/******************************************************************************************************* 功能:程序中有两个按键,一个按下,在用数码管显示相应的数字,KEY1,KEY2主控芯片:stc12c5a60s2 ********************************************************************************************************/ /******************************************************************************************************* 程序发送部分: ********************************************************************************************************/ #include #include typedef unsigned char uchar; typedef unsigned char uint; //****************************************NRF24L01端口定义*************************************** //***it MISO =P1^3; //***it MOSI =P1^4; //***it SCK =P1^2; //***it CE =P1^1; //***it CSN =P3^2; //***it IRQ =P3^3; ***it MISO =P1^6; ***it MOSI =P1^5; ***it SCK =P1^7; ***it CE =P3^7; ***it CSN =P1^4; ***it IRQ =P3^2; //************************************按键*************************************************** ***it KEY1=P3^4; ***it KEY2=P3^5; //************************************数码管位选********************************************* ***it led3=P2^0; ***it led2=P2^1; ***it led1=P2^2; ***it led0=P2^3; //************************************蜂明器*************************************************** ***it BELL=P3^4; //***********************************数码管0-9编码******************************************* uchar seg[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码 //*********************************************NRF24L01************************************* #define TX_ADR_WIDTH 5 // 5 uints TX address width #define RX_ADR_WIDTH 5 // 5 uints RX address width #define TX_PLOAD_WIDTH 20 // 20 uints TX payload #define RX_PLOAD_WIDTH 20 // 20 uints TX payload uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址 uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址 //***************************************NRF24L01寄存器指令******************************************************* #define READ_REG 0x00 // 读寄存器指令 #define WRITE_REG 0x20 // 写寄存器指令 #define RD_RX_PLOAD 0x61 // 读取接收数据指令 #define WR_TX_PLOAD 0xA0 // 写待发数据指令 #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令 #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令 #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令 #define NOP 0xFF // 保留 //*************************************SPI(nRF24L01)寄存器地址**************************************************** #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 #define EN_AA 0x01 // 自动应答功能设置 #define EN_RXADDR 0x02 // 可用信道设置 #define SETUP_AW 0x03 // 收发地址宽度设置 #define SETUP_RETR 0x04 // 自动重发功能设置 #define RF_CH 0x05 // 工作频率设置 #define RF_SETUP 0x06 // 发射速率、功耗功能设置 #define STATUS 0x07 // 状态寄存器 #define OBSERVE_TX 0x08 // 发送监测功能 #define CD 0x09 // 地址检测 #define RX_ADDR_P0 0x0A // 频道0接收数据地址 #define RX_ADDR_P1 0x0B // 频道1接收 #define RX_ADDR_P2 0x0C // 频道2接收数据地址 #define RX_ADDR_P3 0x0D // 频道3接收数据地址 #define RX_ADDR_P4 0x0E // 频道4接收数据地址 #define RX_ADDR_P5 0x0F // 频道5接收数据地址 #define TX_ADDR 0x10 // 发送地址寄存器 #define RX_PW_P0 0x11 // 接收频道0接收数据长度 #define RX_PW_P1 0x12 // 接收频道0接收数据长度 #define RX_PW_P2 0x13 // 接收频道0接收数据长度 #define RX_PW_P3 0x14 // 接收频道0接收数据长度 #define RX_PW_P4 0x15 // 接收频道0接收数据长度 #define RX_PW_P5 0x16 // 接收频道0接收数据长度 #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置 //************************************************************************************** void Delay(unsigned int s); void inerDelay_us(unsigned char n); void init_NRF24L01(void); uint SPI_RW(uint uchar); uchar SPI_Read(uchar reg); void SetRX_Mode(void); uint SPI_RW_Reg(uchar reg, uchar value); uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars); uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); //*****************************************长延时***************************************** void Delay(unsigned int s) { unsigned int i,j; while(s--) { for(i=0; i<10; i++); for(j=0; j<12; j++); } } //****************************************************************************************** uint bdata sta; //状态标志 ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; /****************************************************************************************** /*延时函数 /******************************************************************************************/ void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } //**************************************************************************************** /*NRF24L01初始化 //***************************************************************************************/ void init_NRF24L01(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB } /**************************************************************************************************** /*函数:uint SPI_RW(uint uchar) /*功能:NRF24L01的SPI写时序 /****************************************************************************************************/ uint SPI_RW(uint uchar) { uint bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI uchar = (uchar << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. uchar |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(uchar); // return read uchar } /**************************************************************************************************** /*函数:uchar SPI_Read(uchar reg) /*功能:NRF24L01的SPI时序 /****************************************************************************************************/ uchar SPI_Read(uchar reg) { uchar reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /****************************************************************************************************/ /*功能:NRF24L01读写寄存器函数 /****************************************************************************************************/ uint SPI_RW_Reg(uchar reg, uchar value) { uint status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status uchar } /****************************************************************************************************/ /*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数 /****************************************************************************************************/ uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status uchar for(uchar_ctr=0;uchar_ctr CSN = 1; return(status); // return nRF24L01 status uchar } /********************************************************************************************************* /*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数 /*********************************************************************************************************/ uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; //SPI使能 status = SPI_RW(reg); for(uchar_ctr=0; uchar_ctr CSN = 1; //关闭SPI return(status); // } /****************************************************************************************************/ /*函数:void SetRX_Mode(void) /*功能:数据接收配置 /****************************************************************************************************/ void SetRX_Mode(void) { CE=0; SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC ,主接收 CE = 1; inerDelay_us(130); } /******************************************************************************************************/ /*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) /*功能:数据读取后放如rx_buf接收缓冲区中 /******************************************************************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) { unsigned char revale=0; sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况 if(RX_DR) // 判断是否接收到数据 { CE = 0; //SPI使能 SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1; //读取数据完成标志 } SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志 return revale; } /*********************************************************************************************************** /*函数:void nRF24L01_TxPacket(unsigned char * tx_buf) /*功能:发送 tx_buf中数据 /**********************************************************************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 CE=1; //置高CE,激发数据发送 inerDelay_us(10); } //************************************主函数************************************************************ void main(void) { unsigned char tf =0; unsigned char TxBuf[20]={0}; // unsigned char RxBuf[20]={0}; init_NRF24L01(); led0=0;led1=0;led2=0;led3=0; P0=0x00; TxBuf[1] = 1; TxBuf[2] = 1; nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data Delay(6000); P0=0xBF; while(1) { if(KEY1 ==0 ) { Delay(15); if(KEY1==0) { P0=seg[1]; TxBuf[1] = 1; tf = 1; } } if(KEY2 ==0 ) { Delay(15); if(KEY2 ==0 ) { P0=seg[2]; TxBuf[2] =1; tf = 1; } } if (tf==1) { nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data TxBuf[1] = 0x00; TxBuf[2] = 0x00; tf=0; Delay(1000); } //*********************************************************************************************** SetRX_Mode(); nRF24L01_RxPacket(RxBuf); if(RxBuf[1]|RxBuf[2]) { if( RxBuf[1]==1) { P0=seg[3]; } if( RxBuf[2]==1) { P0=seg[4]; } Delay(1000); } RxBuf[1] = 0x00; RxBuf[2] = 0x00; } } /******************************************************************************************************* 程序接收部分: ********************************************************************************************************/ #include #include typedef unsigned char uchar; typedef