单片机型号 atmega8,升压芯片固定输出3.3V ,VBB小于2.3V时 单片机不工作,大于2.3V时 运行正常。 百思不得其解!! !
5个回答
你确定VBB小于2.3V的时候正常工作,如果输出还是3.3V,正常工作的话,你可以检查一下你的熔丝位设置,BOD位,看看掉电检测设置是不是有问题。
我说的正常工作指的是升压芯片
夏至198811 发表于 2015-5-12 14:33 BOD 掉电检测怎么设置呢 我的 BODLEVEL 为1 BODEN 为0 |
我帮你看了一下ATmega8的数据手册,你可以看附件我的截图,加上下面的描述,里面讲到你设置BODLEVEL=1的话,在2.4V左右会掉电,进入reset,所以你想提高工作电压就把BODLEVEL设为0,BODEN是使能位,0表示开启。
1. The Power-on Reset will not work unless the supply voltage has been below VPOT (falling) 2. VBOT may be below nominal minimum operating voltage for some devices. For devices where this is the case, the device is tested down to VCC = VBOT during the production test. This guarantees that a Brown-out Reset will occur before VCC drops to a voltage where correct operation of the microcontroller is no longer guaranteed. The test is performed using BODLEVEL = 1 for ATmega8L and BODLEVEL = 0 for ATmega8. BODLEVEL = 1 is not applicable for ATmega8
793 浏览 0 评论
996 浏览 0 评论
2078 浏览 1 评论
1398 浏览 1 评论
2551 浏览 1 评论
GMT+8, 2025-12-12 02:46 , Processed in 0.954941 second(s), Total 84, Slave 65 queries .
963
