用proteus仿真12864液晶显示,在做利用外部中断0控制液晶屏切换图片时,只是第一次按下中断键,图片会切换,而继续按键是液晶显示的图片却不再切换,也就是说图片只切换一次,求解问题出在哪里? #include #include #define Disp_On 0x3f #define Disp_Off 0x3e #define Col_Add 0x40 #define Page_Add 0xb8 #define Start_Line 0xc0 /*********************************端口定义**********************************/ ***it Mcs=P2^3; //左半屏使能,当MCS=1,左半屏显示 ***it Scs=P2^4; //右半屏使能,当SCS=1,右半屏显示 ***it Enable=P2^2; //使能 ***it Di=P2^0; //数据/命令选择(RS) ***it RW=P2^1; //读/写信号 ***it Rst=P2^5; //复位脚 为什么不连接这个就不能实现显示? ***it Light=P2^6; //背光脚 ***it K1=P3^2; //切换图画键 unsigned char a; void delay(unsigned int t) { unsigned int i,j; for(i=0;i } void write_com(unsigned char cmdcode) { Di=0; RW=0; P0=cmdcode; delay(2); Enable=1; delay(2); Enable=0; } void write_data(unsigned char Dispdata) { Di=1; RW=0; P0=Dispdata; delay(2); Enable=1; delay(2); Enable=0; } void Clr_Scr() { unsigned char j,k; Mcs=1;Scs=1; write_com(Page_Add+0); write_com(Col_Add+0); for(k=0;k<8;k++) { write_com(Page_Add+k); for(j=0;j<64;j++)write_data(0x00); } Mcs=0;Scs=0; } void DIS_picture(unsigned char pag,unsigned char col,unsigned char b, unsigned char hzk[][64]) { unsigned char j=0,i=0; if(b==0) //左屏显示 { for(j=0;j<8;j++) { Mcs=1;Scs=0; write_com(Page_Add+pag+j);//选择显示的页(行) write_com(Col_Add+col); //选择列 for(i=0;i<64;i++) { write_data(hzk[2*j]);//写入数据 } } } else //右屏显示 { for(j=0;j<8;j++) { Scs=1;Mcs=0; write_com(Page_Add+pag+j);//选择显示的页(行) write_com(Col_Add+col); //选择列 for(i=0;i<64;i++) { write_data(hzk[2*j+1]);//写入数据 } } } } void init_lcd() { delay(100); Mcs=1; Scs=1; delay(100); write_com(Disp_Off); write_com(Page_Add+0); write_com(Start_Line+0); write_com(Col_Add+0); write_com(Disp_On); } void display() { switch(a) { case 0x00: { DIS_picture(0,0,0,table1); DIS_picture(0,0,1,table1); delay(10); break; } case 0x01: { DIS_picture(0,0,0,table2); DIS_picture(0,0,1,table2); delay(10); break; } } } void main(void) { a=1; init_lcd(); Clr_Scr(); EA=1; IT0=1; EX0=1; while(1) { display(); } } void init_K1()interrupt 0 { delay(10); if(K1==0) { a=0; } } picture.h unsigned char code table1[][64]= { 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x7F,0x7F,0x3F,0xC7,0x7F,0x7F,0x8F,0xB7,0xBF,0xBF,0xBF,0xBF,0x3F,0xFF,0xF7,0xF7, 0x37,0xB7,0xB7,0x07,0x07,0xB7,0x07,0xB7,0xB7,0xB7,0x37,0xF7,0xFF,0xFF,0xFF,0xFF, 0x07,0xB7,0xB7,0xB7,0xB7,0xB7,0x07,0x07,0xFF,0xFF,0xFF,0xFF,0x37,0xF7,0xF7,0x07, 0x07,0xFF,0x0F,0x4F,0x47,0x47,0x4F,0x4F,0x0F,0x0F,0xFF,0x4F,0x4F,0x4F,0x4F,0x0F, 0x77,0x7F,0x07,0x07,0x7F,0x77,0x4F,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC, 0xFF,0xFF,0x00,0xBC,0xDF,0xDF,0xE3,0xFF,0x00,0xFF,0xFF,0xE3,0x9F,0xFF,0xE7,0xE7, 0xE4,0xA4,0x84,0xA0,0xA0,0x64,0x24,0x44,0x44,0xE4,0xE4,0xE7,0xE7,0xE7,0x67,0x87, 0xA4,0x64,0x64,0x04,0xA4,0xA4,0xA4,0xA4,0xA7,0xE7,0xFF,0xFF,0xB8,0xBB,0xDB,0x00, 0x00,0xBF,0xC0,0x03,0xDB,0xDB,0x03,0xDB,0x03,0x03,0xFF,0xDF,0xDF,0xE7,0xE7,0x00, 