static void SetSysClock(void)
{ __IO uint32_t StartUpCounter = 0, HSEStatus = 0; /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/ #if defined (PLL_SOURCE_HSI) /* At this stage the HSI is already enabled */ /* Enable Prefetch Buffer and set Flash Latency */ FLASH-》ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY; /* HCLK = SYSCLK */ RCC-》CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1; /* PCLK = HCLK */ RCC-》CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1; /* PLL configuration = (HSI/2) * 12 = ~48 MHz */ RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL)); RCC-》CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_Div2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL12); /* Enable PLL */ RCC-》CR |= RCC_CR_PLLON; /* Wait till PLL is ready */ while((RCC-》CR & RCC_CR_PLLRDY) == 0) { } /* Select PLL as system clock source */ RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC-》CFGR |= (uint32_t)RCC_CFGR_SW_PLL; /* Wait till PLL is used as system clock source */ while ((RCC-》CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL) { } #else #if defined (PLL_SOURCE_HSE) /* Enable HSE */ RCC-》CR |= ((uint32_t)RCC_CR_HSEON); #elif defined (PLL_SOURCE_HSE_BYPASS) /* HSE oscillator bypassed with external clock */ RCC-》CR |= (uint32_t)(RCC_CR_HSEON | RCC_CR_HSEBYP); #endif /* PLL_SOURCE_HSE */ /* Wait till HSE is ready and if Time out is reached exit */ do { HSEStatus = RCC-》CR & RCC_CR_HSERDY; StartUpCounter++; } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT)); if ((RCC-》CR & RCC_CR_HSERDY) != RESET) { HSEStatus = (uint32_t)0x01; } else { HSEStatus = (uint32_t)0x00; } if (HSEStatus == (uint32_t)0x01) { /* Enable Prefetch Buffer and set Flash Latency */ FLASH-》ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY; /* HCLK = SYSCLK */ RCC-》CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1; /* PCLK = HCLK */ RCC-》CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1; /* PLL configuration = HSE * 6 = 48 MHz */ RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL)); RCC-》CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6); /* Enable PLL */ RCC-》CR |= RCC_CR_PLLON; /* Wait till PLL is ready */ while((RCC-》CR & RCC_CR_PLLRDY) == 0) { } /* Select PLL as system clock source */ RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC-》CFGR |= (uint32_t)RCC_CFGR_SW_PLL; /* Wait till PLL is used as system clock source */ while ((RCC-》CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL) { } } else { /* If HSE fails to start-up, the application will have wrong clock configuration. User can add here some code to deal with this error */ } #endif /* PLL_SOURCE_HSI */ } |
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1792 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1626 浏览 1 评论
1094 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
732 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1682 浏览 2 评论
1943浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
740浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
577浏览 3评论
600浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
562浏览 3评论
GMT+8, 2024-12-26 08:37 , Processed in 0.868557 second(s), Total 75, Slave 59 queries .
