OK6410 LCD配置 代码为这个颜色 1:配置与LCD相连的GPIO GPICON = 0xaaaaaaaa; /* GPI0~GPI15用作lcd_vd[0~15] */ GPJCON =0xaaaaaaa; /* GPJ0~GPJ7用作lcd_vd[16~23] GPJ8 HSYNC GPJ9 VSYNC GPJ10 VDEN GPJ11 VCLK */ GPFCON &=~(0x3<<28); GPFCON |= (1<<28); /* GPF14用作背光使能信号 */ GPECON &= ~(0xf); GPECON |= (0x1); /* GPE0用作LCD的on/off信号 */ 2:配置相关寄存器 2. 初始化6410的display controller 2.1 hsync,vsync,vclk,vden的极性和时间参数 2.2 行数、列数(分辨率),象素颜色的格式 2.3 分配显存(frame buffer),写入display controller //下面两个由6410手册要求设置 MIFPCON &=~(1<<3); /* Normal mode */ SPCON &= ~(0x3); SPCON |= 0x1; /* RGB I/F style */ //配置输出格式和时钟 #if 0 VIDCON0 &=~((3<<26) | (3<<17) | (0xff<<6)); // RGB I/F, RGB Parallel format, VIDCON0 |= ((2<<6)| (1<<4) | (0x3<<2)); // vclk== 27MHz Ext Clock input / (CLKVAL+1) = 27/3 = 9MHz */ #else VIDCON0 &= ~((3<<26)| (3<<17) | (0xff<<6) |(3<<2)); //RGB I/F, RGB Parallel format, VIDCON0 |=((14<<6) | (1<<4) ); //vclk== HCLK / (CLKVAL+1) = 133/15 = 9MHz #endif //视频输出及显示控制信号使能 VIDCON0 &=~(0x3); //
VIDCON1 &=~((1<<7) | (1<<4)); /* 在vclk的下降沿获取数据 */ VIDCON1 |=((1<<6) | (1<<5) ); /* HSYNC高电平有效, VSYNC高电平有效 */ //配置时序规则 RGB 接口时序图:
参照4.3寸的LCD “Product Specifications” 定时(时序)规则:
由上面可以得出 VSPW =9 VBPD =1 LINEVAL=271 VFPD =1 HSPW =40 HBPD = 1 HOZVAL =479 HFPD = 1 VIDTCON0 = (VBPD << 16) | (VFPD << 8) | (VSPW<< 0); VIDTCON1 = (HBPD<< 16) | (HFPD << 8) | (HSPW << 0); VIDTCON2 = (LINEVAL<< 11) | (HOZVAL << 0); //配置窗口0 WINCON0 &= ~(0xf<< 2); WINCON0 |= (0xb<<2) | (1<<0); /* unpacked 24 BPP (non-palletized R:8-G:8-B:8 ) */ //配置窗口0的位置 LeftTopX =0 LeftTopY =0
RightBotX =479 RightBotY =271 VIDOSD0A =(LeftTopX<<11) | (LeftTopY << 0); VIDOSD0B =((RightBotX+1)<<11) | ((RightBotY+1) << 0); //窗口尺寸 VIDOSD0C = (LINEVAL +1) * (HOZVAL + 1); //设置显存在内存(帧缓冲地址)的首地址 与 尾地址 VIDW00ADD0B0 = FRAME_BUFFER; VIDW00ADD1B0 = (((HOZVAL + 1)*4 + 0) * (LINEVAL + 1)) &(0xffffff); /* VBASEL = VBASEU + (LINEWIDTH+OFFSIZE) x(LINEVAL+1) * = 0 + (480*4 + 0) * 272 * 注意只取了前24位 */ VIDW00ADD2 = HOZVAL + 1;//可以不用