0x67,0x7B,0xA0,0xA0,0x9F,0x67,0xFB,0x3F,0x3F,0xFF,0xFF,0x7F,0x7F,0xFF,0xFF,0xFF, 0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFC,0xFF,0xFF,0xFF,0xFD,0xFD,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFD, 0xFD,0xFD,0xFD,0xFD,0xFD,0xFE,0xFE,0xFE,0xFE,0xFD,0xFD,0xFF,0xFD,0xFD,0xFE,0xFF, 0xFF,0xFE,0xFE,0xFC,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFF,0xFF,0xFF,0xFD,0xFD,0xFC, 0xFC,0xFF,0xFF,0xFE,0xFF,0xFF,0xFE,0xFD,0xFC,0xFC,0xFF,0xFF,0xFD,0xFD,0xFD,0xFC, 0xFE,0xFE,0xFF,0xFF,0xFF,0xFE,0xFD,0xFC,0xFC,0xFF,0xFF,0xFE,0xFE,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0x73,0x92,0xE1,0x00,0x00,0x81,0x92,0x73,0xF3,0xF3,0xFF,0xF3,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x1F,0x1F,0x0F,0x0F,0x0F,0x83,0xF3, 0x7F,0x7F,0x7F,0x1F,0x1F,0x1F,0xEF,0xEF,0xFF,0xFF,0x7F,0x7F,0x7F,0x1F,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF, 0xEF,0x9F,0x9F,0x9F,0x7F,0x7C,0xFC,0xFC,0xFC,0xFC,0xFD,0xFD,0xFD,0xE1,0xFF,0x7F, 0x9F,0x9F,0x8F,0x83,0x1F,0x0F,0x0F,0x83,0xE1,0x83,0x0F,0x0F,0x1F,0x00,0x81,0x81, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF6,0xF6,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,0x77,0x0E, 0x01,0x01,0x0F,0x7F,0xFF,0xFF,0x07,0x31,0x08,0xC8,0xC8,0x30,0xC1,0x07,0x7F,0x7F, 0x7F,0x3F,0x07,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x08,0x09,0x09,0x08,0x30,0x00,0x00,0x08,0x07,0x01,0xC0, 0xC0,0xFF,0x01,0x07,0x07,0x07,0x07,0x0F,0x0E,0x0E,0x88,0xB8,0xB1,0x31,0x31,0x01, 0x07,0x07,0x07,0x07,0x0F,0x0F,0x0E,0x38,0x38,0x31,0x41,0x07,0x07,0x07,0x0F,0x3F, 0x7F,0x7F,0xFF,0xFF,0x78,0x3E,0x3E,0x0F,0x8F,0x8F,0x3F,0x3F,0x7F,0xFE,0xFF,0xFF, 0x7F,0x07,0x0F,0xB9,0xB9,0xCF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,0x67,0x1C,0x1C,0x03,0x00,0x00, 0x00,0x00,0x00,0x40,0x60,0x60,0x7F,0x7C,0x38,0xE0,0xE0,0x03,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x18,0x1C,0x1C, 0x1C,0xDC,0xDC,0xFC,0x7C,0x38,0x20,0x20,0x00,0x80,0x40,0x40,0x20,0x18,0x07,0x00, 0x00,0x03,0x1C,0x60,0x80,0x80,0x00,0x00,0x43,0x43,0x80,0x80,0xC0,0xE0,0xE0,0xE0, 0x60,0x60,0x60,0x60,0x60,0x40,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x03,0x07,0x00,0x1C,0x1C,0x23,0x1C,0x80,0xC3,0xC3,0xE0,0xDF,0xC3,0xC3, 0x80,0x00,0x00,0x03,0x03,0x00,0x07,0xDB,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0x3F,0x1D,0x3B,0x00,0x00,0x00,0x00,0xC0,0x20, 0x18,0x18,0x38,0xC4,0x04,0x04,0x04,0x1C,0xE2,0x01,0x01,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x24,0xD8,0x20,0x00,0x04,0x04,0x18,0x20, 0x04,0x05,0x05,0x03,0x00,0x00,0xF8,0xF8,0x06,0x01,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x04,0x18,0x18,0xE1,0x01,0x01,0x07,0x07,0x3F, 0xDC,0xC0,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x21,0x21,0xC1,0x01,0x01,0x01, 0x01,0x02,0x00,0x00,0x00,0x00,0x00,0x01,0xFE,0xFE,0xE7,0xC3,0xE7,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0x93,0xFF,0xFF,0x62,0x00,0x00,0x00,0x00,0xFE,0x01,0x00, 