unsigned char uint; //****************************************NRF24L01端口定义*************************************** //***it MISO =P1^3; //***it MOSI =P1^4; //***it SCK =P1^2; //***it CE =P1^1; //***it CSN =P3^2; //***it IRQ =P3^3; ***it MISO =P1^6; ***it MOSI =P1^5; ***it SCK =P1^7; ***it CE =P3^7; ***it CSN =P1^4; ***it IRQ =P3^2; //************************************按键*************************************************** ***it KEY1=P3^5; ***it KEY2=P3^6; //************************************数码管位选********************************************* ***it led3=P2^0; ***it led2=P2^1; ***it led1=P2^2; ***it led0=P2^3; //************************************蜂明器*************************************************** ***it BELL=P3^4; //***********************************数码管0-9编码******************************************* uchar seg[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码 //*********************************************NRF24L01************************************* #define TX_ADR_WIDTH 5 // 5 uints TX address width #define RX_ADR_WIDTH 5 // 5 uints RX address width #define TX_PLOAD_WIDTH 20 // 20 uints TX payload #define RX_PLOAD_WIDTH 20 // 20 uints TX payload uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址 uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址 //***************************************NRF24L01寄存器指令******************************************************* #define READ_REG 0x00 // 读寄存器指令 #define WRITE_REG 0x20 // 写寄存器指令 #define RD_RX_PLOAD 0x61 // 读取接收数据指令 #define WR_TX_PLOAD 0xA0 // 写待发数据指令 #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令 #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令 #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令 #define NOP 0xFF // 保留 //*************************************SPI(nRF24L01)寄存器地址**************************************************** #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 #define EN_AA 0x01 // 自动应答功能设置 #define EN_RXADDR 0x02 // 可用信道设置 #define SETUP_AW 0x03 // 收发地址宽度设置 #define SETUP_RETR 0x04 // 自动重发功能设置 #define RF_CH 0x05 // 工作频率设置 #define RF_SETUP 0x06 // 发射速率、功耗功能设置 #define STATUS 0x07 // 状态寄存器 #define OBSERVE_TX 0x08 // 发送监测功能 #define CD 0x09 // 地址检测 #define RX_ADDR_P0 0x0A // 频道0接收数据地址 #define RX_ADDR_P1 0x0B // 频道1接收 #define RX_ADDR_P2 0x0C // 频道2接收数据地址 #define RX_ADDR_P3 0x0D // 频道3接收数据地址 #define RX_ADDR_P4 0x0E // 频道4接收数据地址 #define RX_ADDR_P5 0x0F // 频道5接收数据地址 #define TX_ADDR 0x10 // 发送地址寄存器 #define RX_PW_P0 0x11 // 接收频道0接收数据长度 #define RX_PW_P1 0x12 // 接收频道0接收数据长度 #define RX_PW_P2 0x13 // 接收频道0接收数据长度 #define RX_PW_P3 0x14 // 接收频道0接收数据长度 #define RX_PW_P4 0x15 // 接收频道0接收数据长度 #define RX_PW_P5 0x16 // 接收频道0接收数据长度 #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置 //************************************************************************************** void Delay(unsigned int s); void inerDelay_us(unsigned char n); void init_NRF24L01(void); uint SPI_RW(uint uchar); uchar SPI_Read(uchar reg); void SetRX_Mode(void); uint SPI_RW_Reg(uchar reg, uchar value); uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars); uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); //*****************************************长延时***************************************** void Delay(unsigned int s) { unsigned int i,j; while(s--) { for(i=0; i<10; i++); for(j=0; j<12; j++); } } //****************************************************************************************** uint bdata sta; //状态标志 ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; /****************************************************************************************** /*延时函数 /******************************************************************************************/ void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } //**************************************************************************************** /*NRF24L01初始化 //***************************************************************************************/ void init_NRF24L01(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB } /**************************************************************************************************** /*函数:uint SPI_RW(uint uchar) /*功能:NRF24L01的SPI写时序 /****************************************************************************************************/ uint SPI_RW(uint uchar) { uint bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI uchar = (uchar << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. uchar |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(uchar); // return read uchar } /**************************************************************************************************** /*函数:uchar SPI_Read(uchar reg) /*功能:NRF24L01的SPI时序 /****************************************************************************************************/ uchar SPI_Read(uchar reg) { uchar reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /****************************************************************************************************/ /*功能:NRF24L01读写寄存器函数 /****************************************************************************************************/ uint SPI_RW_Reg(uchar reg, uchar value) { uint status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status uchar } /****************************************************************************************************/ /*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数 /****************************************************************************************************/ uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status uchar for(uchar_ctr=0;uchar_ctr CSN = 1; return(status); // return nRF24L01 status uchar } /********************************************************************************************************* /*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数 /*********************************************************************************************************/ uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; //SPI使能 status = SPI_RW(reg); for(uchar_ctr=0; uchar_ctr CSN = 1; //关闭SPI return(status); // } /****************************************************************************************************/ /*函数:void SetRX_Mode(void) /*功能:数据接收配置 /****************************************************************************************************/ void SetRX_Mode(void) { CE=0; SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 CE = 1; inerDelay_us(130); } /******************************************************************************************************/ /*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) /*功能:数据读取后放如rx_buf接收缓冲区中 /******************************************************************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) { unsigned char revale=0; sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况 if(RX_DR) // 判断是否接收到数据 { CE = 0; //SPI使能 SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1; //读取数据完成标志 } SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志 return revale; } /*********************************************************************************************************** /*函数:void nRF24L01_TxPacket(unsigned char * tx_buf) /*功能:发送 tx_buf中数据 /**********************************************************************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC,主接收 CE=1; //置高CE,激发数据发送 inerDelay_us(10); } //************************************主函数************************************************************ void main(void) { unsigned char tf =0; unsigned char TxBuf[20]={0}; // unsigned char RxBuf[20]={0}; init_NRF24L01(); led0=0;led1=0;led2=0;led3=0; P0=0x00; TxBuf[1] = 1; TxBuf[2] = 1; nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data Delay(6000); P0=0xBF; while(1) { if(KEY1 ==0 ) { Delay(15); if(KEY1==0) { P0=seg[1]; TxBuf[1] = 1; tf = 1; } while(!KEY1); } if(KEY2 ==0 ) { Delay(15); if(KEY2 ==0 ) { P0=seg[2]; TxBuf[2] =1; tf = 1; } while(!KEY2); } if (tf==1) { nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data TxBuf[1] = 0x00; TxBuf[2] = 0x00; tf=0; Delay(1000); } //*********************************************************************************************** SetRX_Mode(); nRF24L01_RxPacket(RxBuf); if(RxBuf[1]||RxBuf[2]) { if( RxBuf[1]==1) { P0=seg[3]; } if( RxBuf[2]==1) { P0=seg[4]; } Delay(1000); } RxBuf[1] = 0x00; RxBuf[2] = 0x00; } }
8个回答
程序真长。好好看看吧
正在学习中
这个程序很明显 是发射接收一体程序 还分什么接收发射啊!
uint SPI_RW(uint uchar) { uint bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI uchar = (uchar << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. uchar |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(uchar); // return read uchar } 这个段程序要加延时,长短没关系但是用、没用不行的,具体还要看你的,硬件,什么上拉电阻加了没,你这个程序用的是中断,非查询方式,***it IRQ =P3^2; 这句话说明了是用中断的方式,先用逻辑分析仪看一下时序是否正确,再用示波器测一下IRQ这个引脚的波形。这个程序基本没什么问题 检测一下电路吧! |
好的,谢谢你的解答 |
我在修改一下看看能否实现 |
《DNESP32S3使用指南-IDF版_V1.6》 第十六章 WATCH_DOG实验
460 浏览 0 评论
【敏矽微ME32G070开发板免费体验】+ADC测试与LED点亮
418 浏览 0 评论
飞凌嵌入式-ELFBOARD ELF 2的硬件知识分享--核心板
352 浏览 0 评论
【敏矽微ME32G070开发板免费体验】\\+Lora通信终端产品开发项目
514 浏览 0 评论
1576 浏览 0 评论
11971 浏览 31 评论
GMT+8, 2024-12-19 02:13 , Processed in 1.942658 second(s), Total 88, Slave 68 queries .
