`这是一个Altium公司针对AD2010推出的PCB教程 总目录如下,有一定英文基础的,都能看懂,我就不多介绍了,谢谢大家的支持。 也非常大家一起共享资源,共同交流,一起进步!祝各位发烧友们好运!!谢谢!!! Module 1: Getting Started With Altium Designer 1.1 Introduction to Altium Designer .........................................................................................1-1 1.2 The Altium Designer environment.....................................................................................1-2 1.3 Document Editor Overview................................................................................................1-6 1.4 Working with projects and documents ............................................................................1-10 Module 2: Help and DXP system menu 2.1 Using the Help system.......................................................................................................2-1 2.2 Using the Altium website ...................................................................................................2-3 2.3 DXP System menu...........................................................................................................2-10 Module 3: Schematic Editor Basics 3.1 Schematic Editor basics ....................................................................................................3-1 3.2 Schematic graphical objects..............................................................................................3-4 3.3 Schematic electrical objects ..............................................................................................3-9 Module 4: Schematic Capture 4.1 Introduction to Schematic Capture....................................................................................4-1 4.2 The Schematic Editor workspace......................................................................................4-2 4.3 Libraries and components .................................................................................................4-9 4.4 Placing and wiring............................................................................................................4-17 Module 5: Multi-Sheet Design 5.1 Multi-Sheet Design.............................................................................................................5-1 Module 6: Building the Project 6.1 Assigning designators........................................................................................................6-1 6.2 Compiling and verifying the project ...................................................................................6-5 Module 7: Setting Up for Transfer to PCB and Importing Data 7.1 Setting Up for Transfer to PCB..........................................................................................7-1 Module 8: PCB Editor Basics 8.1 PCB Editor Basics..............................................................................................................8-1 8.2 PCB design objects............................................................................................................8-4 Module 9: Setting up the PCB 9.1 Setting up the PCB.............................................................................................................9-1 9.2 Creating a new PCB ..........................................................................................................9-6 9.3 Setting up the PCB layers................................................................................................9-10 Module 10: Global Editing 10.1 Editing Multiple Text Objects ...........................................................................................10-1 10.2 The Data Editing System.................................................................................................10-4 Module 11: PCB Design Flow, Transferring a Design and Navigation 11.1 PCB design process ........................................................................................................11-1 11.2 Transferring design information to the PCB......................................................................11-3 11.3 Using the PCB Panel .......................................................................................................11-7 11.4 Project Navigation and Cross Probing..........................................................................11-16 Module 12: Design Rules 12.1 Design rules and design rule checking ...........................................................................12-1 Module 13: Classes and Rooms 13.1 Object classes..................................................................................................................13-1 13.2 Rooms ..............................................................................................................................13-3 Module 14: Placement and Re-annotation 14.1 Component Placement tools ...........................................................................................14-1 14.2 Re-Annotation and back annotate...................................................................................14-3 Module 15: Schematic Library Editor 15.1 Introduction to Library Editing..........................................................................................15-1 15.2 Schematic Library Editor..................................................................................................15-2 Module 16: PCB Library Editor 16.1 PCB Library Editor ...........................................................................................................16-1 16.2 3D dimensional component detail.................................................................................16-14 Module 17: Linking Models, Parameters, Library Package and Updates 17.1 Adding Model and Parameter Detail to a Component ..................................................17-1 17.2 Component Auditing ........................................................................................................17-8 17.3 3D PCB Components ....................................................................................................17-14 17.4 Library Package types ...................................................................................................17-18 17.5 Library Reports...............................................................................................................1 7-20 Module 18: Routing and Polygons 18.1 Routing .............................................................................................................................18-1 18.2 Testpoint System ...........................................................................................................18-10 18.3 Adding and removing teardrops....................................................................................18-15 18.4 Automatic routing ...........................................................................................................18-16 18.5 Polygons and the Polygon Manager.............................................................................18-19 Module 19: Output Generation and CAM File Editing 19.1 Bill of Materials .................................................................................................................19-1 19.2 Output Generation............................................................................................................19-8 19.3 CAM Editor .....................................................................................................................19-20 Module 20: Interfacing to 3D Mechanical CAD 20.1 Interfacing to 3D Mechanical CAD..................................................................................20-1 `
Altium_Designer_官方培训教材(合集).pdf
(17.6 MB, 下载次数: 3912
174 个讨论
有中文版的就更好了
845 浏览 0 评论
2085 浏览 0 评论
1259 浏览 0 评论
771 浏览 0 评论
1963 浏览 0 评论
GMT+8, 2025-12-3 23:26 , Processed in 1.256279 second(s), Total 86, Slave 74 queries .
15022