0x00,0x00,0x00,0x00,0x03,0x03,0xFC,0x00,0x00,0x01,0x01,0x02,0x0C,0x0C,0x0C,0x0C, 0x03,0x01,0x01,0xFE,0xFE,0x02,0x0C,0x0C,0x0C,0xFC,0x10,0x10,0x10,0x10,0x10,0x10, 0x10,0x10,0x10,0x0C,0x0C,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x60,0x80,0x80,0x80, 0x00,0x00,0x02,0x02,0x01,0x00,0x00,0x02,0x02,0x8D,0x82,0x80,0x80,0x60,0x60,0x90, 0x7C,0x7C,0x02,0x01,0x03,0x0D,0x0D,0x71,0x83,0x02,0x0C,0x0C,0x00,0x00,0x02,0x02, 0x0C,0x10,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6F,0xF2,0x9F,0x7F,0x7F,0xFF, /* (128 X 64 )*/ }; unsigned char code table2[][64]= { 0x00,0x00,0x78,0x78,0x40,0x40,0x80,0x80,0x79,0x79,0x46,0x46,0x06,0x06,0x06,0x06, 0x41,0x41,0x00,0x00,0x00,0x00,0x70,0x70,0x80,0x80,0xFE,0xFE,0x86,0x86,0x78,0x78, 0xC8,0xC8,0x40,0x40,0x87,0x87,0x08,0x08,0x08,0x08,0x00,0x00,0x00,0x00,0x46,0x46, 0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x70,0x80,0x80,0xFE,0xFE,0xFE,0xFE,0x00,0x00, 0xC8,0xC8,0x40,0x40,0x87,0x87,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x78,0x78,0xC6,0xC6,0x36,0x36,0x31,0x31,0x09,0x09,0x0E,0x0E,0x08,0x08, 0x08,0x08,0x08,0x08,0x08,0x08,0x30,0x30,0x30,0x30,0xC0,0xC0,0x70,0x70,0x30,0x30, 0xC0,0xC0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x84,0x84,0x40,0x40,0xD8,0xD8,0x80,0x80,0x00,0x00,0xBF,0xBF,0xC0,0xC0, 0x98,0x98,0x80,0x80,0x80,0x80,0x83,0x83,0x00,0x00,0x03,0x03,0x80,0x80,0x83,0x83, 0x80,0x80,0x84,0x84,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80, 0x80,0x80,0x80,0x80,0x80,0x80,0x83,0x83,0x00,0x00,0x03,0x03,0x03,0x03,0x03,0x03, 0x00,0x00,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xC0,0xC0,0x3F,0x3F,0x98,0x98,0x04,0x04,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00, 0x20,0x20,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x00,0x00,0x20,0x20, 0xE0,0xE0,0x18,0x18,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x06,0x06,0x3F,0x3F,0x38,0x38,0x3F,0x3F,0x39,0x39,0x04,0x04,0xDD,0xDD,0x01,0x01, 0xFF,0xFF,0x01,0x01,0xE1,0xE1,0x1F,0x1F,0x00,0x00,0x04,0x04,0x05,0x05,0xE5,0xE5, 0xFF,0xFF,0x25,0x25,0xE5,0xE5,0x05,0x05,0x04,0x04,0x00,0x00,0x01,0x01,0x01,0x01, 0xF9,0xF9,0x1D,0x1D,0x03,0x03,0x01,0x01,0x00,0x00,0x3C,0x3C,0xFE,0xFE,0x3C,0x3C, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xF8, 0xC7,0xC7,0x20,0x20,0x23,0x23,0xC0,0xC0,0xC0,0xC0,0x00,0x00,0x3C,0x3C,0x00,0x00, 0x00,0x00,0xC1,0xC1,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0x00,0x00,0x00,0x00, 0x01,0x01,0xFE,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x60,0x00,0x00,0x60,0x60,0x10,0x10, 0x1D,0x1D,0x02,0x02,0x1D,0x1D,0x70,0x70,0x60,0x60,0x60,0x60,0x6C,0x6C,0x6F,0x6F, 0x7F,0x7F,0x6D,0x6D,0x6F,0x6F,0x6C,0x6C,0x60,0x60,0x00,0x00,0x00,0x00,0x60,0x60, 0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1D,0x1D,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF, 0x07,0x07,0x1F,0x1F,0x7E,0x7E,0x60,0x60,0x61,0x61,0x1E,0x1E,0x00,0x00,0x00,0x00, 