本帖最后由 tutu1583 于 2015-7-22 19:31 编辑 顶层文件: module auto_machine(clk,clk1,reset,one_rmb,half_rmb,call,half_out,out,state,sel,disply); input clk,clk1,reset;//clk为自动售货机的基准时钟,clk1为数码管显示扫描时钟 input one_rmb,half_rmb; //代表1元和5角 output reg call,half_out,out; //提示取物,找零和输出物品 output reg[2:0]state; //各种投币情况 output reg[6:0]disply; //数码管的七段数据 output reg sel; //选择数码管 parameter idle = 0, //idle空闲状态 half =1, //half投入硬币总钱数为5角状态 one =2, //one投入硬币总钱数为1元状态 one_half =3, //one_half投入硬币总钱数为1.5元状态 two =4; //two投入硬币总钱数为2元状态 always @(posedge clk) begin if(reset) begin state =idle;out=0; half_out=0;call=0; end case (state) idle : if(half_rmb) state = half; else if(one_rmb) state = one; half: if(half_rmb) state =one; else if(one_rmb) state =one_half; one: if(half_rmb) state= one_half; else if(one_rmb) state =two; one_half: if(half_rmb) state= two; else if(one_rmb) begin out =1; //售出物品 call=1; //提示取物 state=idle; end two: if(half_rmb) begin out=1; call=1; state=idle; end else if(one_rmb) begin state =idle ; out =1; //售出物品 call=1; //提示取物 half_out=1; //找零 end endcase end reg [3:0] disply0,disply1; //总价钱的高,低2个BCD数据 reg [4:0] sum; //统计投币的总价钱 always @(posedge clk) begin if(half_rmb) sum=sum+5; //统计投币总钱数 else if(one_rmb) sum=sum+10; else sum=sum; if(sum>=30) begin //将总钱数转换成2个BCD码 disply0 =0; disply1 =3; end else if(sum>=20) begin disply0 =sum-20; disply1 =2; end else if(sum>=10) begin disply0 <=sum-10; disply1 <=1; end else begin disply0 =sum; disply1 =0; end end reg [3:0] d; //将总价钱分为2个BCD码的寄存器 always @(posedge clk1) begin if(sel<1) sel =sel+1; //扫描数码管,即选择数码管 else sel =0; case (sel) //将显示数码传给相应的数码管 0:d=disply1; 1:d=disply0; default:d=4'bx; endcase end always @(d) begin //译码 case(d) 0:disply =7'b1111110; //7E 1:disply =7'b0110000; //30 2:disply =7'b1101101; //6D 3:disply =7'b1111001; //79 4:disply =7'b0110011; //33 5:disply =7'b1011011; //5B 6:disply =7'b1011111; //5F 7:disply =7'b1110000; //70 8:disply =7'b1111111; //7F 9:disply =7'b1111011; //7B default:disply =7'bx; endcase end endmodule testbench: `timescale 1ns/1ps module auto_machine_tb(); reg clk;//clk为自动售货机的基准时钟 reg clk1;//clk1为数码管显示扫描时钟 reg reset; reg one_rmb;//代表1元 reg half_rmb;//代表5角 wire call; wire half_out; wire out; wire [2:0]state; wire [6:0]disply; wire sel; auto_machine i1(.clk(clk), .clk1(clk1), .reset(reset), .one_rmb(one_rmb), .half_rmb(half_rmb), .call(call), .half_out(half_out), .out(out), .state(state), .sel(sel), .disply(disply) ); initial clk =0; //clk always #10 clk =~clk; initial clk1 =0; //clk1 always #40 clk1 =~clk1; initial begin //reset reset =1; #100; reset=0; #400; reset=1; #100; reset=0; #275; reset=1; #100; reset=0; #300; reset=1; #100; reset=0; #400; $stop; end initial begin //half_rmb half_rmb=0; #100; half_rmb=1; #200; half_rmb=0; #100; half_rmb=1; #100; half_rmb=0; #100; half_rmb=1; #75; half_rmb=0; #700; half_rmb=1; #200; half_rmb=0; #200; $stop; end initial begin //one_rmb one_rmb=0; #300; one_rmb=1; #100; one_rmb=0; #275; one_rmb=1; #200; one_rmb=0; #100; one_rmb=1; #300; one_rmb=0; #300; one_rmb=1; #200; $stop; end endmodule 问题:1. 波形图:
4个回答
你说的两个问题,都是你跨时钟域产生的,而且出现modelsim中红色的送不定值,不建议送不定值,给高组值也比这个要好得多的;建议从新规划一下代码,别按照C风格来搞
我发现这是一个神奇的器件
学习了。。。。。。。。。。。
464 浏览 0 评论
430 浏览 0 评论
1533 浏览 0 评论
972 浏览 0 评论
911 浏览 0 评论
4448 浏览 63 评论
GMT+8, 2025-12-4 14:16 , Processed in 0.830791 second(s), Total 81, Slave 62 queries .
2145
