/*Include---------------------------*/
#include"STM32f10x_lib.h" //包含所有的头文件 #include //----------------函数声明-------------------- void Delay_MS(u16 dly); void delay_us(u16 dly1); void RCC_Configuration(void); void GPIO_Configuration(void); unsigned long Read_HX711(void); void USART_Configuration(void); int fputc(int ch,FILE *f); int GetKey (void); USART_InitTypeDef USART_InitStructure; ErrorStatus HSEStartUpStatus; /******************************************************************************* * Function Name : main * Description : Main program. * Input : None * Output : None * Return : None *******************************************************************************/ int main(void) { u32 weigh1; float weigh2; #ifdef DEBUG debug(); #endif //------------初始化------------ RCC_Configuration(); GPIO_Configuration(); USART_Configuration( ); while(1) { Delay_MS(1000); weigh2=Read_HX711(); weigh2=weigh2/83886.08; weigh1=weigh2*2000; GPIO_SetBits(GPIOA,GPIO_Pin_11); printf("%dn",weigh1); } } /******************************************************************************* * Function Name : Delay_Ms * Description : delay 1 ms. * Input : dly (ms) * Output : None * Return : None *******************************************************************************/ void Delay_MS(u16 dly) { u16 i,j; for(i=0;i } void delay_us(u16 dly1) { u16 i; for(i=dly1;i>0;i--); } /******************************************************************************* * Function Name : Delay_Ms * Description : Read weigh * Input : None * Output : None * Return : None *******************************************************************************/ unsigned long Read_HX711(void) //读HX711芯片输出的数据。 { unsigned long val = 0; unsigned char i = 0; GPIO_SetBits(GPIOB,GPIO_Pin_11); //DOUT=1 GPIO_ResetBits(GPIOB,GPIO_Pin_12); //SCK=0 while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_11)); //等待DOUT=0 delay_us(1); for(i=0;i<24;i++) { GPIO_SetBits(GPIOB,GPIO_Pin_12); //SCK=1 val=val<<1; delay_us(1); GPIO_ResetBits(GPIOB,GPIO_Pin_12); //SCK=0 if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_11)) //DOUT=1 val++; delay_us(1); } GPIO_SetBits(GPIOB,GPIO_Pin_12); delay_us(1); GPIO_ResetBits(GPIOB,GPIO_Pin_12); delay_us(1); return val; } /******************************************************************************* * Function Name : RCC_Configuration * Description : Configures the different system clocks. * Input : None * Output : None * Return : None *******************************************************************************/ void RCC_Configuration(void) { //----------使用外部RC晶振----------- RCC_DeInit(); //初始化为缺省值 RCC_HSEConfig(RCC_HSE_ON); //使能外部的高速时钟 while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET); //等待外部高速时钟使能就绪 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); FLASH_SetLatency(FLASH_Latency_2); RCC_HCLKConfig(RCC_SYSCLK_Div1); //HCLK = SYSCLK RCC_PCLK2Config(RCC_HCLK_Div1); //PCLK2 = HCLK RCC_PCLK1Config(RCC_HCLK_Div2); //PCLK1 = HCLK/2 RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9); //PLLCLK = 8MHZ * 9 =72MHZ RCC_PLLCmd(ENABLE); //Enable PLLCLK while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLLCLK is ready RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock while(RCC_GetSYSCLKSource()!=0x08); //Wait till PLL is used as system clock source //---------打开相应外设时钟-------------------- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE); //使能APB2外设的GPIOA的时钟 //开启串口时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); } /******************************************************************************* * Function Name : GPIO_Configuration * Description : 初始化GPIO外设 * Input : None * Output : None * Return : None *******************************************************************************/ void GPIO_Configuration(void) { //CLK:PB5 CLR:PE11 Data:PE10 GPIO_InitTypeDef GPIO_InitStructure; //声明一个结构体变量 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; //选择PC.10(TXD) 和 PC.11 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管脚频率为50MHZ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //输出模式为推挽输出 GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PB5 //配置USART1_Tx为复合推挽输出 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); //配置 USART1_Rx 为浮空输入 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //选择PC.10(TXD) 和 PC.11 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PB5 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管脚频率为50MHZ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PB5 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //选择PC.10(TXD) 和 PC.11 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管脚频率为50MHZ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PB5 } /******************************************************************************* * Function Name : USART_Configuration * Description : 设置串口USART1 * Input : ch,*f * Output : None * Return : None *******************************************************************************/ void USART_Configuration(void) { //串口配置: 波特率 115200 数据位 8 停止位 1 奇偶位 NONE USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No ; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //初始化串口 USART_Init(USART1, &USART_InitStructure); //启动串口 USART_Cmd(USART1, ENABLE); } /******************************************************************************* * Function Name : fputc * Description : 重定向这个C库(stdio)printf函数 文件流——》串口USART1 * Input : ch,*f * Output : None * Return : None *******************************************************************************/ int fputc(int ch, FILE *f) { USART_SendData(USART1, (unsigned char) ch);// USART1 可以换成 USART2 等 while (!(USART1->SR & USART_FLAG_TXE)); return (ch); } // 接收数据 int GetKey (void) { while (!(USART1->SR & USART_FLAG_RXNE)); return ((int)(USART1->DR & 0x1FF)); } |
传感器用的是8Kg 2.0mV/V的如果其它规格,更改转换公式即可。
检测参数通过串口发送的电脑。 可以做程序在电脑上直接显示。 串口选用USART1 PB11接HX711数据口浮空输入 PB12接HX711CLK PA11为测试程序时用过的。可删除 HX711输入电子称电压调称为22K 10K 调压为4V输出 输出结果最后一位为0.1g |
你好,请问一下我要将测得的体重数据通过数码管显示出来,需要用串口通信吗 |
串口通信搞通了,就是主函数里面除以83886.08和乘以2000不懂怎么算的,我制作的是最大两百千克(4个50kg传感器)的电子称,一直显示不出数据,望指导一下
帅哥。。。。。。。求指教呀!!我在做人体秤。。。。。不知道怎么搞的,压力传感器的桥式接法,,,,,好像不对。我需要4个50KG的传感器,,,,,
你好,我现在做的项目用到了HX711称重的,但是我不会经过采集后转换成实际的公斤值,求助下 我的QQ1003810886
请问下大家,我用的是含HX711的称重AD模块,一头接的STM32 一头接称重传感,串口检测到的数据不会变化是怎么回事??
我也一直检测不到数据变化,程序一直停在while(dout),你解决这个问题了么 |
STM32CUBEMX(13)--SPI,W25Q128外部Flash移植
1134 浏览 0 评论
OV7670摄像头使用串口发送数据到另一个板子上的lcd,出现花屏
1520 浏览 1 评论
849 浏览 0 评论
720 浏览 0 评论
866 浏览 0 评论
浏览过的版块 |
GMT+8, 2024-10-5 21:53 , Processed in 0.941825 second(s), Total 110, Slave 92 queries .