0x00,0x00,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x00,0x00,0x03,0x03,0x03,0x03,0x00,0x00, 0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x37,0x37,0x06,0x06,0x0E,0x0E,0x00,0x00,0x00,0x00,0x79,0x79,0x49,0x49, 0xFF,0xFF,0x49,0x49,0x7F,0x7F,0x79,0x79,0x01,0x01,0x01,0x01,0xCE,0xCE,0xF8,0xF8, 0x48,0x48,0x48,0x48,0xFF,0xFF,0x0F,0x0F,0xC8,0xC8,0x00,0x00,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0x7F,0x7F,0x41,0x41,0x7F,0x7F,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01, 0xF1,0xF1,0x09,0x09,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x98,0x98, 0x59,0x59,0x3E,0x3E,0x88,0x88,0x00,0x00,0x36,0x36,0x37,0x37,0x0F,0x0F,0x0F,0x0F, 0x0F,0x0F,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x40,0x70,0x70,0x4E,0x4E,0x81,0x81, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0x80,0x7B,0x7B,0x44,0x44,0x04,0x04,0x03,0x03,0x00,0x00,0x43,0x43,0x5B,0x5B, 0x5F,0x5F,0x23,0x23,0x3F,0x3F,0x43,0x43,0x03,0x03,0x3F,0x3F,0x40,0x40,0x3F,0x3F, 0x3F,0x3F,0x5F,0x5F,0x3F,0x3F,0x23,0x23,0x78,0x78,0x60,0x60,0x5F,0x5F,0x7F,0x7F, 0x7F,0x7F,0x40,0x40,0x40,0x40,0x78,0x78,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x40, 0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0x1C,0x1C,0xE3,0xE3, 0x58,0x58,0xC7,0xC7,0xA0,0xA0,0xC3,0xC3,0x40,0x40,0x40,0x40,0x40,0x40,0x80,0x80, 0x84,0x84,0x80,0x80,0x80,0x80,0x60,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x3F,0x3F,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x19,0x19,0x00,0x00,0x00,0x00,0x3E,0x3E,0xC0,0xC0,0x18,0x18,0xC0,0xC0,0x20,0x20, 0x20,0x20,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x00,0x00,0x00,0x00, 0xE0,0xE0,0x18,0x18,0x18,0x18,0x20,0x20,0xC0,0xC0,0x00,0x00,0x00,0x00,0x18,0x18, 0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0x18,0x18,0x18,0x18,0xE0,0xE0,0x00,0x00, 0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x3F,0x3F,0xFC,0xFC,0x01,0x01, 0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x02,0x02,0x02,0x02,0x02,0x01,0x01, 0x05,0x05,0x05,0x05,0x05,0x05,0x1E,0x1E,0xE0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x6F,0x6F,0x71,0x71,0x0C,0x0C,0x9C,0x9C,0x61,0x61,0x01,0x01,0x03,0x03,0x0C,0x0C, 0x0E,0x0E,0x00,0x00,0x13,0x13,0x02,0x02,0x0C,0x0C,0x00,0x00,0x00,0x00,0x10,0x10, 0x01,0x01,0x02,0x02,0x03,0x03,0x00,0x00,0x8D,0x8D,0x01,0x01,0x03,0x03,0x80,0x80, 0x00,0x00,0x10,0x10,0x00,0x00,0x01,0x01,0x02,0x02,0x03,0x03,0x80,0x80,0x0D,0x0D, 0x01,0x01,0x02,0x02,0x80,0x80,0x00,0x00,0x00,0x00,0x7F,0x7F,0xF0,0xF0,0xF0,0xF0, 0xE0,0xE0,0xE0,0xE0,0x80,0x80,0x1C,0x1C,0xE0,0xE0,0x80,0x80,0x80,0x80,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x03,0x03,0x7C,0x7C,0x8C,0x8C, 0xEC,0xEC,0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, /* (128 X 64 )*/ } ;
10个回答
无图无代码 神仙也难救
无图无代码,别人是神仙也弄不会
是啊,无图无代码没下文
#include
