDI Objects (Windows) Install the latest video driver from the manufacturer This will generally fix the memory leaks that lead to GDI overflow Change palette loading setting. In any LabVIEW window go to the top tool bar and navigate to Tools»Options... This should open the options window. Navigate to Controls/Functions Palette At the top there should be options for loading, select Load palettes when needed to try mitigate crashing Remove unnecessary libraries from your LabVIEW uses a GDI object for each palette image, so large numbers of palette VIs will contribute to this crash Call National Instruments support |
643 浏览 2 评论
NI Vision有个图片打不开其他图都能打开(用NI Vision Assistant也打开不了)
1073 浏览 1 评论
labview2015使用Excel报表程序打包生成后打开程序要选一个vi才能使用,否则软件就会报错,这是什么问题?
1648 浏览 2 评论
LabVIEW与单片机无法串口通信 提示串口打开错误 端口设置有问题吗?
1591 浏览 3 评论
1854 浏览 2 评论
GMT+8, 2024-12-25 04:32 , Processed in 0.714869 second(s), Total 85, Slave 67 queries .
