毛刺(0.3us左右)怎么去掉啊
用PWM发送一串数据 data=0x12345678,前面有一段引导码,我写的程序 主函数 #define Te 400 #define getbit( b, n) (((b) & (1L< dword d=0x12345678; void Lead_code(void); int main(void) { // u16 led0pwmval=0; // u8 dir=1; int i; SystemInit(); delay_init(72); //延时初始化 NVIC_Configuration(); uart_init(9600); LED_Init(); KEY_Init(); //按键初始化 // PWM_On(863,100); //不分频。PWM频率=72000/900=800hz while(1) { Lead_code(); PWM_On(863,100); for (i=31;i>=0;i--) { if (getbit(d,i)==1) { TIM_SetCompare2(TIM3,300); delay_us(1200); } else { TIM_SetCompare2(TIM3,600); delay_us(1200); } } TIM_SetCompare2(TIM3,0); delay_us(1200*13); } } void Lead_code() { int i; PWM_On(576,100); for (i=0;i<12;i++) { TIM_SetCompare2(TIM3,288); delay_us(2*Te); } TIM_SetCompare2(TIM3,0); delay_us(9*Te); } PWM配置的 void PWM_On(u16 arr,u16 psc) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE); //使能GPIO外设和AFIO复用功能模块时钟使能 //用于TIM3的CH2输出的PWM通过该LED显示 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //设置该引脚为复用输出功能,输出TIM3 CH2的PWM脉冲波形 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //TIM_CH2 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); //GPIO_WriteBit(GPIOA, GPIO_Pin_7,Bit_SET); // PA7上拉 TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值 80K TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值 不分频 TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式 TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位 TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能 TIM_OCInitStructure.TIM_Pulse = 0; //设置待装入捕获比较寄存器的脉冲值 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //输出极性:TIM输出比较极性低 TIM_OC2Init(TIM3, &TIM_OCInitStructure); //根据TIM_OCInitStruct中指定的参数初始化外设TIMx TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable); //使能TIMx在CCR2上的预装载寄存器 TIM_ARRPreloadConfig(TIM3, ENABLE); //使能TIMx在ARR上的预装载寄存器 TIM_Cmd(TIM3, ENABLE); //使能TIMx外设 } |
6个回答
看不懂啊 太乱了
这个不是毛刺 你是程序有问题 所以产生这个
开PWM前将定时器设置成0、或最大值,使这个值处于PWM输出低电平的定时器计数值之中就可以了。
1618 浏览 1 评论
1260 浏览 0 评论
1114 浏览 0 评论
5494 浏览 2 评论
4285 浏览 1 评论
GMT+8, 2025-12-17 18:29 , Processed in 0.701712 second(s), Total 82, Slave 64 queries .
9146