#include #define Disp_On 0x3f #define Disp_Off 0x3e #define Col_Add 0x40 #define Page_Add 0xb8 #define Start_Line 0xc0 /*********************************端口定义**********************************/ ***it Mcs=P2^3; //左半屏使能,当MCS=1,左半屏显示 ***it Scs=P2^4; //右半屏使能,当SCS=1,右半屏显示 ***it Enable=P2^2; //使能 ***it Di=P2^0; //数据/命令选择(RS) ***it RW=P2^1; //读/写信号 ***it Rst=P2^5; //复位脚 为什么不连接这个就不能实现显示? ***it Light=P2^6; //背光脚 ***it K1=P3^2; //切换图画键 unsigned char a; void delay(unsigned int t) { unsigned int i,j; for(i=0;i } void write_com(unsigned char cmdcode) { Di=0; RW=0; P0=cmdcode; delay(2); Enable=1; delay(2); Enable=0; } void write_data(unsigned char Dispdata) { Di=1; RW=0; P0=Dispdata; delay(2); Enable=1; delay(2); Enable=0; } void Clr_Scr() { unsigned char j,k; Mcs=1;Scs=1; write_com(Page_Add+0); write_com(Col_Add+0); for(k=0;k<8;k++) { write_com(Page_Add+k); for(j=0;j<64;j++)write_data(0x00); } Mcs=0;Scs=0; } void DIS_picture(unsigned char pag,unsigned char col,unsigned char b, unsigned char hzk[][64]) { unsigned char j=0,i=0; if(b==0) //左屏显示 { for(j=0;j<8;j++) { Mcs=1;Scs=0; write_com(Page_Add+pag+j);//选择显示的页(行) write_com(Col_Add+col); //选择列 for(i=0;i<64;i++) { write_data(hzk[2*j][i]);//写入数据 } } } else //右屏显示 { for(j=0;j<8;j++) { Scs=1;Mcs=0; write_com(Page_Add+pag+j);//选择显示的页(行) write_com(Col_Add+col); //选择列 for(i=0;i<64;i++) { write_data(hzk[2*j+1][i]);//写入数据 } } } } void init_lcd() { delay(100); Mcs=1; Scs=1; delay(100); write_com(Disp_Off); write_com(Page_Add+0); write_com(Start_Line+0); write_com(Col_Add+0); write_com(Disp_On); } void display() { switch(a) { case 0x00: { DIS_picture(0,0,0,table1); DIS_picture(0,0,1,table1); delay(10); break; } case 0x01: { DIS_picture(0,0,0,table2); DIS_picture(0,0,1,table2); delay(10); break; } } } void main(void) { a=1; init_lcd(); Clr_Scr(); EA=1; IT0=1; EX0=1; while(1) { display(); } } void init_K1()interrupt 0 { delay(10); if(K1==0) { a=0; } } picture.h unsigned char code table1[][64]= { 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x7F,0x7F,0x3F,0xC7,0x7F,0x7F,0x8F,0xB7,0xBF,0xBF,0xBF,0xBF,0x3F,0xFF,0xF7,0xF7, 0x37,0xB7,0xB7,0x07,0x07,0xB7,0x07,0xB7,0xB7,0xB7,0x37,0xF7,0xFF,0xFF,0xFF,0xFF, 0x07,0xB7,0xB7,0xB7,0xB7,0xB7,0x07,0x07,0xFF,0xFF,0xFF,0xFF,0x37,0xF7,0xF7,0x07, 0x07,0xFF,0x0F,0x4F,0x47,0x47,0x4F,0x4F,0x0F,0x0F,0xFF,0x4F,0x4F,0x4F,0x4F,0x0F, 0x77,0x7F,0x07,0x07,0x7F,0x77,0x4F,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC, 0xFF,0xFF,0x00,0xBC,0xDF,0xDF,0xE3,0xFF,0x00,0xFF,0xFF,0xE3,0x9F,0xFF,0xE7,0xE7, 0xE4,0xA4,0x84,0xA0,0xA0,0x64,0x24,0x44,0x44,0xE4,0xE4,0xE7,0xE7,0xE7,0x67,0x87, 0xA4,0x64,0x64,0x04,0xA4,0xA4,0xA4,0xA4,0xA7,0xE7,0xFF,0xFF,0xB8,0xBB,0xDB,0x00, 0x00,0xBF,0xC0,0x03,0xDB,0xDB,0x03,0xDB,0x03,0x03,0xFF,0xDF,0xDF,0xE7,0xE7,0x00, 0x67,0x7B,0xA0,0xA0,0x9F,0x67,0xFB,0x3F,0x3F,0xFF,0xFF,0x7F,0x7F,0xFF,0xFF,0xFF, 