DS-5 v5.17.1 官方开发工具 Linux 32位 - 软件 - 电子技术论坛 - 最好最受欢迎电子论坛!
芒果冰 ( 楼主 ) 2014-10-15 11:56:46  只看该作者 倒序浏览
分享网盘下载地址:http://pan.baidu.com/s/1bnm03Yf
这个版本是ARM官方DS-5 5.17.1 Linux 32位开发工具,请在Linux 32位系统上安装使用。
ARM DS-5 Development Studio v.5.17.1 build 5171010 dated 2014/01/23
DS-5 5.17.1 版本更新记录如下:
  • ARM Compiler
    • updated to ARM Compiler 5.04 for latest improvements and bug fixes
    ARM Streamline Performance Analyzer
    • Memory Used chart now filterable by process
    • processes view in Live and Timeline shows per-process %CPU and Memory Used statistics
    • for Cortex-M/ITM captures, exceptions/interrupts are integrated into the scheduler trace heatmap
    • for Cortex-M/ITM captures, additional exception statistics are available via the Exceptions table
    • for Cortex-M/ITM captures, support added for ASCII annotations
    • combined .apc/.apd files into a single container
    • support added for the RT-Preempt Full kernel
    • Kconfig now ships with the gator driver to allow easy integration into the Linux build system
    • Caiman open sourced and the Caiman protocol defined and shipped with DS-5 located in/sw/energy_probe
    • Gator supports filmstrip for Mali-T6xx GPUs - requires Mali-T6xx DDK r4p0
    • Gator, Caiman, and Streamline support IPv6 addresses
    • CCN-504 supported
    DS-5 Debugger
    • added OS awareness for Micrium® μCOS-II® on Cortex-M family devices
    • MQX operating system support is enhanced with visibility of Real-Time TCP/IP Communication Suite (RTCS) state
    • breakpoints in C and assembly code now track changes to source code
    • Trace Control view provides a menu option for dumping trace data to a file
    • new commands trace list/info/dump/report provide access to trace information from the command line
    • Trace Control view shows the relationship between trace source and trace capture devices
    • cdbimporter tool is enhanced to support System Trace Macrocell (STM) as well as AHB and AXI address spaces
    • Eclipse preferences for Configuration Database is enhanced with Test Platforms dialog to allow checking the validity of platforms
    • register set for Cortex-A15 is updated based on the latest technical reference manual (Cortex-A15 r4p0), and now includes Performance Monitor Unit (PMU) registers
    • register set is added for CoreLink CCN-504 Cache Coherent Network
    • standalone version of Debug and Trace Services Layer (DTSL) included in /sw/DTSL
    • standalone version of Remote Device Debug Interface (RDDI) included in/sw/debugger/RDDI
    • device support extended to include:
      • Cortex-M Prototyping System / Cortex-M0: DSTREAM and RealView-ICE support
      • Cortex-M Prototyping System / Cortex-M0+: DSTREAM and RealView-ICE support
      • Cortex-M Prototyping System / Cortex-M1: DSTREAM and RealView-ICE support
      • Cortex-M Prototyping System / Cortex-M3: DSTREAM and RealView-ICE support
      • Cortex-M Prototyping System / Cortex-M4: DSTREAM and RealView-ICE support
      • Versatile_Express_V2P-CA15_A7: Snapshot View
      • CALAO Systems: Snowball - Snapshot View
    • bug fixes and improvements:
      • support for debugging Linux kernel with Large Physical Address Extension (LPAE) turned on: the debugger was unable to read the details of loaded kernel modules, generating Debug Precise Abort errors [SDDEBUG-14760]
      • support for L2C-310 on Cortex-A9 systems: DSTREAM firmware will perform maintenance on L2 cache if L2 cache is enabled, but some cores have disabled MMUs [SDDEBUG-14156]
      • extended DSTREAM DHCP support to fix compatibility issues with some firewalls: some routers require the 'secs' field to be set in BOOTP request [SDDEBUG-15492]
    DSTREAM/RVI
    • new 4.16.0 version of firmware included
    Examples
    • a flash programming example flash_example-FVP-A9x4 in the Bare-metal_examples.zip shows two ways of programming flash devices using DS-5: using a Keil Flash Method and using a Custom Flash Method written in Jython
    • new examples in CoreSight_Access_Library.zip demonstrate how to configure and access CoreSight hardware from Linux applications, and how to later process that data in DS-5 Debugger
    • new bare-metal boards example: Atmel-ATSAMA5D35-EK_RAM
以下为测试功能:
  • ARM Streamline Performance Analyzer
    • Streamline can now analyse Cortex-M targets using DSTREAM, ITM and DWT with an RTOS such as RTX
    DS-5 Debugger
    • new Linux application rewind feature allows you to seamlessly run and step backwards, use breakpoints and watchpoints (on supported kernels and targets) and examine the state of your application at any point in the past
以下功能在以后版本中将会删除:
  • Minimum supported Java version
    • use of Java 6 is deprecated for running ARM's Eclipse plug-ins, and future releases of DS-5 will ship with Java 7 and require this as the minimum supported version
    Simulation models
    • Cortex-A8 simulation model for Emulation Baseboard is deprecated
    Supported host platforms
    • support for Ubuntu Desktop Edition 10.04 LTS is deprecated
0个回复
站长推荐上一条 /9 下一条
GMT+8, 2025-12-4 04:33 , Processed in 0.951027 second(s), Total 63, Slave 44 queries .
