只能定义为char型,否则下载到单片机无法运行?
#include ***it ADDR0 = P1^0; ***it ADDR1 = P1^1; ***it ADDR2 = P1^2; ***it ADDR3 = P1^3; ***it ENLED = P1^4; unsigned char code LedChar[] = { //数码管显示字符转换表 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E }; unsigned char LedBuff[6] = { //数码管显示缓冲区,初值0xFF确保启动时都不亮 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF }; unsigned char i = 0; //动态扫描的索引 unsigned int cnt = 0; //记录T1中断次数 void main() { char j; //循环变量 unsigned long sec = 1000000; //记录经过的秒数,倒计时初值为999999+1 unsigned char buf[6]; //中间转换缓冲区 EA = 1; //使能总中断 ENLED = 0; //使能U3 ADDR3 = 1; //因为需要动态改变ADDR0-2的值,所以不需要再初始化了 TMOD = 0x10; //设置T1为模式1 TH1 = 0xFC; //为T1赋初值0xFC67,定时1ms TL1 = 0x67; ET1 = 1; //使能T1中断 TR1 = 1; //启动T1 while (1) { if (cnt >= 1000) //判断T1溢出是否达到1000次 { cnt = 0; //达到1000次后计数值清零 sec--; //秒计数自减1 //将sec按十进制位从低到高依次提取到buf数组中 buf[0] = sec%10; buf[1] = sec/10%10; buf[2] = sec/100%10; buf[3] = sec/1000%10; buf[4] = sec/10000%10; buf[5] = sec/100000%10; //从最高为开始,遇到0不显示,遇到非0退出循环 for (j=5; j>=1; j--) { if (buf[j] == 0) LedBuff[j] = 0xFF; else break; } //将剩余的有效数字位如实转换 for ( ; j>=0; j--) //for()起始未对j操作,j即保持上个循环结束时的值 { LedBuff[j] = LedChar[buf[j]]; } } } } /* 定时器1中断服务函数 */ void Interrupttimer1() interrupt 3 { TH1 = 0xFC; //重新加载初值 TL1 = 0x67; cnt++; //中断次数计数值加1 //以下代码完成数码管动态扫描刷新 P0 = 0xFF; //显示消隐 switch(i) { case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break; case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break; case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]; break; case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break; case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]; break; case 5: ADDR2=1; ADDR1=0; ADDR0=1; i=0; P0=LedBuff[5]; break; default: break; } }
2个回答
271 浏览 0 评论
493 浏览 0 评论
589 浏览 0 评论
891 浏览 0 评论
1436 浏览 2 评论
16927 浏览 31 评论
GMT+8, 2025-12-4 11:40 , Processed in 0.787651 second(s), Total 73, Slave 55 queries .
2692