0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFC,0xFF,0xFF,0xFF,0xFD,0xFD,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFD, 0xFD,0xFD,0xFD,0xFD,0xFD,0xFE,0xFE,0xFE,0xFE,0xFD,0xFD,0xFF,0xFD,0xFD,0xFE,0xFF, 0xFF,0xFE,0xFE,0xFC,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFF,0xFF,0xFF,0xFD,0xFD,0xFC, 0xFC,0xFF,0xFF,0xFE,0xFF,0xFF,0xFE,0xFD,0xFC,0xFC,0xFF,0xFF,0xFD,0xFD,0xFD,0xFC, 0xFE,0xFE,0xFF,0xFF,0xFF,0xFE,0xFD,0xFC,0xFC,0xFF,0xFF,0xFE,0xFE,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0x73,0x92,0xE1,0x00,0x00,0x81,0x92,0x73,0xF3,0xF3,0xFF,0xF3,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x1F,0x1F,0x0F,0x0F,0x0F,0x83,0xF3, 0x7F,0x7F,0x7F,0x1F,0x1F,0x1F,0xEF,0xEF,0xFF,0xFF,0x7F,0x7F,0x7F,0x1F,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF, 0xEF,0x9F,0x9F,0x9F,0x7F,0x7C,0xFC,0xFC,0xFC,0xFC,0xFD,0xFD,0xFD,0xE1,0xFF,0x7F, 0x9F,0x9F,0x8F,0x83,0x1F,0x0F,0x0F,0x83,0xE1,0x83,0x0F,0x0F,0x1F,0x00,0x81,0x81, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF6,0xF6,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,0x77,0x0E, 0x01,0x01,0x0F,0x7F,0xFF,0xFF,0x07,0x31,0x08,0xC8,0xC8,0x30,0xC1,0x07,0x7F,0x7F, 0x7F,0x3F,0x07,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x08,0x09,0x09,0x08,0x30,0x00,0x00,0x08,0x07,0x01,0xC0, 0xC0,0xFF,0x01,0x07,0x07,0x07,0x07,0x0F,0x0E,0x0E,0x88,0xB8,0xB1,0x31,0x31,0x01, 0x07,0x07,0x07,0x07,0x0F,0x0F,0x0E,0x38,0x38,0x31,0x41,0x07,0x07,0x07,0x0F,0x3F, 0x7F,0x7F,0xFF,0xFF,0x78,0x3E,0x3E,0x0F,0x8F,0x8F,0x3F,0x3F,0x7F,0xFE,0xFF,0xFF, 0x7F,0x07,0x0F,0xB9,0xB9,0xCF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,0x67,0x1C,0x1C,0x03,0x00,0x00, 0x00,0x00,0x00,0x40,0x60,0x60,0x7F,0x7C,0x38,0xE0,0xE0,0x03,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x18,0x1C,0x1C, 0x1C,0xDC,0xDC,0xFC,0x7C,0x38,0x20,0x20,0x00,0x80,0x40,0x40,0x20,0x18,0x07,0x00, 0x00,0x03,0x1C,0x60,0x80,0x80,0x00,0x00,0x43,0x43,0x80,0x80,0xC0,0xE0,0xE0,0xE0, 0x60,0x60,0x60,0x60,0x60,0x40,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x03,0x07,0x00,0x1C,0x1C,0x23,0x1C,0x80,0xC3,0xC3,0xE0,0xDF,0xC3,0xC3, 0x80,0x00,0x00,0x03,0x03,0x00,0x07,0xDB,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0x3F,0x1D,0x3B,0x00,0x00,0x00,0x00,0xC0,0x20, 0x18,0x18,0x38,0xC4,0x04,0x04,0x04,0x1C,0xE2,0x01,0x01,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x24,0xD8,0x20,0x00,0x04,0x04,0x18,0x20, 0x04,0x05,0x05,0x03,0x00,0x00,0xF8,0xF8,0x06,0x01,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x04,0x18,0x18,0xE1,0x01,0x01,0x07,0x07,0x3F, 0xDC,0xC0,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x21,0x21,0xC1,0x01,0x01,0x01, 0x01,0x02,0x00,0x00,0x00,0x00,0x00,0x01,0xFE,0xFE,0xE7,0xC3,0xE7,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0x93,0xFF,0xFF,0x62,0x00,0x00,0x00,0x00,0xFE,0x01,0x00, 0x00,0x00,0x00,0x00,0x03,0x03,0xFC,0x00,0x00,0x01,0x01,0x02,0x0C,0x0C,0x0C,0x0C, 