下面是图和代码,仿真结果,无法放大,数码管不亮,一点反应都没,调了两天,还是没用。求前辈看下,仿真图和代码哪有问题?急用!!
#include #define uint unsigned int #define uchar unsigned char uchar code LEDData[]= { 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f };//共阴数码管 ***it OE=P1^0; ***it EOC=P1^1; ***it ST=P1^2; ***it CLK=P1^3; ***it K1=P2^6; ***it K2=P2^7; void DelayMS(uint ms) { uchar i; while(ms--) { for(i=0;i<120;i++); } } void Display_Result(uchar d) { P2=0xf8; P0=LEDData[d%10]; DelayMS(5); P2=0xf4; P0=LEDData[d%100/10]; DelayMS(5); P2=0xf2; P0=LEDData[d/100]; DelayMS(5); } void AD() { ST = 0; ST = 1; ST = 0; while(EOC == 0); OE = 1; Display_Result(P3); OE = 0; } void kz() { if(K1==0) { DelayMS(5); while(!K1); P3=P3+5; } if(K2==0) { DelayMS(5); while(!K2); P3=P3-5; } } void main() { TMOD=0x01; TH0=(65536-4000)/256; TL0=(65536-4000)%256; EA=1; ET0=1; TR0=1; P1=0x3f; while(1) { AD(); kz(); } } void timer0_INT() interrupt 1 { TH0=(65536-4000)/256; TL0=(65536-4000)%256; CLK =!CLK; }
3个回答
复位电路是不是接错了,RST是复位,EA看低电平有效还是高电平有效
1273 浏览 0 评论
1062 浏览 6 评论
1136 浏览 4 评论
992 浏览 4 评论
1858 浏览 1 评论
GMT+8, 2024-10-3 20:59 , Processed in 0.553886 second(s), Total 78, Slave 59 queries .
