如果能用VR来调节速度就更好了,刚开始学习,望各位前辈多多指教 #include #define LED1_8 P0 //左8个LED,起始P0.0对应LED1,依次对应 #define LED9_16 P2 //右8个LED,起始P2.0对应LED9,依次对应 #define _7SEG P1 //7段数码管 #define KEYBOARD P3 //键盘 #define uchar unsigned char #define uint unsigned int uint code SpeedCode[]={1,3,5,7,10,14,18,23,27,32,40,50,65,80,100,120,140,170,200,280,320,360,400,500,600,700,800,900,1000}; //速度码 uchar code LEDDisplayCode[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F}; //7段共阴数码管0-8字码 //uchar code LEDDisplayCode[]={0x40,0x79,0x2B,0x30,0x19,0x12,0x02,0x78,0x00}; //7段共阳数码管0-8字码 uchar mode; uint count,systemSpeed,speedNum,index; bit direction,flag; void Delay1ms(uint num)//num ms 延时函数 { uint i,j; for(i=0;i } void Display(uchar Value) //数码管驱动函数 { _7SEG=LEDDisplayCode[Value]; } uchar KeyScan(void) //键盘读入函数 { uchar check1,check2,key=0x00; check1=KEYBOARD&0x07; //第一次读键盘值 if(check1==0x07) return 0x00; Delay1ms(10); check2=KEYBOARD&0x07; //第二次读键盘值 if(check2=check1) //若两次值相同,无键按下,返回0值 return 0x00; if(!(check1&0x01)) //key1键按下 key|=0x01; if(!(check1&0x02)) //key2键按下 key|=0x02; if(!(check1&0x04)) //key3键按下 key|=0x04; return key; //返回键值 } void LEDShow(uint LEDStatus) { LED1_8=~(LEDStatus&0x00FF); LED9_16=~((LEDStatus>>8)&0x00FF); } void Timer1(void)interrupt 3 //T1 interrupt service routine { if(++count>=systemSpeed) //*利用计数1000次,使用12M晶振时等同计时1ms,当 //中断次数小于systemSpeed次数时,保持原有跑马运行模式不变,仅当 // 中断次数超过systemSpeed次数时才改变一次跑马运行模式,同时systemSpeed //置0,这就避免了过多使用延时函数,既造成了CPU的资源浪费,又使按键失灵 //的弊端 */ { count=0; if(mode==0x00) //模式0:一个灯亮从左到右跑 { LEDShow(0x0001< } else if(mode==0x01) //模式1:一个灯亮从右到左跑 { LEDShow(0x8000>>index); index=(index+1)%16; } else if(mode==0x02) //模式2:一个灯先从左到右再从右到左 { if(direction) LEDShow(0x0001< LEDShow(0x8000>>index); if(index==15) direction=!direction; index=(index+1)%16; } else if(mode==0x03) //模式3:全亮后逐个灭,先左右,后右左,然后全部灭逐个亮,先右左,后左右 { if(direction) { if(flag) LEDShow(0xFFFE< LEDShow(~(0x7FFF>>index)); } else { if(flag) LEDShow(0x7FFF>>index); else LEDShow(~(0xFFFE< if(index==15) { direction=!direction; if(direction) flag=!flag; } } } TH1=0xFC; TL1=0x18; //重载初值 } void main(void) { uchar key; /******************************************************/ mode=0x00; count=0; index=0; direction=1; flag=1; speedNum=12; //初始速度 LED1_8=0x00; LED9_16=0x00; _7SEG=0xFF; Delay1ms(1000); LED1_8=0xFF; LED9_16=0xFF; _7SEG=0x00; KEYBOARD=0xFF; systemSpeed=SpeedCode[speedNum]; Display(mode); /******************************************************/ TMOD =0x10; //T1模式 TH1=0xFC; TL1=0x18; //计数1000个脉冲 ET1=1; //允许T1中断 EA=1; //开总中断 TR1=1; //开T1中断 /******************************************************/ while(1) //死循环不断的读按键的状态,并按键值响应相关状态跑马花样 { key=KeyScan(); if(key!=0x00) { if(key&0x01) { direction=1; index=0; flag=1; mode=(mode+1)%4; //9中模式循环 Display(mode); } if (key&0x02) { if(speedNum>0) { speedNum--; systemSpeed=SpeedCode[speedNum]; } } if(key&0x04) { if(speedNum<30) { speedNum++; systemSpeed=SpeedCode[speedNum]; } } } } }
6个回答
程序逻辑很清晰,这样看不出问题,你检查是不是硬件电路的问题没?
定时器中断里面重装初值不是应在中断一开始就重装吗。。。
按键未能启动。。。。。。。。。。。。。。。。。。。。。。。。。。。。
506 浏览 0 评论
607 浏览 0 评论
837 浏览 0 评论
832 浏览 0 评论
768 浏览 0 评论
17058 浏览 31 评论
GMT+8, 2025-12-14 06:54 , Processed in 0.753196 second(s), Total 83, Slave 64 queries .
7357