0x03,0x01,0x01,0xFE,0xFE,0x02,0x0C,0x0C,0x0C,0xFC,0x10,0x10,0x10,0x10,0x10,0x10, 0x10,0x10,0x10,0x0C,0x0C,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x60,0x80,0x80,0x80, 0x00,0x00,0x02,0x02,0x01,0x00,0x00,0x02,0x02,0x8D,0x82,0x80,0x80,0x60,0x60,0x90, 0x7C,0x7C,0x02,0x01,0x03,0x0D,0x0D,0x71,0x83,0x02,0x0C,0x0C,0x00,0x00,0x02,0x02, 0x0C,0x10,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6F,0xF2,0x9F,0x7F,0x7F,0xFF,/*"D:MCUSoftwarePCtoLCD12864液晶图片取模2231.bmp",0*/ /* (128 X 64 )*/ }; unsigned char code table2[][64]= { 0x00,0x00,0x78,0x78,0x40,0x40,0x80,0x80,0x79,0x79,0x46,0x46,0x06,0x06,0x06,0x06, 0x41,0x41,0x00,0x00,0x00,0x00,0x70,0x70,0x80,0x80,0xFE,0xFE,0x86,0x86,0x78,0x78, 0xC8,0xC8,0x40,0x40,0x87,0x87,0x08,0x08,0x08,0x08,0x00,0x00,0x00,0x00,0x46,0x46, 0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x70,0x80,0x80,0xFE,0xFE,0xFE,0xFE,0x00,0x00, 0xC8,0xC8,0x40,0x40,0x87,0x87,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x78,0x78,0xC6,0xC6,0x36,0x36,0x31,0x31,0x09,0x09,0x0E,0x0E,0x08,0x08, 0x08,0x08,0x08,0x08,0x08,0x08,0x30,0x30,0x30,0x30,0xC0,0xC0,0x70,0x70,0x30,0x30, 0xC0,0xC0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x84,0x84,0x40,0x40,0xD8,0xD8,0x80,0x80,0x00,0x00,0xBF,0xBF,0xC0,0xC0, 0x98,0x98,0x80,0x80,0x80,0x80,0x83,0x83,0x00,0x00,0x03,0x03,0x80,0x80,0x83,0x83, 0x80,0x80,0x84,0x84,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80, 0x80,0x80,0x80,0x80,0x80,0x80,0x83,0x83,0x00,0x00,0x03,0x03,0x03,0x03,0x03,0x03, 0x00,0x00,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xC0,0xC0,0x3F,0x3F,0x98,0x98,0x04,0x04,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00, 0x20,0x20,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x00,0x00,0x20,0x20, 0xE0,0xE0,0x18,0x18,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x06,0x06,0x3F,0x3F,0x38,0x38,0x3F,0x3F,0x39,0x39,0x04,0x04,0xDD,0xDD,0x01,0x01, 0xFF,0xFF,0x01,0x01,0xE1,0xE1,0x1F,0x1F,0x00,0x00,0x04,0x04,0x05,0x05,0xE5,0xE5, 0xFF,0xFF,0x25,0x25,0xE5,0xE5,0x05,0x05,0x04,0x04,0x00,0x00,0x01,0x01,0x01,0x01, 0xF9,0xF9,0x1D,0x1D,0x03,0x03,0x01,0x01,0x00,0x00,0x3C,0x3C,0xFE,0xFE,0x3C,0x3C, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xF8, 0xC7,0xC7,0x20,0x20,0x23,0x23,0xC0,0xC0,0xC0,0xC0,0x00,0x00,0x3C,0x3C,0x00,0x00, 0x00,0x00,0xC1,0xC1,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0x00,0x00,0x00,0x00, 0x01,0x01,0xFE,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x60,0x00,0x00,0x60,0x60,0x10,0x10, 0x1D,0x1D,0x02,0x02,0x1D,0x1D,0x70,0x70,0x60,0x60,0x60,0x60,0x6C,0x6C,0x6F,0x6F, 0x7F,0x7F,0x6D,0x6D,0x6F,0x6F,0x6C,0x6C,0x60,0x60,0x00,0x00,0x00,0x00,0x60,0x60, 0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1D,0x1D,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF, 0x07,0x07,0x1F,0x1F,0x7E,0x7E,0x60,0x60,0x61,0x61,0x1E,0x1E,0x00,0x00,0x00,0x00, 0x00,0x00,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x00,0x00,0x03,0x03,0x03,0x03,0x00,0x00, 