1个回答
一、仿真电路
要求:用51单片机设计一个波形发生器,可以产生方波、三角波、正弦波、锯齿波,波形幅度可调、频率可调。 仿真电路组成: AT89C51单片机、外接晶振、复位电路 DAC0832:采样频率为 8 位的 D/A 转换芯片 NE5532高性能低噪声双运算放大器(双运放)集成电路、按键、电阻 二、Keil C51 程序设计 初始化参数 #include《reg51.h》 //51头文件 #define uchar unsigned char #define uint unsigned int ***it s1=P3^2; ***it s2=P3^3; uchar k=0,p=0,delay=0; uchar bxxz=0;pinglv=0; uchar a=1,b=0,c=0,d=0; //正弦波数据 uchar code sin[64]={ 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158, 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128 }; //方波数据报表 uchar code juxing[64]={ 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255, 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 }; //锯齿波数据 uchar code juchi[64]={ 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142, 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255 }; //三角波数据 uchar code sanjiao[64]={ 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248, 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0 }; 延时子程序 void delay1() //延时 ms级 { int a,b; for(a=1;a》0;a--) for(b=122;b》0;b--); } 外部中断0子程序 void int0() interrupt 0 //外部中断0 P3.2 中断处理,用于波形切换 { EX0=0; delay1(); if(s1==0) { bxxz++; if(bxxz==4) bxxz=0; switch(bxxz) { case 0 : {a=1,b=0,c=0,d=0;} //正弦波 break; case 1 : {a=0,b=1,c=0,d=0;} //方波 break; case 2 : {a=0,b=0,c=1,d=0;} //锯齿波 break; case 3 : {a=0,b=0,c=0,d=1;} //三角波 break; } delay1(); while(!s1); } while(!s1); EX0=1; } 外部中断1子程序 void int1() interrupt 2 //外部中断1 P3.3 中断处理,用于频率调节 { EX1=0; delay1(); if(s2==0){ p++; if(p==8) p=0; switch(p) { case 1 : pinglv=4; //400Hz break; case 2 : pinglv=8; //250Hz break; case 3 : pinglv=16; //140Hz break; case 4 : pinglv=32; //75Hz break; case 5 : pinglv=64; //40Hz break; case 6 : pinglv=125; //20Hz break; case 7 : pinglv=255; //10Hz break; default : pinglv=0; //1000Hz break; } delay1(); while(!s2); } while(!s2); EX1=1; //开中断 } 主函数 void main() { EA=1; IT0=1; EX0=1; IT1=1; EX1=1; pinglv=15; while(1) { while(a) //产生正弦波 { delay=pinglv; //获取周期数据 P2=sin[k]; //数据数P2口进行波形转换 k++; if(k==64) //一个周期取64点波数据 k=0; while(delay) //延时处理 delay--; } while(b) //产生方波 { delay=pinglv; P2=juxing[k]; k++; if(k==64) k=0; while(delay) delay--; } while(c) //产生锯齿波 { delay=pinglv; P2=juchi[k]; k++; if(k==64) k=0; while(delay) delay--; } while(d) //产生三角波 { delay=pinglv; P2=sanjiao[k]; k++; if(k==64) k=0; while(delay) delay--; } } } 三、仿真效果 正弦波 方波 锯齿波 三角波 频率可调 幅度可调 简单实现波形发生器,设计达到要求。 |
2518 浏览 0 评论
1098浏览 2评论
709浏览 1评论
460浏览 0评论
201浏览 0评论
346浏览 0评论
GMT+8, 2024-11-27 01:52 , Processed in 1.139968 second(s), Total 49, Slave 40 queries .