0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x37,0x37,0x06,0x06,0x0E,0x0E,0x00,0x00,0x00,0x00,0x79,0x79,0x49,0x49, 0xFF,0xFF,0x49,0x49,0x7F,0x7F,0x79,0x79,0x01,0x01,0x01,0x01,0xCE,0xCE,0xF8,0xF8, 0x48,0x48,0x48,0x48,0xFF,0xFF,0x0F,0x0F,0xC8,0xC8,0x00,0x00,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0x7F,0x7F,0x41,0x41,0x7F,0x7F,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01, 0xF1,0xF1,0x09,0x09,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x98,0x98, 0x59,0x59,0x3E,0x3E,0x88,0x88,0x00,0x00,0x36,0x36,0x37,0x37,0x0F,0x0F,0x0F,0x0F, 0x0F,0x0F,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x40,0x70,0x70,0x4E,0x4E,0x81,0x81, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0x80,0x7B,0x7B,0x44,0x44,0x04,0x04,0x03,0x03,0x00,0x00,0x43,0x43,0x5B,0x5B, 0x5F,0x5F,0x23,0x23,0x3F,0x3F,0x43,0x43,0x03,0x03,0x3F,0x3F,0x40,0x40,0x3F,0x3F, 0x3F,0x3F,0x5F,0x5F,0x3F,0x3F,0x23,0x23,0x78,0x78,0x60,0x60,0x5F,0x5F,0x7F,0x7F, 0x7F,0x7F,0x40,0x40,0x40,0x40,0x78,0x78,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x40, 0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0x1C,0x1C,0xE3,0xE3, 0x58,0x58,0xC7,0xC7,0xA0,0xA0,0xC3,0xC3,0x40,0x40,0x40,0x40,0x40,0x40,0x80,0x80, 0x84,0x84,0x80,0x80,0x80,0x80,0x60,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x3F,0x3F,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x19,0x19,0x00,0x00,0x00,0x00,0x3E,0x3E,0xC0,0xC0,0x18,0x18,0xC0,0xC0,0x20,0x20, 0x20,0x20,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x00,0x00,0x00,0x00, 0xE0,0xE0,0x18,0x18,0x18,0x18,0x20,0x20,0xC0,0xC0,0x00,0x00,0x00,0x00,0x18,0x18, 0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0x18,0x18,0x18,0x18,0xE0,0xE0,0x00,0x00, 0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x3F,0x3F,0xFC,0xFC,0x01,0x01, 0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x02,0x02,0x02,0x02,0x02,0x01,0x01, 0x05,0x05,0x05,0x05,0x05,0x05,0x1E,0x1E,0xE0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x6F,0x6F,0x71,0x71,0x0C,0x0C,0x9C,0x9C,0x61,0x61,0x01,0x01,0x03,0x03,0x0C,0x0C, 0x0E,0x0E,0x00,0x00,0x13,0x13,0x02,0x02,0x0C,0x0C,0x00,0x00,0x00,0x00,0x10,0x10, 0x01,0x01,0x02,0x02,0x03,0x03,0x00,0x00,0x8D,0x8D,0x01,0x01,0x03,0x03,0x80,0x80, 0x00,0x00,0x10,0x10,0x00,0x00,0x01,0x01,0x02,0x02,0x03,0x03,0x80,0x80,0x0D,0x0D, 0x01,0x01,0x02,0x02,0x80,0x80,0x00,0x00,0x00,0x00,0x7F,0x7F,0xF0,0xF0,0xF0,0xF0, 0xE0,0xE0,0xE0,0xE0,0x80,0x80,0x1C,0x1C,0xE0,0xE0,0x80,0x80,0x80,0x80,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x03,0x03,0x7C,0x7C,0x8C,0x8C, 0xEC,0xEC,0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, /* (128 X 64 )*/ } ; |
审议沈阳的回复非常神奇的说。。。。
384 浏览 0 评论
398 浏览 0 评论
405 浏览 0 评论
780 浏览 0 评论
741 浏览 0 评论
17010 浏览 31 评论
GMT+8, 2025-12-12 00:58 , Processed in 0.770845 second(s), Total 60, Slave 52 queries .
2836
